Talonius Posted January 20, 2014 Share Posted January 20, 2014 OK, prerequisites.Emulator Export INI[Emulator]BakSnapPath=Z:\Emulation\NEC TurboGrafx\BackgroundEnabled=TrueSystem=NEC TurboGrafx-16Category=ConsoleEmulator=MagicEngineVersion=1.1.3Rating=DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/magicengine.7zRequiredFiles=Website=http://www.magicengine.com/Info=PC Engine (TurboGrafx 16) emulatorTitleText=NEC TurboGrafx-16StartPageName=[Console] NEC TurboGrafx-16 (MagicEngine)StartPageLogo=NEC TurboGrafx-16Command=pce.exe "[ROMPATH]\[ROMFILE]"RomFilter=Database=[Console] NEC TurboGrafx-16ConfigFile=[Mapping Off] Exit (Process Close)MapFile=[APP]\Map Files\[Console] NEC TurboGrafx-16.mapRomPath=Z:\Emulation\NEC TurboGrafx\ROMsSnapPath=Z:\Emulation\NEC TurboGrafx\SnapsTitlePath=Z:\Emulation\NEC TurboGrafx\TitlesBoxPath=Z:\Emulation\NEC TurboGrafx\BoxesCartPath=Z:\Emulation\NEC TurboGrafx\CartridgesManualPath=Z:\Emulation\NEC TurboGrafx\ManualsControlPanelPath=Z:\Emulation\NEC TurboGrafx\ControlsWorkingPath=E:\Emulators\MagicEngineMapKeys=TrueWaitBeforeKeys=SendKeys=ReplaceDash=FalseReplaceUnder=TrueCapitals=FalseRemoveBrackets=TrueShowDesktop=TrueDebug=FalseAlsoLaunch=OLDatZip=LaunchBefore=LaunchAfter=ExcludedFiles=CustomBackground=PlayMusic=FalseDontShowInfo=PlaySelectionMusic=FalseSelectionMusicFolder=PCGame=FalseGamesIn7Zips=TruePlayInScreenSaver=TrueShowMostPlayed=TrueRandomMostPlayed=TrueCDCheck=FalseCDCheckFile=VideoSnapPath=Z:\Emulation\NEC TurboGrafx\VideoSnapsUseDbName=TrueMergeSets=TrueRomsInFolders=TrueInstructionsPath=Z:\Emulation\NEC TurboGrafx\ManualsMusicPath=Z:\Emulation\NEC TurboGrafx\MusicGameEx.ini removed because it made the post too long.Log File:12:30:24.3 1/20/2014: Opening Configuration File12:30:24.3 1/20/2014: GameEx: Version 13.21: Starting Log12:30:24.3 1/20/2014: Operating System Platform: Win32NT12:30:24.3 1/20/2014: Operating System Name: Windows 712:30:24.3 1/20/2014: Operating System Version: 6.1.760112:30:24.3 1/20/2014: Aero running12:30:24.3 1/20/2014: Initializing Vista/Windows 7 volume control12:30:24.3 1/20/2014: Getting CPU and RAM info12:30:24.3 1/20/2014: Intel® Core i5-4430 CPU @ 3.00GHz, 32707MB12:30:24.3 1/20/2014: 3Ghz - 4 Cores or CPU's12:30:24.3 1/20/2014: Running Randomize()12:30:24.3 1/20/2014: Loading PlugIns12:30:24.3 1/20/2014: Checking for applications to Launch On Startup12:30:24.3 1/20/2014: Setting default net connection limit to 1512:30:24.3 1/20/2014: Running Misc startup tasks12:30:24.3 1/20/2014: Setting Menu types12:30:24.3 1/20/2014: Getting Configuration Values12:30:24.3 1/20/2014: Using Theme: Default - Dark Gloss12:30:24.3 1/20/2014: Checking for alternate Image Directory for Theme: Default - Dark Gloss12:30:24.3 1/20/2014: Launching HideOS.exe12:30:24.3 1/20/2014: Initialising Video/MNG DLL's12:30:24.3 1/20/2014: GameEx will check for media insertion (may affect performance)12:30:24.3 1/20/2014: Hiding Taskbar12:30:24.3 1/20/2014: Is Media Center running?12:30:24.3 1/20/2014: Checking/Creating LCD Registry values12:30:24.3 1/20/2014: Check Media Center Exit/Start Mode12:30:24.3 1/20/2014: Media Center Mode 212:30:24.3 1/20/2014: Custom Game Device Input enabled: Getting custom codes12:30:24.3 1/20/2014: Snap Delay set to: 412:30:24.3 1/20/2014: Get other settings12:30:24.3 1/20/2014: Desktop set to Hide ICONS and set Background to Black12:30:24.3 1/20/2014: Set: Find emulator artwork on best match basis12:30:24.3 1/20/2014: Start work for Form12:30:24.3 1/20/2014: Getting Original Screen Size12:30:24.3 1/20/2014: Opening Database Connection12:30:24.4 1/20/2014: Initializing Component12:30:24.4 1/20/2014: MAME Path is: E:\Emulators\MAME12:30:24.4 1/20/2014: MAME EXE file is: mame.exe12:30:24.4 1/20/2014: ROM Path is: \\PlexMediaServer\Games\Emulation\MAME\ROMs12:30:24.4 1/20/2014: Catver.ini is located at: E:\GameEx\DATA\catver.ini12:30:24.4 1/20/2014: controls.ini is located at: E:\GameEx\DATA\controls.ini12:30:24.5 1/20/2014: History.dat is located at: E:\GameEx\DATA\history.dat12:30:24.5 1/20/2014: nplayers.ini is located at: E:\GameEx\DATA\nplayers.ini12:30:24.5 1/20/2014: command.dat is located at: E:\GameEx\DATA\command.dat12:30:24.5 1/20/2014: MAMEinfo.dat is located at: E:\GameEx\DATA\mameinfo.dat12:30:24.5 1/20/2014: Loading Controls.ini map file12:30:24.5 1/20/2014: Snap Path is: \\PlexMediaServer\Games\Emulation\MAME\Snaps12:30:24.5 1/20/2014: Background Snap Path is: \\PlexMediaServer\Games\Emulation\MAME\Snaps12:30:24.5 1/20/2014: AVI Snap Path is: \\PlexMediaServer\Games\Emulation\MAME\Video12:30:24.5 1/20/2014: Flyer Path is: \\PlexMediaServer\Games\Emulation\MAME\Flyers12:30:24.5 1/20/2014: Cabinet Path is: \\PlexMediaServer\Games\Emulation\MAME\Cabinets12:30:24.5 1/20/2014: Cabinet 3D Path is: \\PlexMediaServer\Games\Emulation\MAME\Cabinets3D12:30:24.5 1/20/2014: Title Path is: \\PlexMediaServer\Games\Emulation\MAME\Titles12:30:24.5 1/20/2014: PCB Path is: \\PlexMediaServer\Games\Emulation\MAME\PCB12:30:24.5 1/20/2014: Artwork Preview Path is: \\PlexMediaServer\Games\Emulation\MAME\Artwork Preview12:30:24.6 1/20/2014: Panel Path is: \\PlexMediaServer\Games\Emulation\MAME\Panel12:30:24.6 1/20/2014: Manual Path is: \\PlexMediaServer\Games\Emulation\MAME\Manuals12:30:24.6 1/20/2014: Icon Path is: \\PlexMediaServer\Games\Emulation\MAME\Icons12:30:24.6 1/20/2014: Marquee Path is: \\PlexMediaServer\Games\Emulation\MAME\Marquees12:30:24.6 1/20/2014: Applying Language/Text12:30:24.6 1/20/2014: Text/Language: English12:30:24.6 1/20/2014: Loading Language/Text12:30:24.6 1/20/2014: Loading Custom Emulators12:30:24.6 1/20/2014: Loading Emulator 1: [Arcade] Arcade (MAME)12:30:24.6 1/20/2014: Loading Emulator 2: [Console] Atari 2600 (MESS)12:30:24.6 1/20/2014: Loading Emulator 3: [Console] Atari 5200 (MESS)12:30:24.6 1/20/2014: Loading Emulator 4: [Console] Atari 7800 (MESS)12:30:24.6 1/20/2014: Loading Emulator 5: [Console] Atari Jaguar (Virtual Jaguar)12:30:24.6 1/20/2014: Loading Emulator 6: [Console] Coleco Vision (MESS)12:30:24.6 1/20/2014: Loading Emulator 7: [Console] Commodore Amiga CD32 (WinUAE)12:30:24.7 1/20/2014: Loading Emulator 8: [Console] NEC TurboGrafx CD (MagicEngine)12:30:24.7 1/20/2014: Loading Emulator 9: [Console] NEC TurboGrafx-16 (MagicEngine)12:30:24.7 1/20/2014: Loading Emulator 10: [Console] Nintendo GameCube (Dolphin)12:30:24.7 1/20/2014: Loading Emulator 11: [Console] Nintendo N64 (Project64)12:30:24.7 1/20/2014: Loading Emulator 12: [Console] Nintendo NES (MESS)12:30:24.7 1/20/2014: Loading Emulator 13: [Console] Nintendo SNES (MESS)12:30:24.7 1/20/2014: Loading Emulator 14: [Console] Nintendo Wii (Dolphin)12:30:24.7 1/20/2014: Loading Emulator 15: [Console] Sega 32X (GENS+)12:30:24.7 1/20/2014: Loading Emulator 16: [Console] Sega CD (GENS+)12:30:24.7 1/20/2014: Loading Emulator 17: [Console] Sega Dreamcast (nullDC)12:30:24.8 1/20/2014: Loading Emulator 18: [Console] Sega Genesis (GENS+)12:30:24.8 1/20/2014: Loading Emulator 19: [Console] Sega Master System (GENS+)12:30:24.8 1/20/2014: Loading Emulator 20: [Console] Sega Saturn (SSF)12:30:24.8 1/20/2014: Loading Emulator 21: [Console] SNK Neo Geo (Nebula)12:30:24.8 1/20/2014: Loading Emulator 22: [Console] SNK Neo Geo CD (Nebula)12:30:24.8 1/20/2014: Loading Emulator 23: [Console] Sony Playstation 2 (PCSX2)12:30:24.8 1/20/2014: Loading Emulator 24: [Handheld] Atari Lynx (mednafen)12:30:24.8 1/20/2014: Loading Emulator 25: [Handheld] Bandai WonderSwan Color (mednafen)12:30:24.8 1/20/2014: Loading Emulator 26: [Handheld] Nintendo Game Boy (mednafen)12:30:24.8 1/20/2014: Loading Emulator 27: [Handheld] Nintendo Game Boy Advance (mednafen)12:30:24.8 1/20/2014: Loading Emulator 28: [Handheld] Nintendo Game Boy Color (mednafen)12:30:24.8 1/20/2014: Checking if Steam enabled12:30:24.8 1/20/2014: Steam is installed correctly12:30:24.8 1/20/2014: Found Steam Base Install Folder: f:/program files (x86)/steam12:30:24.9 1/20/2014: Found Steam Game: Ticket to Ride. AppID=108200. Location:F:\Program Files (x86)\Steam\steamapps\common\Ticket to Ride12:30:24.9 1/20/2014: Found Steam Game: Blocks That Matter. AppID=111800. Location:F:\Program Files (x86)\Steam\steamapps\common\Blocks That Matter12:30:24.9 1/20/2014: Found Steam Game: Avadon: The Black Fortress. AppID=112100. Location:F:\Program Files (x86)\Steam\steamapps\common\Avadon The Black Fortress12:30:24.9 1/20/2014: Found Steam Game: The Binding of Isaac. AppID=113200. Location:F:\Program Files (x86)\Steam\steamapps\common\The Binding Of Isaac12:30:24.9 1/20/2014: Found Steam Game: DiRT 2. AppID=12840. Location:f:\program files (x86)\steam\steamapps\common\dirt 212:30:24.9 1/20/2014: Found Steam Game: Spore. AppID=17390. Location:F:\Program Files (x86)\Steam\steamapps\common\Spore12:30:24.9 1/20/2014: Found Steam Game: Need for Speed: Undercover. AppID=17430. Location:F:\Program Files (x86)\Steam\steamapps\common\Need for Speed Undercover12:30:24.9 1/20/2014: Found Steam Game: Spore: Creepy & Cute Parts Pack. AppID=17440. Location:F:\Program Files (x86)\Steam\steamapps\common\Spore12:30:24.9 1/20/2014: Found Steam Game: On the Rain-Slick Precipice of Darkness, Episode One. AppID=18000. Location:F:\Program Files (x86)\Steam\steamapps\common\On the Rain-Slick Precipice of Darkness - Episode One12:30:24.9 1/20/2014: Found Steam Game: On the Rain-Slick Precipice of Darkness, Episode Two. AppID=18020. Location:F:\Program Files (x86)\Steam\steamapps\common\Penny Arcade Adventures On the Rain-Slick Precipice of Darkness Episode 212:30:24.9 1/20/2014: Found Steam Game: Batman: Arkham City GOTY. AppID=200260. Location:F:\Program Files (x86)\Steam\steamapps\common\Batman Arkham City GOTY12:30:24.9 1/20/2014: Found Steam Game: Geneforge 1. AppID=200960. Location:F:\Program Files (x86)\Steam\steamapps\common\Geneforge12:30:24.9 1/20/2014: Found Steam Game: Geneforge 2. AppID=200980. Location:F:\Program Files (x86)\Steam\steamapps\common\Geneforge 212:30:24.9 1/20/2014: Found Steam Game: Geneforge 3. AppID=200990. Location:F:\Program Files (x86)\Steam\steamapps\common\Geneforge 312:30:24.9 1/20/2014: Found Steam Game: Geneforge 4. AppID=201000. Location:F:\Program Files (x86)\Steam\steamapps\common\Geneforge 412:30:25.0 1/20/2014: Found Steam Game: Geneforge 5. AppID=201010. Location:F:\Program Files (x86)\Steam\steamapps\common\Geneforge 512:30:25.0 1/20/2014: Found Steam Game: Fable - The Lost Chapters. AppID=204030. Location:F:\Program Files (x86)\Steam\steamapps\common\Fable The Lost Chapters12:30:25.0 1/20/2014: Found Steam Game: Avernum 4. AppID=206020. Location:F:\Program Files (x86)\Steam\steamapps\common\Avernum 412:30:25.0 1/20/2014: Found Steam Game: Avernum 5. AppID=206040. Location:F:\Program Files (x86)\Steam\steamapps\common\Avernum 512:30:25.0 1/20/2014: Found Steam Game: Avernum 6. AppID=206060. Location:F:\Program Files (x86)\Steam\steamapps\common\Avernum 612:30:25.0 1/20/2014: Found Steam Game: Hack, Slash, Loot. AppID=207430. Location:F:\Program Files (x86)\Steam\steamapps\common\HackSlashLoot12:30:25.0 1/20/2014: Found Steam Game: Thief Gold. AppID=211600. Location:F:\Program Files (x86)\Steam\steamapps\common\thief_gold12:30:25.0 1/20/2014: Found Steam Game: Thief 2. AppID=211740. Location:F:\Program Files (x86)\Steam\steamapps\common\thief_212:30:25.0 1/20/2014: Found Steam Game: Transformers: Fall of Cybertron. AppID=213120. Location:F:\Program Files (x86)\Steam\steamapps\common\Transformers Fall of Cybertron12:30:25.0 1/20/2014: Invalid or filtered path:12:30:25.0 1/20/2014: Found Steam Game: World of Goo. AppID=22000. Location:F:\Program Files (x86)\Steam\steamapps\common\World of Goo12:30:25.0 1/20/2014: Found Steam Game: Penumbra: Overture. AppID=22180. Location:F:\Program Files (x86)\Steam\steamapps\common\Penumbra Overture12:30:25.0 1/20/2014: Found Steam Game: Ys I. AppID=223810. Location:F:\Program Files (x86)\Steam\steamapps\common\Ys I12:30:25.0 1/20/2014: Found Steam Game: Ys II. AppID=223870. Location:F:\Program Files (x86)\Steam\steamapps\common\Ys II12:30:25.0 1/20/2014: Found Steam Game: Worms Reloaded. AppID=22600. Location:F:\Program Files (x86)\Steam\steamapps\common\Worms Reloaded12:30:25.0 1/20/2014: Found Steam Game: Skulls of the Shogun. AppID=228960. Location:F:\Program Files (x86)\Steam\steamapps\common\Skulls of the Shogun12:30:25.0 1/20/2014: Found Steam Game: Incredipede. AppID=230150. Location:F:\Program Files (x86)\Steam\steamapps\common\Incredipede12:30:25.0 1/20/2014: Found Steam Game: Company of Heroes 2. AppID=231430. Location:F:\Program Files (x86)\Steam\steamapps\common\Company of Heroes 212:30:25.1 1/20/2014: Found Steam Game: Avadon 2: The Corruption. AppID=233310. Location:F:\Program Files (x86)\Steam\steamapps\common\Avadon 212:30:25.1 1/20/2014: Found Steam Game: Organ Trail: Director's Cut. AppID=233740. Location:F:\Program Files (x86)\Steam\steamapps\common\OrganTrailDC12:30:25.1 1/20/2014: Found Steam Game: Anodyne. AppID=234900. Location:F:\Program Files (x86)\Steam\steamapps\common\Anodyne12:30:25.1 1/20/2014: Found Steam Game: Mortal Kombat Komplete Edition. AppID=237110. Location:F:\Program Files (x86)\Steam\steamapps\common\MortalKombat_KompleteEdition12:30:25.1 1/20/2014: Found Steam Game: The Banner Saga. AppID=237990. Location:F:\Program Files (x86)\Steam\steamapps\common\tbs12:30:25.1 1/20/2014: Found Steam Game: Space Hulk. AppID=242570. Location:F:\Program Files (x86)\Steam\steamapps\common\Space Hulk12:30:25.1 1/20/2014: Found Steam Game: Injustice: Gods Among Us Ultimate Edition. AppID=242700. Location:F:\Program Files (x86)\Steam\steamapps\common\InjusticeGodsAmongUs_UltimateEdition12:30:25.1 1/20/2014: Found Steam Game: Aquaria. AppID=24420. Location:F:\Program Files (x86)\Steam\steamapps\common\Aquaria12:30:25.1 1/20/2014: Found Steam Game: Spore: Galactic Adventures. AppID=24720. Location:F:\Program Files (x86)\Steam\steamapps\common\spore12:30:25.1 1/20/2014: Found Steam Game: Need for Speed: SHIFT. AppID=24870. Location:F:\Program Files (x86)\Steam\steamapps\common\Need For Speed Shift12:30:25.1 1/20/2014: Found Steam Game: Lugaru HD . AppID=25010. Location:F:\Program Files (x86)\Steam\steamapps\common\Lugaru HD12:30:25.1 1/20/2014: Found Steam Game: Anomaly Korea. AppID=251530. Location:F:\Program Files (x86)\Steam\steamapps\common\Anomaly Korea12:30:25.1 1/20/2014: Found Steam Game: RollerCoaster Tycoon 3: Platinum!. AppID=2700. Location:F:\Program Files (x86)\Steam\steamapps\common\Rollercoaster Tycoon 3 Gold12:30:25.1 1/20/2014: Found Steam Game: Osmos. AppID=29180. Location:F:\Program Files (x86)\Steam\steamapps\common\Osmos12:30:25.1 1/20/2014: Found Steam Game: The Secret of Monkey Island: Special Edition. AppID=32360. Location:F:\Program Files (x86)\Steam\steamapps\common\The Secret of Monkey Island Special Edition12:30:25.1 1/20/2014: Invalid or filtered path:12:30:25.1 1/20/2014: Found Steam Game: Arma 2: Operation Arrowhead. AppID=33930. Location:F:\Program Files (x86)\Steam\steamapps\common\Arma 2 Operation Arrowhead12:30:25.1 1/20/2014: Found Steam Game: Batman: Arkham Asylum GOTY Edition. AppID=35140. Location:F:\Program Files (x86)\Steam\steamapps\common\Batman Arkham Asylum GOTY12:30:25.1 1/20/2014: Found Steam Game: Samorost 2. AppID=40720. Location:F:\Program Files (x86)\Steam\steamapps\common\Samorost 212:30:25.1 1/20/2014: Found Steam Game: Blur. AppID=42640. Location:F:\Program Files (x86)\Steam\steamapps\common\Blur12:30:25.1 1/20/2014: Found Steam Game: Transformers: War for Cybertron. AppID=42650. Location:F:\Program Files (x86)\Steam\steamapps\common\Transformers War for Cybertron12:30:25.1 1/20/2014: Found Steam Game: GRID 2. AppID=44350. Location:F:\Program Files (x86)\Steam\steamapps\common\grid 212:30:25.2 1/20/2014: Found Steam Game: Need for Speed: Hot Pursuit. AppID=47870. Location:f:\program files (x86)\steam\steamapps\common\need for speed hot pursuit12:30:25.2 1/20/2014: Found Steam Game: Assassin's Creed Brotherhood. AppID=48190. Location:F:\Program Files (x86)\Steam\steamapps\common\Assassins Creed Brotherhood12:30:25.2 1/20/2014: Found Steam Game: Broken Sword 1 - Shadow of the Templars: Director's Cut. AppID=57640. Location:F:\Program Files (x86)\Steam\steamapps\common\Broken Sword Shadow of the Templars12:30:25.2 1/20/2014: Found Steam Game: Arma 2: British Armed Forces. AppID=65700. Location:F:\Program Files (x86)\Steam\steamapps\common\ARMA 2 Operation Arrowhead12:30:25.2 1/20/2014: Invalid or filtered path:12:30:25.2 1/20/2014: Found Steam Game: Thief: Deadly Shadows. AppID=6980. Location:F:\Program Files (x86)\Steam\steamapps\common\Thief Deadly Shadows12:30:25.2 1/20/2014: Found Steam Game: Sam & Max 102: Situation: Comedy. AppID=8210. Location:F:\Program Files (x86)\Steam\steamapps\common\Sam and Max Episode 212:30:25.2 1/20/2014: Found Steam Game: Gish. AppID=9500. Location:F:\Program Files (x86)\Steam\steamapps\common\Gish12:30:25.2 1/20/2014: Found Steam games. Steam enabled.12:30:25.2 1/20/2014: Using 3D Alpha Blended Animations.12:30:25.2 1/20/2014: Retrieving resolution setting12:30:25.2 1/20/2014: Using General Font: Tahoma12:30:25.2 1/20/2014: Using Title Font: Tahoma12:30:25.2 1/20/2014: GameEx will try to reduce CPU usage12:30:25.2 1/20/2014: Initialising Direct3D12:30:25.3 1/20/2014: Mouse Input is disabled12:30:25.3 1/20/2014: Applying GameEx is Loading Image12:30:25.3 1/20/2014: Setting Resolution to 1920x1080 32 bit color12:30:25.3 1/20/2014: Creating Surfaces12:30:25.4 1/20/2014: Creating Primary Surface - Full Screen Mode12:30:25.5 1/20/2014: Creating Back Buffer12:30:25.5 1/20/2014: Loading graphic Surfaces12:30:25.5 1/20/2014: Display is running at: 1920x1080 32bit color, 60hz12:30:25.5 1/20/2014: Adapter: NVIDIA GeForce GTX 650 Ti BOOST12:30:25.5 1/20/2014: Max texture size: 16384x1638412:30:25.5 1/20/2014: Available texture memory: -82MB12:30:25.5 1/20/2014: Initialising Bass Audio Library12:30:25.5 1/20/2014: Creating Surfaces Misc and Dialogs12:30:25.5 1/20/2014: Creating Surfaces Volume12:30:25.5 1/20/2014: Creating Surfaces Arrows12:30:25.5 1/20/2014: Creating Surfaces GameEXlogo Text12:30:25.5 1/20/2014: Creating Surfaces Toolbar12:30:25.5 1/20/2014: Creating Surfaces Toolbar Controls12:30:25.5 1/20/2014: Creating Surfaces Backgrounds12:30:25.6 1/20/2014: Creating Surfaces GameEx Logo12:30:25.6 1/20/2014: Creating Surface Unselected12:30:25.6 1/20/2014: Creating Surfaces Snaps12:30:25.6 1/20/2014: Creating Surfaces Menu and List Bars12:30:25.6 1/20/2014: Creating Fonts12:30:25.6 1/20/2014: Creating Game Font12:30:25.6 1/20/2014: Creating Game Font Faded12:30:25.7 1/20/2014: Creating Title Font12:30:25.7 1/20/2014: Restoring Title Font From Cache12:30:25.8 1/20/2014: Creating Font Black12:30:25.8 1/20/2014: Creating Font Black Small12:30:25.9 1/20/2014: Fonts Created Succesfully12:30:26.1 1/20/2014: Playing Startup Video on thread12:30:26.1 1/20/2014: Attempting to load game list12:30:26.1 1/20/2014: MAME CMD options: -nowindow -joy -skip_gameinfo12:30:26.2 1/20/2014: Cannot Load Play List. Check Path and filename12:30:26.2 1/20/2014: Initialising DirectInput for Gamepad support12:30:26.2 1/20/2014: Using Device Controller (XBOX 360 For Windows)12:30:26.3 1/20/2014: Loading Start Page12:30:26.3 1/20/2014: Initializing MCE Remote12:30:26.3 1/20/2014: Initialization OK! Starting GameEx!12:30:26.3 1/20/2014: Testing Main Loop Once: Processing Frame12:30:26.5 1/20/2014: Testing Main Loop Once: Main Loop ran successfully12:30:26.9 1/20/2014: Validating: Emulator_2: Snap Path: \\PlexMediaServer\Games\Emulation\Atari 2600\Snaps12:30:26.9 1/20/2014: Validating: Emulator_2: Background Snap Path: \\PlexMediaServer\Games\Emulation\Atari 2600\Background12:30:26.9 1/20/2014: Validating: Emulator_2: Video Snap Path: \\PlexMediaServer\Games\Emulation\Atari 2600\VideoSnaps12:30:26.9 1/20/2014: Validating: Emulator_2: Control Panel Path: \\PlexMediaServer\Games\Emulation\Atari 2600\Controls12:30:26.9 1/20/2014: Validating: Emulator_2: Database: [Console] Atari 260012:30:26.9 1/20/2014: Validating: Emulator_2: Title Snap Path: \\PlexMediaServer\Games\Emulation\Atari 2600\Titles12:30:26.9 1/20/2014: Validating: Emulator_2: Box Art Path: \\PlexMediaServer\Games\Emulation\Atari 2600\Boxes12:30:26.9 1/20/2014: Validating: Emulator_2: Cart Art Path: \\PlexMediaServer\Games\Emulation\Atari 2600\Cartridges12:30:26.9 1/20/2014: Validating: Emulator_2: Manual Path: \\PlexMediaServer\Games\Emulation\Atari 2600\Manuals12:30:26.9 1/20/2014: Caching Video Snap Path12:30:26.9 1/20/2014: Caching Snap Path12:30:27.0 1/20/2014: Caching Title Path12:30:27.0 1/20/2014: Caching Box Path12:30:27.0 1/20/2014: Caching Cart Path12:30:27.1 1/20/2014: Caching Background Path12:30:27.1 1/20/2014: Validating: Emulator_3: Snap Path: \\PlexMediaServer\Games\Emulation\Atari 5200\Snaps12:30:27.1 1/20/2014: Validating: Emulator_3: Background Snap Path: \\PlexMediaServer\Games\Emulation\Atari 5200\Background12:30:27.1 1/20/2014: Validating: Emulator_3: Video Snap Path: \\PlexMediaServer\Games\Emulation\Atari 5200\VideoSnaps12:30:27.1 1/20/2014: Validating: Emulator_3: Control Panel Path: \\PlexMediaServer\Games\Emulation\Atari 5200\Controls12:30:27.1 1/20/2014: Validating: Emulator_3: Database: [Console] Atari 520012:30:27.1 1/20/2014: Validating: Emulator_3: Title Snap Path: \\PlexMediaServer\Games\Emulation\Atari 5200\Titles12:30:27.1 1/20/2014: Validating: Emulator_3: Box Art Path: \\PlexMediaServer\Games\Emulation\Atari 5200\Boxes12:30:27.1 1/20/2014: Validating: Emulator_3: Cart Art Path: \\PlexMediaServer\Games\Emulation\Atari 5200\Cartridges12:30:27.1 1/20/2014: Validating: Emulator_3: Manual Path: \\PlexMediaServer\Games\Emulation\Atari 5200\Manuals12:30:27.1 1/20/2014: Caching Video Snap Path12:30:27.1 1/20/2014: Caching Snap Path12:30:27.2 1/20/2014: Caching Title Path12:30:27.2 1/20/2014: Caching Box Path12:30:27.2 1/20/2014: Caching Cart Path12:30:27.2 1/20/2014: Caching Background Path12:30:27.2 1/20/2014: Validating: Emulator_4: Snap Path: \\PlexMediaServer\Games\Emulation\Atari 7800\Snaps12:30:27.2 1/20/2014: Validating: Emulator_4: Background Snap Path: \\PlexMediaServer\Games\Emulation\Atari 7800\Background12:30:27.2 1/20/2014: Validating: Emulator_4: Video Snap Path: \\PlexMediaServer\Games\Emulation\Atari 7800\VideoSnaps12:30:27.2 1/20/2014: Validating: Emulator_4: Control Panel Path: \\PlexMediaServer\Games\Emulation\Atari 7800\Controls12:30:27.2 1/20/2014: Validating: Emulator_4: Database: [Console] Atari 780012:30:27.2 1/20/2014: Validating: Emulator_4: Title Snap Path: \\PlexMediaServer\Games\Emulation\Atari 7800\Titles12:30:27.3 1/20/2014: Validating: Emulator_4: Box Art Path: \\PlexMediaServer\Games\Emulation\Atari 7800\Boxes12:30:27.3 1/20/2014: Validating: Emulator_4: Cart Art Path: \\PlexMediaServer\Games\Emulation\Atari 7800\Cartridges12:30:27.3 1/20/2014: Validating: Emulator_4: Manual Path: \\PlexMediaServer\Games\Emulation\Atari 7800\Manuals12:30:27.3 1/20/2014: Caching Video Snap Path12:30:27.3 1/20/2014: Caching Snap Path12:30:27.3 1/20/2014: Caching Title Path12:30:27.3 1/20/2014: Caching Box Path12:30:27.3 1/20/2014: Caching Cart Path12:30:27.3 1/20/2014: Caching Background Path12:30:27.3 1/20/2014: Validating: Emulator_5: Snap Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\Snaps12:30:27.4 1/20/2014: Validating: Emulator_5: Background Snap Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\Background12:30:27.4 1/20/2014: Validating: Emulator_5: Video Snap Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\VideoSnaps12:30:27.4 1/20/2014: Validating: Emulator_5: Control Panel Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\Controls12:30:27.4 1/20/2014: Validating: Emulator_5: Database: [Console] Atari Jaguar12:30:27.4 1/20/2014: Validating: Emulator_5: Title Snap Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\Titles12:30:27.4 1/20/2014: Validating: Emulator_5: Box Art Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\Boxes12:30:27.4 1/20/2014: Validating: Emulator_5: Cart Art Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\Cartridges12:30:27.4 1/20/2014: Validating: Emulator_5: Manual Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\Manuals12:30:27.4 1/20/2014: Caching Video Snap Path12:30:27.4 1/20/2014: Caching Snap Path12:30:27.4 1/20/2014: Caching Title Path12:30:27.4 1/20/2014: Caching Box Path12:30:27.4 1/20/2014: Caching Cart Path12:30:27.4 1/20/2014: Caching Background Path12:30:27.4 1/20/2014: Validating: Emulator_6: Snap Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\Snaps12:30:27.5 1/20/2014: Validating: Emulator_6: Background Snap Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\Background12:30:27.5 1/20/2014: Validating: Emulator_6: Video Snap Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\VideoSnaps12:30:27.5 1/20/2014: Validating: Emulator_6: Control Panel Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\Controls12:30:27.5 1/20/2014: Validating: Emulator_6: Database: [Console] Coleco Vision12:30:27.5 1/20/2014: Validating: Emulator_6: Title Snap Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\Titles12:30:27.5 1/20/2014: Validating: Emulator_6: Box Art Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\Boxes12:30:27.5 1/20/2014: Validating: Emulator_6: Cart Art Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\Cartridges12:30:27.5 1/20/2014: Validating: Emulator_6: Manual Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\Manuals12:30:27.5 1/20/2014: Caching Video Snap Path12:30:27.5 1/20/2014: Caching Snap Path12:30:27.5 1/20/2014: Caching Title Path12:30:27.5 1/20/2014: Caching Box Path12:30:27.5 1/20/2014: Caching Cart Path12:30:27.6 1/20/2014: Caching Background Path12:30:27.6 1/20/2014: Validating: Emulator_7: Snap Path: \\PlexMediaServer\Games\Emulation\Commodore Amiga CD32\Snaps12:30:27.6 1/20/2014: Validating: Emulator_7: Control Panel Path: \\PlexMediaServer\Games\Emulation\Commodore Amiga CD32\Controls12:30:27.6 1/20/2014: Validating: Emulator_7: Database: [Console] Commodore Amiga CD3212:30:27.6 1/20/2014: Validating: Emulator_7: Title Snap Path: \\PlexMediaServer\Games\Emulation\Commodore Amiga CD32\Titles12:30:27.6 1/20/2014: Validating: Emulator_7: Box Art Path: \\PlexMediaServer\Games\Emulation\Commodore Amiga CD32\Boxes12:30:27.6 1/20/2014: Validating: Emulator_7: Cart Art Path: \\PlexMediaServer\Games\Emulation\Commodore Amiga CD32\Cartridges12:30:27.6 1/20/2014: Validating: Emulator_7: Manual Path: \\PlexMediaServer\Games\Emulation\Commodore Amiga CD32\Manuals12:30:27.6 1/20/2014: Caching Video Snap Path12:30:27.6 1/20/2014: Caching Snap Path12:30:27.6 1/20/2014: Caching Title Path12:30:27.6 1/20/2014: Caching Box Path12:30:27.6 1/20/2014: Caching Cart Path12:30:27.6 1/20/2014: Validating: Emulator_8: Snap Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\Snaps12:30:27.6 1/20/2014: Validating: Emulator_8: Background Snap Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\Background12:30:27.6 1/20/2014: Validating: Emulator_8: Video Snap Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\VideoSnaps12:30:27.6 1/20/2014: Validating: Emulator_8: Control Panel Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\Controls12:30:27.7 1/20/2014: Validating: Emulator_8: Database: [Console] NEC TurboGrafx CD12:30:27.7 1/20/2014: Validating: Emulator_8: Title Snap Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\Titles12:30:27.7 1/20/2014: Validating: Emulator_8: Box Art Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\Boxes12:30:27.7 1/20/2014: Validating: Emulator_8: Cart Art Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\Cartridges12:30:27.7 1/20/2014: Validating: Emulator_8: Manual Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\Manuals12:30:27.7 1/20/2014: Caching Video Snap Path12:30:27.7 1/20/2014: Caching Snap Path12:30:27.7 1/20/2014: Caching Title Path12:30:27.7 1/20/2014: Caching Box Path12:30:27.7 1/20/2014: Caching Cart Path12:30:27.7 1/20/2014: Caching Background Path12:30:27.7 1/20/2014: Validating: Emulator_9: Snap Path: Z:\Emulation\NEC TurboGrafx\Snaps12:30:27.8 1/20/2014: Validating: Emulator_9: Background Snap Path: Z:\Emulation\NEC TurboGrafx\Background12:30:27.8 1/20/2014: Validating: Emulator_9: Video Snap Path: Z:\Emulation\NEC TurboGrafx\VideoSnaps12:30:27.8 1/20/2014: Validating: Emulator_9: Control Panel Path: Z:\Emulation\NEC TurboGrafx\Controls12:30:27.8 1/20/2014: Validating: Emulator_9: Instructions Path: Z:\Emulation\NEC TurboGrafx\Manuals12:30:27.8 1/20/2014: Validating: Emulator_9: Database: [Console] NEC TurboGrafx-1612:30:27.8 1/20/2014: Validating: Emulator_9: Title Snap Path: Z:\Emulation\NEC TurboGrafx\Titles12:30:27.8 1/20/2014: Validating: Emulator_9: Box Art Path: Z:\Emulation\NEC TurboGrafx\Boxes12:30:27.8 1/20/2014: Validating: Emulator_9: Cart Art Path: Z:\Emulation\NEC TurboGrafx\Cartridges12:30:27.8 1/20/2014: Validating: Emulator_9: Music Path: Z:\Emulation\NEC TurboGrafx\Music12:30:27.8 1/20/2014: Validating: Emulator_9: Manual Path: Z:\Emulation\NEC TurboGrafx\Manuals12:30:27.8 1/20/2014: Caching Video Snap Path12:30:27.8 1/20/2014: Caching Snap Path12:30:27.8 1/20/2014: Caching Title Path12:30:27.8 1/20/2014: Caching Box Path12:30:27.8 1/20/2014: Caching Cart Path12:30:27.9 1/20/2014: Caching Background Path12:30:27.9 1/20/2014: Validating: Emulator_10: Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo GameCube\Snaps12:30:27.9 1/20/2014: Validating: Emulator_10: Control Panel Path: \\PlexMediaServer\Games\Emulation\Nintendo GameCube\Controls12:30:27.9 1/20/2014: Validating: Emulator_10: Database: [Console] Nintendo GameCube12:30:27.9 1/20/2014: Validating: Emulator_10: Title Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo GameCube\Titles12:30:27.9 1/20/2014: Validating: Emulator_10: Box Art Path: \\PlexMediaServer\Games\Emulation\Nintendo GameCube\Boxes12:30:27.9 1/20/2014: Validating: Emulator_10: Cart Art Path: \\PlexMediaServer\Games\Emulation\Nintendo GameCube\Cartridges12:30:27.9 1/20/2014: Validating: Emulator_10: Manual Path: \\PlexMediaServer\Games\Emulation\Nintendo GameCube\Manuals12:30:27.9 1/20/2014: Caching Video Snap Path12:30:27.9 1/20/2014: Caching Snap Path12:30:27.9 1/20/2014: Caching Title Path12:30:27.9 1/20/2014: Caching Box Path12:30:27.9 1/20/2014: Caching Cart Path12:30:27.9 1/20/2014: Validating: Emulator_11: Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\Snaps12:30:27.9 1/20/2014: Validating: Emulator_11: Background Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\Background12:30:27.9 1/20/2014: Validating: Emulator_11: Video Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\VideoSnaps12:30:27.9 1/20/2014: Warning: Emulator_11: Video Snap Path Does not exist12:30:27.9 1/20/2014: Validating: Emulator_11: Control Panel Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\Controls12:30:27.9 1/20/2014: Validating: Emulator_11: Database: [Console] Nintendo N6412:30:28.0 1/20/2014: Validating: Emulator_11: Title Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\Titles12:30:28.0 1/20/2014: Validating: Emulator_11: Box Art Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\Boxes12:30:28.0 1/20/2014: Validating: Emulator_11: Cart Art Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\Cartridges12:30:28.0 1/20/2014: Validating: Emulator_11: Manual Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\Manuals12:30:28.0 1/20/2014: Caching Video Snap Path12:30:28.0 1/20/2014: Caching Snap Path12:30:28.0 1/20/2014: Caching Title Path12:30:28.0 1/20/2014: Caching Box Path12:30:28.0 1/20/2014: Caching Cart Path12:30:28.0 1/20/2014: Caching Background Path12:30:28.1 1/20/2014: Validating: Emulator_12: Snap Path: \\PlexMediaServer\Games\Emulation\NES\Snaps12:30:28.1 1/20/2014: Validating: Emulator_12: Control Panel Path: \\PlexMediaServer\Games\Emulation\Nintendo NES\Controls12:30:28.1 1/20/2014: Warning: Emulator_12: Control Panel Path Does not exist12:30:28.1 1/20/2014: Validating: Emulator_12: Database: [Console] Nintendo NES12:30:28.1 1/20/2014: Validating: Emulator_12: Title Snap Path: \\PlexMediaServer\Games\Emulation\NES\Titles12:30:28.1 1/20/2014: Validating: Emulator_12: Box Art Path: \\PlexMediaServer\Games\Emulation\NES\Boxes12:30:28.1 1/20/2014: Validating: Emulator_12: Cart Art Path: \\PlexMediaServer\Games\Emulation\NES\Cartridges12:30:28.1 1/20/2014: Validating: Emulator_12: Manual Path: \\PlexMediaServer\Games\Emulation\NES\Manuals12:30:28.1 1/20/2014: Caching Video Snap Path12:30:28.1 1/20/2014: Caching Snap Path12:30:28.1 1/20/2014: Caching Title Path12:30:28.2 1/20/2014: Caching Box Path12:30:28.2 1/20/2014: Caching Cart Path12:30:28.2 1/20/2014: Validating: Emulator_13: Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo SNES\Snaps12:30:28.2 1/20/2014: Validating: Emulator_13: Control Panel Path: \\PlexMediaServer\Games\Emulation\Nintendo SNES\Controls12:30:28.3 1/20/2014: Validating: Emulator_13: Database: [Console] Nintendo SNES12:30:28.3 1/20/2014: Validating: Emulator_13: Title Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo SNES\Titles12:30:28.3 1/20/2014: Validating: Emulator_13: Box Art Path: \\PlexMediaServer\Games\Emulation\Nintendo SNES\Boxes12:30:28.3 1/20/2014: Validating: Emulator_13: Cart Art Path: \\PlexMediaServer\Games\Emulation\Nintendo SNES\Cartridges12:30:28.3 1/20/2014: Validating: Emulator_13: Manual Path: \\PlexMediaServer\Games\Emulation\Nintendo SNES\Manuals12:30:28.3 1/20/2014: Caching Video Snap Path12:30:28.9 1/20/2014: Caching Snap Path12:30:28.9 1/20/2014: Caching Title Path12:30:29.5 1/20/2014: Caching Box Path12:30:29.6 1/20/2014: Caching Cart Path12:30:29.6 1/20/2014: Validating: Emulator_14: Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo Wii\Snaps12:30:29.6 1/20/2014: Validating: Emulator_14: Control Panel Path: \\PlexMediaServer\Games\Emulation\Nintendo Wii\Controls12:30:29.6 1/20/2014: Validating: Emulator_14: Database: [Console] Nintendo Wii12:30:29.6 1/20/2014: Validating: Emulator_14: Title Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo Wii\Titles12:30:29.6 1/20/2014: Validating: Emulator_14: Box Art Path: \\PlexMediaServer\Games\Emulation\Nintendo Wii\Boxes12:30:29.6 1/20/2014: Validating: Emulator_14: Cart Art Path: \\PlexMediaServer\Games\Emulation\Nintendo Wii\Cartridges12:30:29.6 1/20/2014: Validating: Emulator_14: Manual Path: \\PlexMediaServer\Games\Emulation\Nintendo Wii\Manuals12:30:29.6 1/20/2014: Caching Video Snap Path12:30:29.6 1/20/2014: Caching Snap Path12:30:29.6 1/20/2014: Caching Title Path12:30:29.6 1/20/2014: Caching Box Path12:30:29.6 1/20/2014: Caching Cart Path12:30:29.6 1/20/2014: Validating: Emulator_15: Snap Path: \\PlexMediaServer\Games\Emulation\Sega 32X\Snaps12:30:29.6 1/20/2014: Validating: Emulator_15: Control Panel Path: \\PlexMediaServer\Games\Emulation\Sega 32X\Controls12:30:29.6 1/20/2014: Validating: Emulator_15: Database: [Console] Sega 32X12:30:29.6 1/20/2014: Validating: Emulator_15: Title Snap Path: \\PlexMediaServer\Games\Emulation\Sega 32X\Titles12:30:29.7 1/20/2014: Validating: Emulator_15: Box Art Path: \\PlexMediaServer\Games\Emulation\Sega 32X\Boxes12:30:29.7 1/20/2014: Validating: Emulator_15: Cart Art Path: \\PlexMediaServer\Games\Emulation\Sega 32X\Cartridges12:30:29.7 1/20/2014: Validating: Emulator_15: Manual Path: \\PlexMediaServer\Games\Emulation\Sega 32X\Manuals12:30:29.7 1/20/2014: Caching Video Snap Path12:30:29.7 1/20/2014: Caching Snap Path12:30:29.7 1/20/2014: Caching Title Path12:30:29.7 1/20/2014: Caching Box Path12:30:29.7 1/20/2014: Caching Cart Path12:30:29.7 1/20/2014: Validating: Emulator_16: Snap Path: \\PlexMediaServer\Games\Emulation\Sega Genesis CD\Snaps12:30:29.7 1/20/2014: Validating: Emulator_16: Control Panel Path: \\PlexMediaServer\Games\Emulation\Sega CD\Controls12:30:29.7 1/20/2014: Warning: Emulator_16: Control Panel Path Does not exist12:30:29.7 1/20/2014: Validating: Emulator_16: Database: [Console] Sega CD12:30:29.7 1/20/2014: Validating: Emulator_16: Title Snap Path: \\PlexMediaServer\Games\Emulation\Sega Genesis CD\Titles12:30:29.7 1/20/2014: Validating: Emulator_16: Box Art Path: \\PlexMediaServer\Games\Emulation\Sega Genesis CD\Boxes12:30:29.7 1/20/2014: Validating: Emulator_16: Cart Art Path: \\PlexMediaServer\Games\Emulation\Sega Genesis CD\Cartridges12:30:29.7 1/20/2014: Validating: Emulator_16: Manual Path: \\PlexMediaServer\Games\Emulation\Sega Genesis CD\Manuals12:30:29.7 1/20/2014: Caching Video Snap Path12:30:29.8 1/20/2014: Caching Snap Path12:30:29.8 1/20/2014: Caching Title Path12:30:29.8 1/20/2014: Caching Box Path12:30:29.8 1/20/2014: Caching Cart Path12:30:29.8 1/20/2014: Validating: Emulator_17: Snap Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Snaps12:30:29.8 1/20/2014: Validating: Emulator_17: Background Snap Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Background Snaps12:30:29.8 1/20/2014: Validating: Emulator_17: Video Snap Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Video Snaps12:30:29.8 1/20/2014: Validating: Emulator_17: Control Panel Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Controls12:30:29.8 1/20/2014: Validating: Emulator_17: Database: [Console] Sega Dreamcast12:30:29.8 1/20/2014: Validating: Emulator_17: Title Snap Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Titles12:30:29.8 1/20/2014: Validating: Emulator_17: Box Art Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Boxes12:30:29.8 1/20/2014: Validating: Emulator_17: Cart Art Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Cartridges12:30:29.8 1/20/2014: Validating: Emulator_17: Manual Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Manuals12:30:29.8 1/20/2014: Caching Video Snap Path12:30:29.8 1/20/2014: Caching Snap Path12:30:29.8 1/20/2014: Caching Title Path12:30:29.9 1/20/2014: Caching Box Path12:30:29.9 1/20/2014: Caching Cart Path12:30:29.9 1/20/2014: Caching Background Path12:30:29.9 1/20/2014: Validating: Emulator_18: Snap Path: \\PlexMediaServer\Games\Emulation\Sega Genesis\Snaps12:30:29.9 1/20/2014: Validating: Emulator_18: Control Panel Path: \\PlexMediaServer\Games\Emulation\Sega Genesis\Controls12:30:29.9 1/20/2014: Validating: Emulator_18: Database: [Console] Sega Genesis12:30:29.9 1/20/2014: Validating: Emulator_18: Title Snap Path: \\PlexMediaServer\Games\Emulation\Sega Genesis\Titles12:30:29.9 1/20/2014: Validating: Emulator_18: Box Art Path: \\PlexMediaServer\Games\Emulation\Sega Genesis\Boxes12:30:29.9 1/20/2014: Validating: Emulator_18: Cart Art Path: \\PlexMediaServer\Games\Emulation\Sega Genesis\Cartridges12:30:29.9 1/20/2014: Validating: Emulator_18: Manual Path: \\PlexMediaServer\Games\Emulation\Sega Genesis\Manuals12:30:29.9 1/20/2014: Caching Video Snap Path12:30:30.0 1/20/2014: Caching Snap Path12:30:30.0 1/20/2014: Caching Title Path12:30:30.1 1/20/2014: Caching Box Path12:30:30.1 1/20/2014: Caching Cart Path12:30:30.1 1/20/2014: Validating: Emulator_19: Snap Path: \\PlexMediaServer\Games\Emulation\Sega Master System\Snaps12:30:30.1 1/20/2014: Validating: Emulator_19: Control Panel Path: \\PlexMediaServer\Games\Emulation\Sega Master System\Controls12:30:30.1 1/20/2014: Validating: Emulator_19: Database: [Console] Sega Master System12:30:30.1 1/20/2014: Validating: Emulator_19: Title Snap Path: \\PlexMediaServer\Games\Emulation\Sega Master System\Titles12:30:30.1 1/20/2014: Validating: Emulator_19: Box Art Path: \\PlexMediaServer\Games\Emulation\Sega Master System\Boxes12:30:30.2 1/20/2014: Validating: Emulator_19: Cart Art Path: \\PlexMediaServer\Games\Emulation\Sega Master System\Cartridges12:30:30.2 1/20/2014: Validating: Emulator_19: Manual Path: \\PlexMediaServer\Games\Emulation\Sega Master System\Manuals12:30:30.2 1/20/2014: Caching Video Snap Path12:30:30.2 1/20/2014: Caching Snap Path12:30:30.2 1/20/2014: Caching Title Path12:30:30.2 1/20/2014: Caching Box Path12:30:30.2 1/20/2014: Caching Cart Path12:30:30.3 1/20/2014: Validating: Emulator_20: Snap Path: \\PlexMediaServer\Games\Emulation\Sega Saturn\Snaps12:30:30.3 1/20/2014: Validating: Emulator_20: Control Panel Path: \\PlexMediaServer\Games\Emulation\Sega Saturn\Controls12:30:30.3 1/20/2014: Validating: Emulator_20: Database: [Console] Sega Saturn12:30:30.3 1/20/2014: Validating: Emulator_20: Title Snap Path: \\PlexMediaServer\Games\Emulation\Sega Saturn\Titles12:30:30.3 1/20/2014: Validating: Emulator_20: Box Art Path: \\PlexMediaServer\Games\Emulation\Sega Saturn\Boxes12:30:30.3 1/20/2014: Validating: Emulator_20: Cart Art Path: \\PlexMediaServer\Games\Emulation\Sega Saturn\Cartridges12:30:30.3 1/20/2014: Validating: Emulator_20: Manual Path: \\PlexMediaServer\Games\Emulation\Sega Saturn\Manuals12:30:30.3 1/20/2014: Caching Video Snap Path12:30:30.3 1/20/2014: Caching Snap Path12:30:30.3 1/20/2014: Caching Title Path12:30:30.3 1/20/2014: Caching Box Path12:30:30.3 1/20/2014: Caching Cart Path12:30:30.3 1/20/2014: Validating: Emulator_21: Snap Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo\Snaps12:30:30.3 1/20/2014: Validating: Emulator_21: Control Panel Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo\Controls12:30:30.3 1/20/2014: Validating: Emulator_21: Database: [Console] SNK Neo Geo12:30:30.3 1/20/2014: Validating: Emulator_21: Title Snap Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo\Titles12:30:30.3 1/20/2014: Validating: Emulator_21: Box Art Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo\Boxes12:30:30.3 1/20/2014: Validating: Emulator_21: Cart Art Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo\Cartridges12:30:30.3 1/20/2014: Validating: Emulator_21: Manual Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo\Manuals12:30:30.3 1/20/2014: Caching Video Snap Path12:30:30.4 1/20/2014: Caching Snap Path12:30:30.4 1/20/2014: Caching Title Path12:30:30.4 1/20/2014: Caching Box Path12:30:30.4 1/20/2014: Caching Cart Path12:30:30.4 1/20/2014: Validating: Emulator_22: Snap Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo CD\Snaps12:30:30.4 1/20/2014: Validating: Emulator_22: Control Panel Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo CD\Controls12:30:30.4 1/20/2014: Validating: Emulator_22: Database: [Console] SNK Neo Geo CD12:30:30.4 1/20/2014: Validating: Emulator_22: Title Snap Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo CD\Titles12:30:30.4 1/20/2014: Validating: Emulator_22: Box Art Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo CD\Boxes12:30:30.4 1/20/2014: Validating: Emulator_22: Cart Art Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo CD\Cartridges12:30:30.4 1/20/2014: Validating: Emulator_22: Manual Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo CD\Manuals12:30:30.4 1/20/2014: Caching Video Snap Path12:30:30.4 1/20/2014: Caching Snap Path12:30:30.4 1/20/2014: Caching Title Path12:30:30.4 1/20/2014: Caching Box Path12:30:30.4 1/20/2014: Caching Cart Path12:30:30.5 1/20/2014: Validating: Emulator_23: Snap Path: \\PlexMediaServer\Games\Emulation\Sony Playstation 2\Snaps12:30:30.5 1/20/2014: Validating: Emulator_23: Control Panel Path: \\PlexMediaServer\Games\Emulation\Sony Playstation 2\Controls12:30:30.5 1/20/2014: Validating: Emulator_23: Database: [Console] Sony PlayStation 212:30:30.5 1/20/2014: Validating: Emulator_23: Title Snap Path: \\PlexMediaServer\Games\Emulation\Sony Playstation 2\Titles12:30:30.5 1/20/2014: Validating: Emulator_23: Box Art Path: \\PlexMediaServer\Games\Emulation\Sony Playstation 2\Boxes12:30:30.5 1/20/2014: Validating: Emulator_23: Cart Art Path: \\PlexMediaServer\Games\Emulation\Sony Playstation 2\Cartridges12:30:30.5 1/20/2014: Validating: Emulator_23: Manual Path: \\PlexMediaServer\Games\Emulation\Sony Playstation 2\Manuals12:30:30.5 1/20/2014: Warning: Emulator_23: MAPFile Does Not Exist12:30:30.5 1/20/2014: Caching Video Snap Path12:30:30.5 1/20/2014: Caching Snap Path12:30:30.5 1/20/2014: Caching Title Path12:30:30.5 1/20/2014: Caching Box Path12:30:30.5 1/20/2014: Caching Cart Path12:30:30.5 1/20/2014: Validating: Emulator_24: Snap Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\Snaps12:30:30.5 1/20/2014: Validating: Emulator_24: Background Snap Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\Background12:30:30.5 1/20/2014: Validating: Emulator_24: Video Snap Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\VideoSnaps12:30:30.5 1/20/2014: Validating: Emulator_24: Control Panel Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\Controls12:30:30.5 1/20/2014: Validating: Emulator_24: Database: [Handheld] Atari Lynx12:30:30.5 1/20/2014: Validating: Emulator_24: Title Snap Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\Titles12:30:30.5 1/20/2014: Validating: Emulator_24: Box Art Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\Boxes12:30:30.5 1/20/2014: Validating: Emulator_24: Cart Art Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\Cartridges12:30:30.5 1/20/2014: Validating: Emulator_24: Manual Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\Manuals12:30:30.6 1/20/2014: Caching Video Snap Path12:30:30.6 1/20/2014: Caching Snap Path12:30:30.6 1/20/2014: Caching Title Path12:30:30.6 1/20/2014: Caching Box Path12:30:30.6 1/20/2014: Caching Cart Path12:30:30.6 1/20/2014: Caching Background Path12:30:30.6 1/20/2014: Validating: Emulator_25: Snap Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\Snaps12:30:30.6 1/20/2014: Validating: Emulator_25: Background Snap Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\Background12:30:30.6 1/20/2014: Validating: Emulator_25: Video Snap Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\VideoSnaps12:30:30.6 1/20/2014: Validating: Emulator_25: Control Panel Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\Controls12:30:30.6 1/20/2014: Validating: Emulator_25: Database: [Handheld] Bandai WonderSwan Color12:30:30.6 1/20/2014: Validating: Emulator_25: Title Snap Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\Titles12:30:30.6 1/20/2014: Validating: Emulator_25: Box Art Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\Boxes12:30:30.6 1/20/2014: Validating: Emulator_25: Cart Art Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\Cartridges12:30:30.7 1/20/2014: Validating: Emulator_25: Manual Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\Manuals12:30:30.7 1/20/2014: Caching Video Snap Path12:30:30.7 1/20/2014: Caching Snap Path12:30:30.7 1/20/2014: Caching Title Path12:30:30.7 1/20/2014: Caching Box Path12:30:30.7 1/20/2014: Caching Cart Path12:30:30.7 1/20/2014: Caching Background Path12:30:30.8 1/20/2014: Restoring Emulator from Cache: 212:30:30.8 1/20/2014: Restoring Emulator Database From Cache: 212:30:30.9 1/20/2014: Restoring Emulator from Cache: 312:30:30.9 1/20/2014: Restoring Emulator Database From Cache: 312:30:30.9 1/20/2014: Restoring Emulator from Cache: 412:30:30.9 1/20/2014: Restoring Emulator Database From Cache: 412:30:30.9 1/20/2014: Restoring Emulator from Cache: 512:30:30.9 1/20/2014: Restoring Emulator Database From Cache: 512:30:32.0 1/20/2014: Restoring Emulator from Cache: 612:30:32.0 1/20/2014: Restoring Emulator Database From Cache: 612:30:32.2 1/20/2014: Restoring Emulator Database From Cache: 912:30:32.2 1/20/2014: Restoring Emulator from Cache: 1112:30:32.2 1/20/2014: Restoring Emulator Database From Cache: 1112:30:32.2 1/20/2014: Restoring Emulator from Cache: 1212:30:32.3 1/20/2014: Restoring Emulator Database From Cache: 1212:30:32.3 1/20/2014: Restoring Emulator from Cache: 1312:30:32.4 1/20/2014: Restoring Emulator Database From Cache: 1312:30:32.6 1/20/2014: Restoring Emulator from Cache: 1712:30:32.6 1/20/2014: No Database Data: 1712:30:32.6 1/20/2014: Restoring Emulator from Cache: 1812:30:32.7 1/20/2014: Restoring Emulator Database From Cache: 1812:30:32.7 1/20/2014: Restoring Emulator from Cache: 1912:30:32.7 1/20/2014: Restoring Emulator Database From Cache: 1912:30:32.8 1/20/2014: Restoring Emulator from Cache: 2112:30:32.8 1/20/2014: Restoring Emulator Database From Cache: 2112:30:32.8 1/20/2014: Restoring Emulator from Cache: 2412:30:32.9 1/20/2014: Restoring Emulator Database From Cache: 2412:30:32.9 1/20/2014: Restoring Emulator from Cache: 2512:30:32.9 1/20/2014: Restoring Emulator Database From Cache: 2512:32:22.2 1/20/2014: Mouse Input is disabled12:32:30.4 1/20/2014: Saving Settings12:32:30.4 1/20/2014: Running: cmd.exe /c E: GameExConfig.exe12:32:30.5 1/20/2014: Shutting down display12:32:39.7 1/20/2014: GameEx configuration updated, reinitialising12:32:39.7 1/20/2014: Reloading Configuration file12:32:39.8 1/20/2014: Getting Configuration Values12:32:39.8 1/20/2014: Using Theme: Default - Dark Gloss12:32:39.8 1/20/2014: Checking for alternate Image Directory for Theme: Default - Dark Gloss12:32:39.8 1/20/2014: Launching HideOS.exe12:32:39.8 1/20/2014: Initialising Video/MNG DLL's12:32:39.8 1/20/2014: GameEx will check for media insertion (may affect performance)12:32:39.8 1/20/2014: Hiding Taskbar12:32:39.8 1/20/2014: Is Media Center running?12:32:39.8 1/20/2014: Checking/Creating LCD Registry values12:32:39.8 1/20/2014: Check Media Center Exit/Start Mode12:32:39.8 1/20/2014: Media Center Mode 212:32:39.8 1/20/2014: Custom Game Device Input enabled: Getting custom codes12:32:39.8 1/20/2014: Snap Delay set to: 412:32:39.8 1/20/2014: Get other settings12:32:39.8 1/20/2014: Set: Find emulator artwork on best match basis12:32:39.8 1/20/2014: Opening Database Connection12:32:39.8 1/20/2014: MAME Path is: E:\Emulators\MAME12:32:39.8 1/20/2014: MAME EXE file is: mame.exe12:32:39.8 1/20/2014: ROM Path is: \\PlexMediaServer\Games\Emulation\MAME\ROMs12:32:39.8 1/20/2014: Catver.ini is located at: E:\GameEx\DATA\catver.ini12:32:39.8 1/20/2014: controls.ini is located at: E:\GameEx\DATA\controls.ini12:32:39.8 1/20/2014: History.dat is located at: E:\GameEx\DATA\history.dat12:32:39.8 1/20/2014: nplayers.ini is located at: E:\GameEx\DATA\nplayers.ini12:32:39.8 1/20/2014: command.dat is located at: E:\GameEx\DATA\command.dat12:32:39.8 1/20/2014: MAMEinfo.dat is located at: E:\GameEx\DATA\mameinfo.dat12:32:39.8 1/20/2014: Snap Path is: \\PlexMediaServer\Games\Emulation\MAME\Snaps12:32:39.9 1/20/2014: Background Snap Path is: \\PlexMediaServer\Games\Emulation\MAME\Snaps12:32:39.9 1/20/2014: AVI Snap Path is: \\PlexMediaServer\Games\Emulation\MAME\Video12:32:39.9 1/20/2014: Flyer Path is: \\PlexMediaServer\Games\Emulation\MAME\Flyers12:32:39.9 1/20/2014: Cabinet Path is: \\PlexMediaServer\Games\Emulation\MAME\Cabinets12:32:39.9 1/20/2014: Cabinet 3D Path is: \\PlexMediaServer\Games\Emulation\MAME\Cabinets3D12:32:39.9 1/20/2014: Title Path is: \\PlexMediaServer\Games\Emulation\MAME\Titles12:32:39.9 1/20/2014: PCB Path is: \\PlexMediaServer\Games\Emulation\MAME\PCB12:32:39.9 1/20/2014: Artwork Preview Path is: \\PlexMediaServer\Games\Emulation\MAME\Artwork Preview12:32:39.9 1/20/2014: Panel Path is: \\PlexMediaServer\Games\Emulation\MAME\Panel12:32:39.9 1/20/2014: Manual Path is: \\PlexMediaServer\Games\Emulation\MAME\Manuals12:32:39.9 1/20/2014: Icon Path is: \\PlexMediaServer\Games\Emulation\MAME\Icons12:32:39.9 1/20/2014: Marquee Path is: \\PlexMediaServer\Games\Emulation\MAME\Marquees12:32:39.9 1/20/2014: Applying Language/Text12:32:39.9 1/20/2014: Text/Language: English12:32:39.9 1/20/2014: Loading Language/Text12:32:39.9 1/20/2014: Loading Custom Emulators12:32:39.9 1/20/2014: Loading Emulator 1: [Arcade] Arcade (MAME)12:32:39.9 1/20/2014: Loading Emulator 2: [Console] Atari 2600 (MESS)12:32:39.9 1/20/2014: Loading Emulator 3: [Console] Atari 5200 (MESS)12:32:39.9 1/20/2014: Loading Emulator 4: [Console] Atari 7800 (MESS)12:32:39.9 1/20/2014: Loading Emulator 5: [Console] Atari Jaguar (Virtual Jaguar)12:32:40.0 1/20/2014: Loading Emulator 6: [Console] Coleco Vision (MESS)12:32:40.0 1/20/2014: Loading Emulator 7: [Console] Commodore Amiga CD32 (WinUAE)12:32:40.0 1/20/2014: Loading Emulator 8: [Console] NEC TurboGrafx CD (MagicEngine)12:32:40.0 1/20/2014: Loading Emulator 9: [Console] NEC TurboGrafx-16 (MagicEngine)12:32:40.0 1/20/2014: Loading Emulator 10: [Console] Nintendo GameCube (Dolphin)12:32:40.0 1/20/2014: Loading Emulator 11: [Console] Nintendo N64 (Project64)12:32:40.0 1/20/2014: Loading Emulator 12: [Console] Nintendo NES (MESS)12:32:40.0 1/20/2014: Loading Emulator 13: [Console] Nintendo SNES (MESS)12:32:40.0 1/20/2014: Loading Emulator 14: [Console] Nintendo Wii (Dolphin)12:32:40.0 1/20/2014: Loading Emulator 15: [Console] Sega 32X (GENS+)12:32:40.0 1/20/2014: Loading Emulator 16: [Console] Sega CD (GENS+)12:32:40.1 1/20/2014: Loading Emulator 17: [Console] Sega Dreamcast (nullDC)12:32:40.1 1/20/2014: Loading Emulator 18: [Console] Sega Genesis (GENS+)12:32:40.1 1/20/2014: Loading Emulator 19: [Console] Sega Master System (GENS+)12:32:40.1 1/20/2014: Loading Emulator 20: [Console] Sega Saturn (SSF)12:32:40.1 1/20/2014: Loading Emulator 21: [Console] SNK Neo Geo (Nebula)12:32:40.1 1/20/2014: Loading Emulator 22: [Console] SNK Neo Geo CD (Nebula)12:32:40.1 1/20/2014: Loading Emulator 23: [Console] Sony Playstation 2 (PCSX2)12:32:40.1 1/20/2014: Loading Emulator 24: [Handheld] Atari Lynx (mednafen)12:32:40.1 1/20/2014: Loading Emulator 25: [Handheld] Bandai WonderSwan Color (mednafen)12:32:40.1 1/20/2014: Loading Emulator 26: [Handheld] Nintendo Game Boy (mednafen)12:32:40.1 1/20/2014: Loading Emulator 27: [Handheld] Nintendo Game Boy Advance (mednafen)12:32:40.1 1/20/2014: Loading Emulator 28: [Handheld] Nintendo Game Boy Color (mednafen)12:32:40.2 1/20/2014: Using 3D Alpha Blended Animations.12:32:40.2 1/20/2014: Retrieving resolution setting12:32:40.2 1/20/2014: Using General Font: Tahoma12:32:40.2 1/20/2014: Using Title Font: Tahoma12:32:40.2 1/20/2014: GameEx will try to reduce CPU usage12:32:40.2 1/20/2014: Initialising Direct3D12:32:40.2 1/20/2014: Mouse Input is disabled12:32:40.2 1/20/2014: Applying GameEx is Loading Image12:32:40.2 1/20/2014: Setting Resolution to 1920x1080 32 bit color12:32:40.2 1/20/2014: Creating Surfaces12:32:40.3 1/20/2014: Creating Primary Surface - Full Screen Mode12:32:40.3 1/20/2014: Creating Back Buffer12:32:40.3 1/20/2014: Loading graphic Surfaces12:32:40.3 1/20/2014: Display is running at: 1920x1080 32bit color, 60hz12:32:40.3 1/20/2014: Adapter: NVIDIA GeForce GTX 650 Ti BOOST12:32:40.3 1/20/2014: Max texture size: 16384x1638412:32:40.3 1/20/2014: Available texture memory: -82MB12:32:40.3 1/20/2014: Initialising Bass Audio Library12:32:40.3 1/20/2014: Creating Surfaces Misc and Dialogs12:32:40.4 1/20/2014: Creating Surfaces Volume12:32:40.4 1/20/2014: Creating Surfaces Arrows12:32:40.4 1/20/2014: Creating Surfaces GameEXlogo Text12:32:40.4 1/20/2014: Creating Surfaces Toolbar12:32:40.4 1/20/2014: Creating Surfaces Toolbar Controls12:32:40.4 1/20/2014: Creating Surfaces Backgrounds12:32:40.4 1/20/2014: Creating Surfaces GameEx Logo12:32:40.4 1/20/2014: Creating Surface Unselected12:32:40.4 1/20/2014: Creating Surfaces Snaps12:32:40.4 1/20/2014: Creating Surfaces Menu and List Bars12:32:40.4 1/20/2014: Creating Fonts12:32:40.4 1/20/2014: Creating Game Font12:32:40.5 1/20/2014: Creating Game Font Faded12:32:40.5 1/20/2014: Creating Title Font12:32:40.5 1/20/2014: Restoring Title Font From Cache12:32:40.6 1/20/2014: Creating Font Black12:32:40.6 1/20/2014: Creating Font Black Small12:32:40.6 1/20/2014: Fonts Created Succesfully12:32:40.9 1/20/2014: Attempting to load game list12:32:40.9 1/20/2014: MAME CMD options: -nowindow -joy -skip_gameinfo12:32:40.9 1/20/2014: Cannot Load Play List. Check Path and filename12:32:40.9 1/20/2014: Loading Start Page12:32:41.0 1/20/2014: Initializing MCE Remote12:32:41.0 1/20/2014: Testing Main Loop Once: Main Loop ran successfully12:32:46.4 1/20/2014: Validating: Emulator_2: Snap Path: \\PlexMediaServer\Games\Emulation\Atari 2600\Snaps12:32:46.4 1/20/2014: Validating: Emulator_2: Background Snap Path: \\PlexMediaServer\Games\Emulation\Atari 2600\Background12:32:46.4 1/20/2014: Validating: Emulator_2: Video Snap Path: \\PlexMediaServer\Games\Emulation\Atari 2600\VideoSnaps12:32:46.4 1/20/2014: Validating: Emulator_2: Control Panel Path: \\PlexMediaServer\Games\Emulation\Atari 2600\Controls12:32:46.4 1/20/2014: Validating: Emulator_2: Database: [Console] Atari 260012:32:46.4 1/20/2014: Validating: Emulator_2: Title Snap Path: \\PlexMediaServer\Games\Emulation\Atari 2600\Titles12:32:46.4 1/20/2014: Validating: Emulator_2: Box Art Path: \\PlexMediaServer\Games\Emulation\Atari 2600\Boxes12:32:46.4 1/20/2014: Validating: Emulator_2: Cart Art Path: \\PlexMediaServer\Games\Emulation\Atari 2600\Cartridges12:32:46.5 1/20/2014: Validating: Emulator_2: Manual Path: \\PlexMediaServer\Games\Emulation\Atari 2600\Manuals12:32:46.5 1/20/2014: Caching Video Snap Path12:32:46.5 1/20/2014: Caching Snap Path12:32:46.5 1/20/2014: Caching Title Path12:32:46.5 1/20/2014: Caching Box Path12:32:46.5 1/20/2014: Caching Cart Path12:32:46.5 1/20/2014: Caching Background Path12:32:46.5 1/20/2014: Validating: Emulator_3: Snap Path: \\PlexMediaServer\Games\Emulation\Atari 5200\Snaps12:32:46.5 1/20/2014: Validating: Emulator_3: Background Snap Path: \\PlexMediaServer\Games\Emulation\Atari 5200\Background12:32:46.5 1/20/2014: Validating: Emulator_3: Video Snap Path: \\PlexMediaServer\Games\Emulation\Atari 5200\VideoSnaps12:32:46.5 1/20/2014: Validating: Emulator_3: Control Panel Path: \\PlexMediaServer\Games\Emulation\Atari 5200\Controls12:32:46.5 1/20/2014: Validating: Emulator_3: Database: [Console] Atari 520012:32:46.5 1/20/2014: Validating: Emulator_3: Title Snap Path: \\PlexMediaServer\Games\Emulation\Atari 5200\Titles12:32:46.5 1/20/2014: Validating: Emulator_3: Box Art Path: \\PlexMediaServer\Games\Emulation\Atari 5200\Boxes12:32:46.5 1/20/2014: Validating: Emulator_3: Cart Art Path: \\PlexMediaServer\Games\Emulation\Atari 5200\Cartridges12:32:46.5 1/20/2014: Validating: Emulator_3: Manual Path: \\PlexMediaServer\Games\Emulation\Atari 5200\Manuals12:32:46.5 1/20/2014: Caching Video Snap Path12:32:46.5 1/20/2014: Caching Snap Path12:32:46.5 1/20/2014: Caching Title Path12:32:46.5 1/20/2014: Caching Box Path12:32:46.5 1/20/2014: Caching Cart Path12:32:46.5 1/20/2014: Caching Background Path12:32:46.5 1/20/2014: Validating: Emulator_4: Snap Path: \\PlexMediaServer\Games\Emulation\Atari 7800\Snaps12:32:46.5 1/20/2014: Validating: Emulator_4: Background Snap Path: \\PlexMediaServer\Games\Emulation\Atari 7800\Background12:32:46.5 1/20/2014: Validating: Emulator_4: Video Snap Path: \\PlexMediaServer\Games\Emulation\Atari 7800\VideoSnaps12:32:46.5 1/20/2014: Validating: Emulator_4: Control Panel Path: \\PlexMediaServer\Games\Emulation\Atari 7800\Controls12:32:46.5 1/20/2014: Validating: Emulator_4: Database: [Console] Atari 780012:32:46.5 1/20/2014: Validating: Emulator_4: Title Snap Path: \\PlexMediaServer\Games\Emulation\Atari 7800\Titles12:32:46.5 1/20/2014: Validating: Emulator_4: Box Art Path: \\PlexMediaServer\Games\Emulation\Atari 7800\Boxes12:32:46.5 1/20/2014: Validating: Emulator_4: Cart Art Path: \\PlexMediaServer\Games\Emulation\Atari 7800\Cartridges12:32:46.5 1/20/2014: Validating: Emulator_4: Manual Path: \\PlexMediaServer\Games\Emulation\Atari 7800\Manuals12:32:46.5 1/20/2014: Caching Video Snap Path12:32:46.5 1/20/2014: Caching Snap Path12:32:46.5 1/20/2014: Caching Title Path12:32:46.5 1/20/2014: Caching Box Path12:32:46.5 1/20/2014: Caching Cart Path12:32:46.5 1/20/2014: Caching Background Path12:32:46.5 1/20/2014: Validating: Emulator_5: Snap Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\Snaps12:32:46.5 1/20/2014: Validating: Emulator_5: Background Snap Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\Background12:32:46.5 1/20/2014: Validating: Emulator_5: Video Snap Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\VideoSnaps12:32:46.5 1/20/2014: Validating: Emulator_5: Control Panel Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\Controls12:32:46.5 1/20/2014: Validating: Emulator_5: Database: [Console] Atari Jaguar12:32:46.5 1/20/2014: Validating: Emulator_5: Title Snap Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\Titles12:32:46.5 1/20/2014: Validating: Emulator_5: Box Art Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\Boxes12:32:46.5 1/20/2014: Validating: Emulator_5: Cart Art Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\Cartridges12:32:46.5 1/20/2014: Validating: Emulator_5: Manual Path: \\PlexMediaServer\Games\Emulation\Atari Jaguar\Manuals12:32:46.6 1/20/2014: Caching Video Snap Path12:32:46.6 1/20/2014: Caching Snap Path12:32:46.6 1/20/2014: Caching Title Path12:32:46.6 1/20/2014: Caching Box Path12:32:46.6 1/20/2014: Caching Cart Path12:32:46.6 1/20/2014: Caching Background Path12:32:46.6 1/20/2014: Validating: Emulator_6: Snap Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\Snaps12:32:46.6 1/20/2014: Validating: Emulator_6: Background Snap Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\Background12:32:46.6 1/20/2014: Validating: Emulator_6: Video Snap Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\VideoSnaps12:32:46.6 1/20/2014: Validating: Emulator_6: Control Panel Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\Controls12:32:46.6 1/20/2014: Validating: Emulator_6: Database: [Console] Coleco Vision12:32:46.6 1/20/2014: Validating: Emulator_6: Title Snap Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\Titles12:32:46.6 1/20/2014: Validating: Emulator_6: Box Art Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\Boxes12:32:46.6 1/20/2014: Validating: Emulator_6: Cart Art Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\Cartridges12:32:46.6 1/20/2014: Validating: Emulator_6: Manual Path: \\PlexMediaServer\Games\Emulation\Coleco Vision\Manuals12:32:46.6 1/20/2014: Caching Video Snap Path12:32:46.6 1/20/2014: Caching Snap Path12:32:46.6 1/20/2014: Caching Title Path12:32:46.6 1/20/2014: Caching Box Path12:32:46.6 1/20/2014: Caching Cart Path12:32:46.6 1/20/2014: Caching Background Path12:32:46.6 1/20/2014: Validating: Emulator_7: Snap Path: \\PlexMediaServer\Games\Emulation\Commodore Amiga CD32\Snaps12:32:46.6 1/20/2014: Validating: Emulator_7: Control Panel Path: \\PlexMediaServer\Games\Emulation\Commodore Amiga CD32\Controls12:32:46.6 1/20/2014: Validating: Emulator_7: Database: [Console] Commodore Amiga CD3212:32:46.6 1/20/2014: Validating: Emulator_7: Title Snap Path: \\PlexMediaServer\Games\Emulation\Commodore Amiga CD32\Titles12:32:46.6 1/20/2014: Validating: Emulator_7: Box Art Path: \\PlexMediaServer\Games\Emulation\Commodore Amiga CD32\Boxes12:32:46.6 1/20/2014: Validating: Emulator_7: Cart Art Path: \\PlexMediaServer\Games\Emulation\Commodore Amiga CD32\Cartridges12:32:46.6 1/20/2014: Validating: Emulator_7: Manual Path: \\PlexMediaServer\Games\Emulation\Commodore Amiga CD32\Manuals12:32:46.6 1/20/2014: Caching Video Snap Path12:32:46.6 1/20/2014: Caching Snap Path12:32:46.6 1/20/2014: Caching Title Path12:32:46.6 1/20/2014: Caching Box Path12:32:46.6 1/20/2014: Caching Cart Path12:32:46.6 1/20/2014: Validating: Emulator_8: Snap Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\Snaps12:32:46.6 1/20/2014: Validating: Emulator_8: Background Snap Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\Background12:32:46.6 1/20/2014: Validating: Emulator_8: Video Snap Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\VideoSnaps12:32:46.6 1/20/2014: Validating: Emulator_8: Control Panel Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\Controls12:32:46.6 1/20/2014: Validating: Emulator_8: Database: [Console] NEC TurboGrafx CD12:32:46.6 1/20/2014: Validating: Emulator_8: Title Snap Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\Titles12:32:46.6 1/20/2014: Validating: Emulator_8: Box Art Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\Boxes12:32:46.6 1/20/2014: Validating: Emulator_8: Cart Art Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\Cartridges12:32:46.6 1/20/2014: Validating: Emulator_8: Manual Path: \\PlexMediaServer\Games\Emulation\NEC TurboGrafx\Manuals12:32:46.6 1/20/2014: Caching Video Snap Path12:32:46.6 1/20/2014: Caching Snap Path12:32:46.6 1/20/2014: Caching Title Path12:32:46.6 1/20/2014: Caching Box Path12:32:46.6 1/20/2014: Caching Cart Path12:32:46.6 1/20/2014: Caching Background Path12:32:46.6 1/20/2014: Validating: Emulator_9: Snap Path: Z:\Emulation\NEC TurboGrafx\Snaps12:32:46.6 1/20/2014: Validating: Emulator_9: Background Snap Path: Z:\Emulation\NEC TurboGrafx\Background12:32:46.7 1/20/2014: Validating: Emulator_9: Video Snap Path: Z:\Emulation\NEC TurboGrafx\VideoSnaps12:32:46.7 1/20/2014: Validating: Emulator_9: Control Panel Path: Z:\Emulation\NEC TurboGrafx\Controls12:32:46.7 1/20/2014: Validating: Emulator_9: Instructions Path: Z:\Emulation\NEC TurboGrafx\Manuals12:32:46.7 1/20/2014: Validating: Emulator_9: Database: [Console] NEC TurboGrafx-1612:32:46.7 1/20/2014: Validating: Emulator_9: Title Snap Path: Z:\Emulation\NEC TurboGrafx\Titles12:32:46.7 1/20/2014: Validating: Emulator_9: Box Art Path: Z:\Emulation\NEC TurboGrafx\Boxes12:32:46.7 1/20/2014: Validating: Emulator_9: Cart Art Path: Z:\Emulation\NEC TurboGrafx\Cartridges12:32:46.7 1/20/2014: Validating: Emulator_9: Music Path: Z:\Emulation\NEC TurboGrafx\Music12:32:46.7 1/20/2014: Validating: Emulator_9: Manual Path: Z:\Emulation\NEC TurboGrafx\Manuals12:32:46.7 1/20/2014: Caching Video Snap Path12:32:46.7 1/20/2014: Caching Snap Path12:32:46.7 1/20/2014: Caching Title Path12:32:46.7 1/20/2014: Caching Box Path12:32:46.7 1/20/2014: Caching Cart Path12:32:46.7 1/20/2014: Caching Background Path12:32:46.7 1/20/2014: Validating: Emulator_10: Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo GameCube\Snaps12:32:46.7 1/20/2014: Validating: Emulator_10: Control Panel Path: \\PlexMediaServer\Games\Emulation\Nintendo GameCube\Controls12:32:46.7 1/20/2014: Validating: Emulator_10: Database: [Console] Nintendo GameCube12:32:46.7 1/20/2014: Validating: Emulator_10: Title Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo GameCube\Titles12:32:46.7 1/20/2014: Validating: Emulator_10: Box Art Path: \\PlexMediaServer\Games\Emulation\Nintendo GameCube\Boxes12:32:46.7 1/20/2014: Validating: Emulator_10: Cart Art Path: \\PlexMediaServer\Games\Emulation\Nintendo GameCube\Cartridges12:32:46.7 1/20/2014: Validating: Emulator_10: Manual Path: \\PlexMediaServer\Games\Emulation\Nintendo GameCube\Manuals12:32:46.7 1/20/2014: Caching Video Snap Path12:32:46.7 1/20/2014: Caching Snap Path12:32:46.7 1/20/2014: Caching Title Path12:32:46.7 1/20/2014: Caching Box Path12:32:46.7 1/20/2014: Caching Cart Path12:32:46.7 1/20/2014: Validating: Emulator_11: Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\Snaps12:32:46.7 1/20/2014: Validating: Emulator_11: Background Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\Background12:32:46.7 1/20/2014: Validating: Emulator_11: Video Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\VideoSnaps12:32:46.7 1/20/2014: Warning: Emulator_11: Video Snap Path Does not exist12:32:46.7 1/20/2014: Validating: Emulator_11: Control Panel Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\Controls12:32:46.7 1/20/2014: Validating: Emulator_11: Database: [Console] Nintendo N6412:32:46.7 1/20/2014: Validating: Emulator_11: Title Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\Titles12:32:46.7 1/20/2014: Validating: Emulator_11: Box Art Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\Boxes12:32:46.7 1/20/2014: Validating: Emulator_11: Cart Art Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\Cartridges12:32:46.7 1/20/2014: Validating: Emulator_11: Manual Path: \\PlexMediaServer\Games\Emulation\Nintendo N64\Manuals12:32:46.7 1/20/2014: Caching Video Snap Path12:32:46.7 1/20/2014: Caching Snap Path12:32:46.7 1/20/2014: Caching Title Path12:32:46.7 1/20/2014: Caching Box Path12:32:46.7 1/20/2014: Caching Cart Path12:32:46.7 1/20/2014: Caching Background Path12:32:46.7 1/20/2014: Validating: Emulator_12: Snap Path: \\PlexMediaServer\Games\Emulation\NES\Snaps12:32:46.7 1/20/2014: Validating: Emulator_12: Control Panel Path: \\PlexMediaServer\Games\Emulation\Nintendo NES\Controls12:32:46.8 1/20/2014: Warning: Emulator_12: Control Panel Path Does not exist12:32:46.8 1/20/2014: Validating: Emulator_12: Database: [Console] Nintendo NES12:32:46.8 1/20/2014: Validating: Emulator_12: Title Snap Path: \\PlexMediaServer\Games\Emulation\NES\Titles12:32:46.8 1/20/2014: Validating: Emulator_12: Box Art Path: \\PlexMediaServer\Games\Emulation\NES\Boxes12:32:46.8 1/20/2014: Validating: Emulator_12: Cart Art Path: \\PlexMediaServer\Games\Emulation\NES\Cartridges12:32:46.8 1/20/2014: Validating: Emulator_12: Manual Path: \\PlexMediaServer\Games\Emulation\NES\Manuals12:32:46.8 1/20/2014: Caching Video Snap Path12:32:46.8 1/20/2014: Caching Snap Path12:32:46.8 1/20/2014: Caching Title Path12:32:46.8 1/20/2014: Caching Box Path12:32:46.8 1/20/2014: Caching Cart Path12:32:46.8 1/20/2014: Validating: Emulator_13: Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo SNES\Snaps12:32:46.8 1/20/2014: Validating: Emulator_13: Control Panel Path: \\PlexMediaServer\Games\Emulation\Nintendo SNES\Controls12:32:46.8 1/20/2014: Validating: Emulator_13: Database: [Console] Nintendo SNES12:32:46.8 1/20/2014: Validating: Emulator_13: Title Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo SNES\Titles12:32:46.8 1/20/2014: Validating: Emulator_13: Box Art Path: \\PlexMediaServer\Games\Emulation\Nintendo SNES\Boxes12:32:46.8 1/20/2014: Validating: Emulator_13: Cart Art Path: \\PlexMediaServer\Games\Emulation\Nintendo SNES\Cartridges12:32:46.8 1/20/2014: Validating: Emulator_13: Manual Path: \\PlexMediaServer\Games\Emulation\Nintendo SNES\Manuals12:32:46.8 1/20/2014: Caching Video Snap Path12:32:46.8 1/20/2014: Caching Snap Path12:32:46.8 1/20/2014: Caching Title Path12:32:46.8 1/20/2014: Caching Box Path12:32:46.8 1/20/2014: Caching Cart Path12:32:46.8 1/20/2014: Validating: Emulator_14: Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo Wii\Snaps12:32:46.8 1/20/2014: Validating: Emulator_14: Control Panel Path: \\PlexMediaServer\Games\Emulation\Nintendo Wii\Controls12:32:46.8 1/20/2014: Validating: Emulator_14: Database: [Console] Nintendo Wii12:32:46.8 1/20/2014: Validating: Emulator_14: Title Snap Path: \\PlexMediaServer\Games\Emulation\Nintendo Wii\Titles12:32:46.8 1/20/2014: Validating: Emulator_14: Box Art Path: \\PlexMediaServer\Games\Emulation\Nintendo Wii\Boxes12:32:46.8 1/20/2014: Validating: Emulator_14: Cart Art Path: \\PlexMediaServer\Games\Emulation\Nintendo Wii\Cartridges12:32:46.8 1/20/2014: Validating: Emulator_14: Manual Path: \\PlexMediaServer\Games\Emulation\Nintendo Wii\Manuals12:32:46.8 1/20/2014: Caching Video Snap Path12:32:46.8 1/20/2014: Caching Snap Path12:32:46.8 1/20/2014: Caching Title Path12:32:46.8 1/20/2014: Caching Box Path12:32:46.8 1/20/2014: Caching Cart Path12:32:46.8 1/20/2014: Validating: Emulator_15: Snap Path: \\PlexMediaServer\Games\Emulation\Sega 32X\Snaps12:32:46.8 1/20/2014: Validating: Emulator_15: Control Panel Path: \\PlexMediaServer\Games\Emulation\Sega 32X\Controls12:32:46.8 1/20/2014: Validating: Emulator_15: Database: [Console] Sega 32X12:32:46.8 1/20/2014: Validating: Emulator_15: Title Snap Path: \\PlexMediaServer\Games\Emulation\Sega 32X\Titles12:32:46.8 1/20/2014: Validating: Emulator_15: Box Art Path: \\PlexMediaServer\Games\Emulation\Sega 32X\Boxes12:32:46.8 1/20/2014: Validating: Emulator_15: Cart Art Path: \\PlexMediaServer\Games\Emulation\Sega 32X\Cartridges12:32:46.8 1/20/2014: Validating: Emulator_15: Manual Path: \\PlexMediaServer\Games\Emulation\Sega 32X\Manuals12:32:46.8 1/20/2014: Caching Video Snap Path12:32:46.8 1/20/2014: Caching Snap Path12:32:46.8 1/20/2014: Caching Title Path12:32:46.8 1/20/2014: Caching Box Path12:32:46.8 1/20/2014: Caching Cart Path12:32:46.8 1/20/2014: Validating: Emulator_16: Snap Path: \\PlexMediaServer\Games\Emulation\Sega Genesis CD\Snaps12:32:46.8 1/20/2014: Validating: Emulator_16: Control Panel Path: \\PlexMediaServer\Games\Emulation\Sega CD\Controls12:32:46.8 1/20/2014: Warning: Emulator_16: Control Panel Path Does not exist12:32:46.8 1/20/2014: Validating: Emulator_16: Database: [Console] Sega CD12:32:46.8 1/20/2014: Validating: Emulator_16: Title Snap Path: \\PlexMediaServer\Games\Emulation\Sega Genesis CD\Titles12:32:46.9 1/20/2014: Validating: Emulator_16: Box Art Path: \\PlexMediaServer\Games\Emulation\Sega Genesis CD\Boxes12:32:46.9 1/20/2014: Validating: Emulator_16: Cart Art Path: \\PlexMediaServer\Games\Emulation\Sega Genesis CD\Cartridges12:32:46.9 1/20/2014: Validating: Emulator_16: Manual Path: \\PlexMediaServer\Games\Emulation\Sega Genesis CD\Manuals12:32:46.9 1/20/2014: Caching Video Snap Path12:32:46.9 1/20/2014: Caching Snap Path12:32:46.9 1/20/2014: Caching Title Path12:32:46.9 1/20/2014: Caching Box Path12:32:46.9 1/20/2014: Caching Cart Path12:32:46.9 1/20/2014: Validating: Emulator_17: Snap Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Snaps12:32:46.9 1/20/2014: Validating: Emulator_17: Background Snap Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Background Snaps12:32:46.9 1/20/2014: Validating: Emulator_17: Video Snap Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Video Snaps12:32:46.9 1/20/2014: Validating: Emulator_17: Control Panel Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Controls12:32:46.9 1/20/2014: Validating: Emulator_17: Database: [Console] Sega Dreamcast12:32:46.9 1/20/2014: Validating: Emulator_17: Title Snap Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Titles12:32:46.9 1/20/2014: Validating: Emulator_17: Box Art Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Boxes12:32:46.9 1/20/2014: Validating: Emulator_17: Cart Art Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Cartridges12:32:46.9 1/20/2014: Validating: Emulator_17: Manual Path: \\PlexMediaServer\Games\Emulation\Sega Dreamcast\Manuals12:32:46.9 1/20/2014: Caching Video Snap Path12:32:46.9 1/20/2014: Caching Snap Path12:32:46.9 1/20/2014: Caching Title Path12:32:46.9 1/20/2014: Caching Box Path12:32:46.9 1/20/2014: Caching Cart Path12:32:46.9 1/20/2014: Caching Background Path12:32:46.9 1/20/2014: Validating: Emulator_18: Snap Path: \\PlexMediaServer\Games\Emulation\Sega Genesis\Snaps12:32:46.9 1/20/2014: Validating: Emulator_18: Control Panel Path: \\PlexMediaServer\Games\Emulation\Sega Genesis\Controls12:32:46.9 1/20/2014: Validating: Emulator_18: Database: [Console] Sega Genesis12:32:46.9 1/20/2014: Validating: Emulator_18: Title Snap Path: \\PlexMediaServer\Games\Emulation\Sega Genesis\Titles12:32:46.9 1/20/2014: Validating: Emulator_18: Box Art Path: \\PlexMediaServer\Games\Emulation\Sega Genesis\Boxes12:32:46.9 1/20/2014: Validating: Emulator_18: Cart Art Path: \\PlexMediaServer\Games\Emulation\Sega Genesis\Cartridges12:32:46.9 1/20/2014: Validating: Emulator_18: Manual Path: \\PlexMediaServer\Games\Emulation\Sega Genesis\Manuals12:32:46.9 1/20/2014: Caching Video Snap Path12:32:46.9 1/20/2014: Caching Snap Path12:32:46.9 1/20/2014: Caching Title Path12:32:46.9 1/20/2014: Caching Box Path12:32:46.9 1/20/2014: Caching Cart Path12:32:46.9 1/20/2014: Validating: Emulator_19: Snap Path: \\PlexMediaServer\Games\Emulation\Sega Master System\Snaps12:32:46.9 1/20/2014: Validating: Emulator_19: Control Panel Path: \\PlexMediaServer\Games\Emulation\Sega Master System\Controls12:32:46.9 1/20/2014: Validating: Emulator_19: Database: [Console] Sega Master System12:32:46.9 1/20/2014: Validating: Emulator_19: Title Snap Path: \\PlexMediaServer\Games\Emulation\Sega Master System\Titles12:32:46.9 1/20/2014: Validating: Emulator_19: Box Art Path: \\PlexMediaServer\Games\Emulation\Sega Master System\Boxes12:32:46.9 1/20/2014: Validating: Emulator_19: Cart Art Path: \\PlexMediaServer\Games\Emulation\Sega Master System\Cartridges12:32:46.9 1/20/2014: Validating: Emulator_19: Manual Path: \\PlexMediaServer\Games\Emulation\Sega Master System\Manuals12:32:46.9 1/20/2014: Caching Video Snap Path12:32:46.9 1/20/2014: Caching Snap Path12:32:46.9 1/20/2014: Caching Title Path12:32:46.9 1/20/2014: Caching Box Path12:32:46.9 1/20/2014: Caching Cart Path12:32:46.9 1/20/2014: Validating: Emulator_20: Snap Path: \\PlexMediaServer\Games\Emulation\Sega Saturn\Snaps12:32:47.0 1/20/2014: Validating: Emulator_20: Control Panel Path: \\PlexMediaServer\Games\Emulation\Sega Saturn\Controls12:32:47.0 1/20/2014: Validating: Emulator_20: Database: [Console] Sega Saturn12:32:47.0 1/20/2014: Validating: Emulator_20: Title Snap Path: \\PlexMediaServer\Games\Emulation\Sega Saturn\Titles12:32:47.0 1/20/2014: Validating: Emulator_20: Box Art Path: \\PlexMediaServer\Games\Emulation\Sega Saturn\Boxes12:32:47.0 1/20/2014: Validating: Emulator_20: Cart Art Path: \\PlexMediaServer\Games\Emulation\Sega Saturn\Cartridges12:32:47.0 1/20/2014: Validating: Emulator_20: Manual Path: \\PlexMediaServer\Games\Emulation\Sega Saturn\Manuals12:32:47.0 1/20/2014: Caching Video Snap Path12:32:47.0 1/20/2014: Caching Snap Path12:32:47.0 1/20/2014: Caching Title Path12:32:47.0 1/20/2014: Caching Box Path12:32:47.0 1/20/2014: Caching Cart Path12:32:47.0 1/20/2014: Validating: Emulator_21: Snap Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo\Snaps12:32:47.0 1/20/2014: Validating: Emulator_21: Control Panel Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo\Controls12:32:47.0 1/20/2014: Validating: Emulator_21: Database: [Console] SNK Neo Geo12:32:47.0 1/20/2014: Validating: Emulator_21: Title Snap Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo\Titles12:32:47.0 1/20/2014: Validating: Emulator_21: Box Art Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo\Boxes12:32:47.0 1/20/2014: Validating: Emulator_21: Cart Art Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo\Cartridges12:32:47.0 1/20/2014: Validating: Emulator_21: Manual Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo\Manuals12:32:47.0 1/20/2014: Caching Video Snap Path12:32:47.0 1/20/2014: Caching Snap Path12:32:47.0 1/20/2014: Caching Title Path12:32:47.0 1/20/2014: Caching Box Path12:32:47.0 1/20/2014: Caching Cart Path12:32:47.0 1/20/2014: Validating: Emulator_22: Snap Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo CD\Snaps12:32:47.0 1/20/2014: Validating: Emulator_22: Control Panel Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo CD\Controls12:32:47.0 1/20/2014: Validating: Emulator_22: Database: [Console] SNK Neo Geo CD12:32:47.0 1/20/2014: Validating: Emulator_22: Title Snap Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo CD\Titles12:32:47.0 1/20/2014: Validating: Emulator_22: Box Art Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo CD\Boxes12:32:47.0 1/20/2014: Validating: Emulator_22: Cart Art Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo CD\Cartridges12:32:47.0 1/20/2014: Validating: Emulator_22: Manual Path: \\PlexMediaServer\Games\Emulation\SNK Neo Geo CD\Manuals12:32:47.0 1/20/2014: Caching Video Snap Path12:32:47.0 1/20/2014: Caching Snap Path12:32:47.0 1/20/2014: Caching Title Path12:32:47.0 1/20/2014: Caching Box Path12:32:47.0 1/20/2014: Caching Cart Path12:32:47.0 1/20/2014: Validating: Emulator_23: Snap Path: \\PlexMediaServer\Games\Emulation\Sony Playstation 2\Snaps12:32:47.0 1/20/2014: Validating: Emulator_23: Control Panel Path: \\PlexMediaServer\Games\Emulation\Sony Playstation 2\Controls12:32:47.0 1/20/2014: Validating: Emulator_23: Database: [Console] Sony PlayStation 212:32:47.0 1/20/2014: Validating: Emulator_23: Title Snap Path: \\PlexMediaServer\Games\Emulation\Sony Playstation 2\Titles12:32:47.0 1/20/2014: Validating: Emulator_23: Box Art Path: \\PlexMediaServer\Games\Emulation\Sony Playstation 2\Boxes12:32:47.0 1/20/2014: Validating: Emulator_23: Cart Art Path: \\PlexMediaServer\Games\Emulation\Sony Playstation 2\Cartridges12:32:47.1 1/20/2014: Validating: Emulator_23: Manual Path: \\PlexMediaServer\Games\Emulation\Sony Playstation 2\Manuals12:32:47.1 1/20/2014: Warning: Emulator_23: MAPFile Does Not Exist12:32:47.1 1/20/2014: Caching Video Snap Path12:32:47.1 1/20/2014: Caching Snap Path12:32:47.1 1/20/2014: Caching Title Path12:32:47.1 1/20/2014: Caching Box Path12:32:47.1 1/20/2014: Caching Cart Path12:32:47.1 1/20/2014: Validating: Emulator_24: Snap Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\Snaps12:32:47.1 1/20/2014: Validating: Emulator_24: Background Snap Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\Background12:32:47.1 1/20/2014: Validating: Emulator_24: Video Snap Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\VideoSnaps12:32:47.1 1/20/2014: Validating: Emulator_24: Control Panel Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\Controls12:32:47.1 1/20/2014: Validating: Emulator_24: Database: [Handheld] Atari Lynx12:32:47.1 1/20/2014: Validating: Emulator_24: Title Snap Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\Titles12:32:47.1 1/20/2014: Validating: Emulator_24: Box Art Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\Boxes12:32:47.1 1/20/2014: Validating: Emulator_24: Cart Art Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\Cartridges12:32:47.1 1/20/2014: Validating: Emulator_24: Manual Path: \\PlexMediaServer\Games\Emulation\Atari Lynx\Manuals12:32:47.1 1/20/2014: Caching Video Snap Path12:32:47.1 1/20/2014: Caching Snap Path12:32:47.1 1/20/2014: Caching Title Path12:32:47.1 1/20/2014: Caching Box Path12:32:47.1 1/20/2014: Caching Cart Path12:32:47.1 1/20/2014: Caching Background Path12:32:47.1 1/20/2014: Validating: Emulator_25: Snap Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\Snaps12:32:47.1 1/20/2014: Validating: Emulator_25: Background Snap Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\Background12:32:47.1 1/20/2014: Validating: Emulator_25: Video Snap Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\VideoSnaps12:32:47.1 1/20/2014: Validating: Emulator_25: Control Panel Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\Controls12:32:47.1 1/20/2014: Validating: Emulator_25: Database: [Handheld] Bandai WonderSwan Color12:32:47.1 1/20/2014: Validating: Emulator_25: Title Snap Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\Titles12:32:47.1 1/20/2014: Validating: Emulator_25: Box Art Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\Boxes12:32:47.1 1/20/2014: Validating: Emulator_25: Cart Art Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\Cartridges12:32:47.1 1/20/2014: Validating: Emulator_25: Manual Path: \\PlexMediaServer\Games\Emulation\Bandai WonderSwan Color\Manuals12:32:47.1 1/20/2014: Caching Video Snap Path12:32:47.1 1/20/2014: Caching Snap Path12:32:47.1 1/20/2014: Caching Title Path12:32:47.1 1/20/2014: Caching Box Path12:32:47.1 1/20/2014: Caching Cart Path12:32:47.1 1/20/2014: Caching Background Path12:32:47.1 1/20/2014: Restoring Emulator from Cache: 212:32:47.2 1/20/2014: Restoring Emulator Database From Cache: 212:32:47.2 1/20/2014: Restoring Emulator from Cache: 312:32:47.2 1/20/2014: Restoring Emulator Database From Cache: 312:32:47.3 1/20/2014: Restoring Emulator from Cache: 412:32:47.3 1/20/2014: Restoring Emulator Database From Cache: 412:32:47.3 1/20/2014: Restoring Emulator from Cache: 512:32:47.3 1/20/2014: Restoring Emulator Database From Cache: 512:32:47.4 1/20/2014: Restoring Emulator from Cache: 612:32:47.4 1/20/2014: Restoring Emulator Database From Cache: 612:32:47.5 1/20/2014: Restoring Emulator Database From Cache: 912:32:47.6 1/20/2014: Restoring Emulator from Cache: 1112:32:47.6 1/20/2014: Restoring Emulator Database From Cache: 1112:32:47.6 1/20/2014: Restoring Emulator from Cache: 1212:32:47.7 1/20/2014: Restoring Emulator Database From Cache: 1212:32:47.7 1/20/2014: Restoring Emulator from Cache: 1312:32:47.8 1/20/2014: Restoring Emulator Database From Cache: 1312:32:48.1 1/20/2014: Restoring Emulator from Cache: 1712:32:48.1 1/20/2014: No Database Data: 1712:32:48.1 1/20/2014: Restoring Emulator from Cache: 1812:32:48.1 1/20/2014: Restoring Emulator Database From Cache: 1812:32:48.2 1/20/2014: Restoring Emulator from Cache: 1912:32:48.2 1/20/2014: Restoring Emulator Database From Cache: 1912:32:48.3 1/20/2014: Restoring Emulator from Cache: 2112:32:48.3 1/20/2014: Restoring Emulator Database From Cache: 2112:32:48.4 1/20/2014: Restoring Emulator from Cache: 2412:32:48.4 1/20/2014: Restoring Emulator Database From Cache: 2412:32:48.4 1/20/2014: Restoring Emulator from Cache: 2512:32:48.4 1/20/2014: Restoring Emulator Database From Cache: 2512:35:23.3 1/20/2014: Mouse Input is disabled12:36:14.2 1/20/2014: Exiting GameEx!12:36:14.2 1/20/2014: Disposing all videos12:36:14.2 1/20/2014: Deleting temporary Karaoke videos12:36:14.2 1/20/2014: Disposing Image List12:36:14.2 1/20/2014: Disposing Fonts12:36:14.2 1/20/2014: Disposing Surfaces12:36:14.3 1/20/2014: Saving Settings12:36:14.3 1/20/2014: Shutting down Bass12:36:14.3 1/20/2014: Closing HideOS.exe12:36:14.3 1/20/2014: Disposing Plugins12:36:14.3 1/20/2014: Disposing Plugins12:36:14.3 1/20/2014: Closing database connection12:36:14.3 1/20/2014: Checking for applications to Launch On Exit12:36:14.3 1/20/2014: Media Center was not open when starting GameEx, so not launching12:36:14.4 1/20/2014: ByeRunLastGame not included because I'm not getting that far.Troubleshooting with Run Last Game not processed because I'm not getting that far.System:Windows 7, 64 bit, 32GB RAM, >1TB of drive space available on E:Registered copy of GameEx.Situation:First, to repeat, this is NOT MAME. I'm not looking for the Update List menu item. This is for the TurboGrafx-16 using the MagicEngine emulator. The emulator is fully functional outside of GameEx. However, inside GameEx I am not able to view all of the ROMs which I have. For instance, my list inside of GameEx begins with Air Zonk. In my ROMs directory there are 44 ROMs prior to Air Zonk alphabetically, 13 unique. Originally, the ROMs were GoodRenamed and GoodMerged but during my troubleshooting I have undone that operation, leaving 1,565 ROMs in the directory (with GameEx listing 94; not sure how many that includes when extended to over dumps, etc). Other emulators on my system appear to be functioning fine, without any of the inherent problems the TG16 is having.I would appreciate any advice or direction on how to proceed in order to resolve this issue.Thank you in advance for your time. Link to comment Share on other sites More sharing options...
Talonius Posted January 20, 2014 Author Share Posted January 20, 2014 Link to comment Share on other sites More sharing options...
nullPointer Posted January 20, 2014 Share Posted January 20, 2014 Just to be sure, you mentioned that you originally had your games GoodMerged, but then undid the operation correct? So at this point each individual ROM is either in its own .zip or is just hanging out there on its own (like with a .pce extension or whatever)?If that’s the case you’ll probably want to change the Zip/7-Zip/GoodMerge/RAR setting from Yes to No (It’s listed as GamesIn7Zips=True in your Emulator Config). That may have an impact. You may also want to have a play with setting up a ROM filter (possibly setting it to *.pce or whatever your ROM extension is).You could also probably change the Scan Sub Folders setting (listed as RomsInFolders=True in your Emu Config) from Yes to No unless you actually need it. Does each ROM have it's own directory by any chance? If not you won't need that setting.Lastly the Merge Sets setting (listed as MergeSets=True in your Emu config) may be playing a role here. If you want all your ROMs to appear in a single flattened list you'll want to change that to false. Otherwise GameEx will start grouping ROMs by country and version into a sub-menu structure. I really like grouping in this fashion, but not everyone does.Try the above settings first to see whether they have an impact. If that doesn't work we'll proceed to the next step. 1 Link to comment Share on other sites More sharing options...
Talonius Posted January 21, 2014 Author Share Posted January 21, 2014 Just to be sure, you mentioned that you originally had your games GoodMerged, but then undid the operation correct? So at this point each individual ROM is either in its own .zip or is just hanging out there on its own (like with a .pce extension or whatever)?If that’s the case you’ll probably want to change the Zip/7-Zip/GoodMerge/RAR setting from Yes to No (It’s listed as GamesIn7Zips=True in your Emulator Config). That may have an impact. You may also want to have a play with setting up a ROM filter (possibly setting it to *.pce or whatever your ROM extension is).You could also probably change the Scan Sub Folders setting (listed as RomsInFolders=True in your Emu Config) from Yes to No unless you actually need it. Does each ROM have it's own directory by any chance? If not you won't need that setting.Lastly the Merge Sets setting (listed as MergeSets=True in your Emu config) may be playing a role here. If you want all your ROMs to appear in a single flattened list you'll want to change that to false. Otherwise GameEx will start grouping ROMs by country and version into a sub-menu structure. I really like grouping in this fashion, but not everyone does.Try the above settings first to see whether they have an impact. If that doesn't work we'll proceed to the next step.Thanks for the reply! GamesIn7Zips has been disabled, as well as MergeSets and RomsInFolders. The ROMs are dumped into one large directory right now, all PCE files. Still missing the ROMs, unfortunately.Here's another strange thing which is probably related: when I go to play a game which was presumed working (and have Debug turned on for the emulator) it's passing a Zip file to MagicEngine rather than a PCE -- when there are no Zip files in that directory now.EDIT: Also, I moved the ROMs to a local path rather than a mapped network drive so this caching - whatever it is - has withstood a complete move of the library.EDIT 2: I deleted the emulator and re-added it; no impact. I added a ROM filter to see if that would jar it into reinitalizing; no impact.Again, thanks for any help. Link to comment Share on other sites More sharing options...
DazzleHP Posted January 21, 2014 Share Posted January 21, 2014 May we have a copy of your latest log and GameEx.ini (after your recent changes) it's passing a Zip file to MagicEngine rather than a PCE -- when there are no Zip files in that directory now. I added a ROM filter to see if that would jar it into reinitalizing; no impact. Thanks Link to comment Share on other sites More sharing options...
Talonius Posted January 22, 2014 Author Share Posted January 22, 2014 I'm a dumbass.When I first set the ROMs directory up, I created ..\NEC TurboGrafx-16.For some reason later I changed it to ..\NEC TurboGrafx.I _thought_ I changed GameEx to point to the new directory but I hadn't. It's odd that GameEx would continue to show me the cached contents of a directory that didn't exist, but I'm not complaining.Once I changed the directories I was good.Sorry to have wasted your time. (sigh) 1 Link to comment Share on other sites More sharing options...
slavearm Posted January 22, 2014 Share Posted January 22, 2014 Happens to the best of us sir! Link to comment Share on other sites More sharing options...
Adultery Posted January 22, 2014 Share Posted January 22, 2014 I'd totally rather hang around with a dumbass as opposed to a smartass! Glad you got it sorted! Marking as [RESOLVED]! Link to comment Share on other sites More sharing options...
Tempest Posted January 22, 2014 Share Posted January 22, 2014 I take offense to that! Link to comment Share on other sites More sharing options...
