Witse Posted January 18, 2014 Share Posted January 18, 2014 Hi EveryoneI have been having a few problems getting PinballX running but I'm glad to say that I am almost there I have come across what I think is the last hurdle which is proving to be a hard nut to crack.When I load a table in PinballX / Visual Pinball the DMD loads on the second screen but is then hidden behind the backglass image. I am able to get the DMD to the front by alt / tab, However the DMD will not remain in that position after I close and reopen the table.I have tried moving the DMD after bringing it to the front then clicking on the playfield and then back on the DMD before closing the table as suggested in another post but that did not work either.Please if anyone has any ideas on how I could approach the issue your input would be greatly appreciated.Kind regardsWitse Link to comment Share on other sites More sharing options...
zeenon Posted January 18, 2014 Share Posted January 18, 2014 Check some of the tips in post #14:http://www.gameex.info/forums/topic/13815-backglass-wont-load-with-table/Z Link to comment Share on other sites More sharing options...
Witse Posted January 18, 2014 Author Share Posted January 18, 2014 Hi againI had the problem with the DMD not staying in the place I left it but that issue has been solved.My screens are configured the correct way round with the playfield as display 1 to the left of the backglass which is set to display 2.I have the latest Pinmame cab software downloaded yesterday from VPforums.I have used game manager to unhide the DMD and Backglass in all tables.I have both exe files to run as admin.I just don't know what to try next.From what I can tell the DMD loads first, as it's the first thing I see on any screens when Visual Pinball starts. Then the backglass appears covering over the DMD image and hiding it from view. One press of f3 returns the DMD to the correct position but after exiting the table it does not save in this position. The next time you load the table the same thing occurs.Can anyone suggest a method of delaying the DMD from loading until the backglass has appeared? This is the only thing I can think of that I have not tried That's for taking the time to read my post.If anyone has any ideas please let me know as I'm desperate to have this working correctly before I can finish my cabinet.Kind regardsWitse Link to comment Share on other sites More sharing options...
Censored Posted January 18, 2014 Share Posted January 18, 2014 Do you run PinballX as admin?What backglasses do you use? b2s, uvp or other?Do you use that special Cab Version of vpinmame?please post your pinballx.ini and log.txtYou can also try this ahk script (launch it before starting PinballX):https://www.dropbox.com/s/q6g55go3onm369d/VpmToFront.rar Link to comment Share on other sites More sharing options...
Witse Posted January 18, 2014 Author Share Posted January 18, 2014 HiyaThat script u link to I have already tried. It makes the dmd appear but the backglass disappears?Everything running as admin.I use db2s backglasses now but this happens with uvp too. I can't post the script now but will try to later The version of pinmame I use is marked as the cabinet version. Link to comment Share on other sites More sharing options...
Censored Posted January 18, 2014 Share Posted January 18, 2014 Can´t imagine that it would help, but try disabling (hide) the b2s DMD in the b2s settings and set the "normal" DMD to visible.also set "DMD enabled" to no in the PinballX settings (because of the 2 screen setup) Link to comment Share on other sites More sharing options...
Witse Posted January 19, 2014 Author Share Posted January 19, 2014 Thanks for all suggestions but I'm gonna link f3 to a button on the front of the cab for now!That seems to be a good enough fix for now! Link to comment Share on other sites More sharing options...
zeenon Posted January 24, 2014 Share Posted January 24, 2014 For the folks having issue with the DMD behind the BG can you try the beta version of VP 9.2.1 posted here:http://www.vpforums.org/index.php?showtopic=26693&hl=Z Link to comment Share on other sites More sharing options...
Witse Posted January 29, 2014 Author Share Posted January 29, 2014 The fix was to change the visual pinball .exe to run in NT compatibility modeAll works perfect now!!!! 1 Link to comment Share on other sites More sharing options...
