How easy is it to do the following
- add Neo Geo & Players Choice & Megatech under Mame on the main screen
- take out all the emulators and list them also under mame (instead of going to emulation all the time)
Ta
B
I would say that the easiest way to accomplish what you would describe would be to delve into the world of custom menus (although depending on your goal you may not be able to configure it precisely as you envision, you should be able to get a close approximation). DazzleHP wrote a really nice guide on the subject which can be found in the link.
