Project Tempest - Jag Emulator
Beaps73
I use a wrapper I found here on GameEx called PTLauncher. I put the executable in my Project Tempest folder. The command line is simple...
ptlauncher.exe "[ROMPATH]\[ROMFILE]"
In the Launch After portion of the Advanced Emulator Setup, I run a batch file called EndPT.bat which is also located in my Project Tempest folder and contains these lines:
taskkill /IM ptlauncher.exe /T /F
taskkill /IM pt.exe /T /F
Hope this helps. Works great for me and plays Jaguar games much better than Virtual Jaguar and t2k. I own an Atari Jaguar just so that I can play Jeff Minter's masterpiece Tempest 2000. It plays perfectly under GameEx and Project Tempest :-)
Scott
Link to comment
Share on other sites
