First, appologies if this is not an appropriate place for this, but over on the HTPC forums people glaze over when I mention wantint to control my TV from my PC, rather than just remote controlling my PC...
My mame cabinet has a 27" Television as the "Monitor". Problem with this is the power button and remote IR eye are covered when the bezel is in place making turning on/off the tv a pain in the rear.
I have the IR Blaster hardware that I know will control this television, however, I do not want to install Beyond TV (the only software I have found that will work with this device)
What I am searching for is a piece of software that will allow me to take keyboard keystrokes and convert them to IR to control the television. Has anyone done this?
I would have thought yourll get more help on that forum, but Im assuming you've looked at "Girder"? I don't know much about it other than its supposed to do this kind of stuff.
You could also solder two wires, (one on each side of the power switch on the TV circuit board) and wire it to a momentary switch on the outside of your arcade machine. That's what I did and it works well if you are handy with a soldering iron. (Even if you're not it's still pretty simple to do and nice looking) Of course that's a hardware not software solution but whatever you want.
