Hi, I'm absolutely loving GameEx but have a couple of questions that I'd appreciate some help with :)
I control all my emulators and the front-end with a PS1 pad hooked up to a USB adaptor. Is it possible to map Select+Start (for example) to close Fusion and return to GameEx? Currently I have to go across to the keyboard under my TV and hit Escape and it'd be really cool if I didn't have to get up from my bed :)
Also another minor annoyance with Fusion. When I launch a Genesis game from GameEx, the screen goes black, but I hear sound. When I press Alt+Enter it looks fine. Any idea what's causing this, so I can launch straight into working full screen?
Cheers for your help :)
EDIT: Actually, just typing that out made it insanely obvious. I've set-up Joy2Key, and realised that FullScreen was set to 0 in Fusion's ini. D'oh!
Sorry for wasting your time :unsure:
Instead of using Joy2Key, you can setup one of GameEx's advanced emulator configs to exit when you press a certain button combination. I use this for all the emulators that I setup and it works well.
