this plugin looks brill but struggling to get it working. have leds wired u in cab. mixture of led strips and function buttons at bottom of bezel. trying to set up, but can only get one button/fed to activate. pics:
in example above, f1 always lights, but if i chose "always active" for any others they dont light.
however i know plugin feeding uttons properly b/c attract and animations lighting all buttons.
is there any help/guide for this plugin? for e.g. what's "state"?
can ne1 advise ; this looks amazing if i could only get it working
Under 'LED Input Map' your Id should all be 1 and you should be setting "Single" to 1..n LED's. Plus you don't have any keycodes assigned to your inputs. Check out the screenshot for an example.
Many thanks Headkaze. :D
Do you have to have keycodes set to each input? It's just that not all of my leds are buttons/keys - some are led strips + other decals
thanks for a great plugin
You should set them to your MAME keys. That is used for mapping the LED's in MAME only.
