Overall I've had no problems setting up PinballX to work with Future Pinball and Visual Pinball, but I'm having a strange issue with PinballFX2.
When you choose a table, PinballFX2 loads, but PinballX quits - so when you finish playing and exit PinballFX2 you're back at the desktop again.
Has anybody else seen this sort of behaviour?
  • 6 months later...
I have the same issue.
The last two days i search in this forum for some help, but i can't find something similar. My Pc is now at my parents, but today i installed pinball x and pinball fx2 on my macbook with vmware to see if there is the same issue. On my macbook it works fine, i can load tables and exit those again back to pinball x.
I try to upload my ini file in the next days, but maybe someone can help me.
I also updated pinball x a few days ago, but i didn´t update the shark codecs.
If i can´t get it work, what is the best way to reinstall pinball x without loosing all the table files and settings...
Many thanks in advance and i hope someone can help me.
ok, i think i found a solution. i changed the setting back to default in my nvidia panel... Now it works just fine...
