I have been looking for a long time for something like this that works with xbmc. So first, thanks for the work.
I am using a rental. It plays on a slingplayer stand alone app.
So my question is how can I enter the information I entered into the slingplayer app into slingfront?
I can't seem to find it. Any help would be great.
On my slingplayer, under connect, I can choose by ip. Enter the ip address and port number. Enter the alias and password.
Can I not do that in slingfront?
Treat SlingFront the same as the web player.
I.e. you sign into it with your Sling account and it shows all the Slingboxes in your directory.
You can't currently connect directly with an IP address but presumably your Slingbox shows up in your directory and if not you can probably add it via your account page at Sling?
