I recently upgraded to the latest version of GameEx and have enabled the feature to start the jukebox playing when GameEx is started. I've picked a playlist that I've created in media player, but GameEx is just selecting a track at random to play from my entire list of MP3 files within media player. Any ideas?
Thanks,
Thanks,
Have you got the Jukebox set to Media Player mode (rather than tags)? What happens when you go into the Jukebox and select that playlist, does it play it?
Yup, Jukebox is set to media player mode and if I select the playlist it plays fine...
OK, sounds like something I need to fix in the code then (ie bug). Probably be fixed for next release (in about a week).
Cheers.
Tom,
Don't know if this is just something with my set up but with the latest version I'm now not getting the jukebox to start up at all when selecting to enable the feature. It works fine if I select it once I'm in GameEx but nothing plays on startup.
