Tom,
Something changed in 169 that was not there in 162, 165, and 167 (I didn't try 168, but I can if needed). If I position the DMD on the BG and resize it, exit out of the table, and go back in.....the DMD is reset to the default position (top right on a cab) every time. I can reproduce this 100% with version 169, but with the older versions the DMD stays where it is put every time.
I thought it was a pinmame.dll or vpinball.exe so I tried older versions of those and had the same issue. I was about ready to give up, then said let me try my old reliable 165, worked every time.....soon as I used 169 it would reset the DMD to default.
Z
Just some additional info, 168 and 169 both reset the DMD position. I've been running 167 and have had no issues.
Z
Fixed thanks Tom. (I posted my reply in imagamejunky's thread, but I'll cross post here in case you missed it) I used the last zip file in his thread if it makes a difference.
Z
