I put a little ledgend in the bottom left corner of my backgrounds, as I don't have any instructions on my cab:
Here's the PSD if you want to play:
bak2.zip
Fits nicely on a 1280x1024 screen without interfereing with any menus, etc.
Top instuctions.
Have you got a program or something similar which you made this from.
I would like to use yours but i need to change the button layouts,if it would be alright with you.
Thanks.
This was just done in photoshop, the .psd file has all the buttons on different layers, so you can move them around.
Just put in a background layer, and you're set.
Images were grabbed from the theme designer, and I blurred the little black man out to make the white button. You could turn the white button any colour you want with a filter...
