I'm getting 425 Can't Open Data Connection errors, then its switches to passive mode. It was fine when I downloaded some scripts. Then it started on some backglasses successfully and just started failing. I didn't specify a port, should I? Its currently failing on some of the Future Pinball backglasses.
Status: Connected
Status: Retrieving directory listing...
Command: CWD /
Response: 250 CWD successful. "/" is current directory.
Command: PWD
Response: 257 "/" is current directory.
Command: TYPE I
Response: 200 Type set to I
Command: PASV
Response: 227 Entering Passive Mode (50,7,38,59,216,175)
Command: MLSD
Response: 425 Can't open data connection.
Error: Failed to retrieve directory listing
