fwiler Posted October 24, 2013 Share Posted October 24, 2013 Hello, I tried doing a search but didn't know the correct verbage for my question.I have everything working as I like except one thing.After selecting a game to launch (only using MAME), it shows the controls for the game for about 5 seconds before continuing on.I would like to disable this if possible. Running 13.18Thank you, Link to comment Share on other sites More sharing options...
nullPointer Posted October 24, 2013 Share Posted October 24, 2013 Hi fwiler and welcome to the GameEx forums!When reporting an issue please attach a copy of your GameEx.ini and/or a copy of your GameEx log after having experienced the problem (in this case a copy of your GameEx.ini would probably be enough). This will help us determine the cause of the problem. Please refer to this thread for further details. Thanks man! Link to comment Share on other sites More sharing options...
Tempest Posted October 24, 2013 Share Posted October 24, 2013 Enable / Disable features >>> Enable panel viewer >>> No Link to comment Share on other sites More sharing options...
