1.66 includes Pin Cab compatible MAME database of 11 games. These games are compatible with normal pin cab controls using both flippers and 1 button.
Upscaled 1080p table videos and other media is on the FTP.
To set up MAME as a custom system: You should make sure MAME is setup correctly in MAME.ini. Arguments should simply be [TABLEFILE]. The table folder should be any folder where your MAME roms are NOT. Its a dummy setting and should not point to your roms. Working path is the folder where MAME is installed and the executable is simply your MAME.exe file. I recommend using MAME Plus and using the upscaling features.
