[RESOLVED] Error in GameEx setup when choosing theme...
I am running GameEx v13.18. When running the Setup Wizard, I get the following error when I get to the screen to pick my default theme: (please see the first attached image). When I click on the details button in the error prompt, here is what it lists: (please see text just below my signature). I have attached my GameEx.ini file and my log.txt file and can send any other files necessary to figure this out. I did uninstall and reinstall GameEx but nothing changed... I still get the error.
Many Thanks in advance!
Scott
  Reveal hidden contents
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Parameter is not valid.
at System.Drawing.Bitmap..ctor(String filename)
at SetupWizard.ThemeSelector..ctor(Int32 top)
at SetupWizard.XmlSection.ShowSettings(Int32 top)
at SetupWizard.XmlSectionArray.ShowSection()
at SetupWizard.XmlSectionArray.GoToPreviousSection()
at SetupWizard.frmMain.butBack_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripButton.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5472 (Win7SP1GDR.050727-5400)
SetupWizard
Assembly Version: 1.0.4967.17013
Win32 Version: 1.0.4967.17013
Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
System
Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
System.Drawing
System.Xml
Win32 Version: 2.0.50727.5476 (Win7SP1GDR.050727-5400)
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
post-23474-0-41836400-1381641876_thumb.p
GameEx.ini
