Each time I start to play a table, and as soon as the ball enters the chute my pc starts to make a terrible NOISE until the ball is released, this occurs on 80% of my tables, is this a programming fault or something in the setup?.Regards
Are you launching the table through the frontend?
Have you tried launching directly from Future Pinball/BAM Launcher and checking if the noise is still there?
Im thinking this is not frontend (PinballX) related at all
I had this exact issue and I recieved a response on another set of forums. The issue for me was I did not have VSync turned on in Future Pinball.
If you start Future Pinball and then go to "Preferences", "Video Rendering" and make sure VSync is checked. This fixed the issue for me and I was in the same position as you. Hopefully iy works for you as well.
