Subscript out of range line 230 AnPlNewPos
So out of 200 tables I've seen this problem maybe twice and Koadic's 2nd suggestion has fixed it previously:
http://www.vpforums.org/index.php?showtopic=24521&hl=%2Banalog+%2Bplunger+%2Bscript+%2Berrors
The odd part is the tables works fine outside of PBX....why would PBX cause the issue??
So now I load up the new Ripley's, and the first thing that shows on the DMD is.....4 Balls Missing with a countdown from 20, then the table seems to hang. Alt -Tab and I see it's because of the subscript error above, but copying the code as before, does not fix it this time. Loading Ripley's outside of PBX and it works fine. I'm going to xpost this to the VPF forums also. Vpinball rev677 and PBX 1.64.
Z
