Hi,
Could I please ask for some help from PinDMD 2 users?
Please try the attached and let me know if it works.
It should render a small scrolling message to a window and your PinDMD.
Ensure you run on a machine with PinballX installed as that will have the file dependencies.
Cheers.
Tom.
Demo.7z
tom test tom the quick brown fox jumped over something also has "16/15" in upper left corner message scrolls in center right to left and not using full width on dmd
Didn't notice fading, flickering maybe...no longer at location of a cab but can check tonight. But I'm sure someone else will report by then! :)
What do you have planned Tom? Maybe table descriptions on the dmd while scrolling through tables? Awesome
This is awesome Tom!!!! I may have to donate again, PBX is getting better and better!!!
Z
Oh no - that's a shame - there are around 100 of us :(
I haven't completely made up my mind on it but I may be releasing some source code (for the DMD API), so someone else could add support.
I haven't completely made up my mind on it but I may be releasing some source code (for the DMD API), so someone else could add suopport.
Thanks for considering :)
