Hi,
Hoping someone else has encountered this issue:
When I load up PinballX, it seems to start up fine, and will load a table, and backglass fine (video, or graphic depending on the table).
When I rotate the wheel of tables it doesn't load the new backglass and table video for the selected table.
If I load a table, and then exit the table the UI will show the correct table and backglass video, it just doesn't flip through the tables. It will only show the first one it started with.
I am using the following:
Windows XP SP3 (32bit),
NVidia GTX 780
i7 3930K 4GB RAM
Thanks for any assistance.
I am using CCCP.
Like I said what ever board is loaded it will play the video.
Example:
PinballX starts game that was displayed is High Speed. It plays the table video and the backglass. I start rotating the wheel the video stops (with flicker like it's going to change, but does nothing).
I select Lord of the Rings. I start LotR, and play it fine. I exit LotR back to PinballX and the Video and backglass will now be on LotR playing fine.
I can play all the videos from the desktop with no issues as well. All the videos will play if I start the board and exit the game the correct video will be playing.
Oh I am running 1.6.1 as well. The lastest version of PinballX.
Thanks.
Spot on....
I reinstall the CCCP codecs and now everything is working perfectly. I guess something must have become hosed some how.
Thanks for the great support.
