Hey all, Im trying to run gameex with win 98se and it wont load. Im using the newest vision of gameex. It has something to do with the fonts but I dont know how to fix it. If you can help - thanks
Rayman - here is my log
11:06:29.8 3/18/2006: GameEx: Version 5.73: Starting Log
11:06:30.0 3/18/2006: Operating System Platform: Win32Windows
11:06:30.0 3/18/2006: Operating System Name: Windows 98
11:06:30.0 3/18/2006: Operating System Version: 4.10.67766446
11:06:30.0 3/18/2006: Checking for versions of .net Framework installed
11:06:30.0 3/18/2006: .net Framework 1.1 Installed
11:06:30.0 3/18/2006: Checking Registration
11:06:30.0 3/18/2006: Running Randomize()
11:06:30.0 3/18/2006: Initialising Video/MNG DLL's
11:06:30.3 3/18/2006: Running Misc startup tasks
11:06:30.3 3/18/2006: Setting Menu types
11:06:30.3 3/18/2006: Opening Configuration File
11:06:30.3 3/18/2006: Getting Configuration Values
11:06:30.4 3/18/2006: Using Theme: Default - Default
11:06:30.4 3/18/2006: Checking for alternate Image Directory for Theme: Default - Default
11:06:30.4 3/18/2006: Text/Language: English
11:06:30.4 3/18/2006: Applying Language/Text
11:06:30.5 3/18/2006: Creating Scancodes.txt (List of DirectInput scan codes)
11:06:30.6 3/18/2006: Snap Delay set to: 1
11:06:30.6 3/18/2006: Is Media Center running?
11:06:30.6 3/18/2006: Check Media Center Exit/Start Mode
11:06:30.6 3/18/2006: Media Center Mode 2
11:06:30.6 3/18/2006: Checking for applications to Launch On Startup
11:06:30.6 3/18/2006: Get other settings
11:06:30.6 3/18/2006: Using 2D Animations
11:06:30.7 3/18/2006: Set: Find emulator artwork on best match basis
11:06:30.7 3/18/2006: Launching HideOS.exe
11:06:31.3 3/18/2006: Hiding Taskbar
11:06:31.3 3/18/2006: Start work for Form
11:06:31.3 3/18/2006: Getting Original Screen Size
11:06:31.4 3/18/2006: Loading ICON
11:06:31.5 3/18/2006: Initializing Component
11:06:31.9 3/18/2006: Initialising Bass Audio Library
11:06:32.2 3/18/2006: Loading default loading screen
11:06:32.4 3/18/2006: Using General Font: Trebuchet MS
11:06:32.4 3/18/2006: Using Title Font: Trebuchet MS
11:06:32.4 3/18/2006: Initialising DirectDraw
11:06:32.6 3/18/2006: Creating DirectDraw Device
11:06:34.9 3/18/2006: Setting Resolution to 800x600 32 bit color
11:06:34.9 3/18/2006: Creating DirectDraw Surfaces
11:06:34.9 3/18/2006: Creating Primary Surface - Full Screen Mode
11:06:35.8 3/18/2006: Creating Back Buffer
11:06:36.0 3/18/2006: Loading graphic surfaces
11:06:36.1 3/18/2006: Creating Surfaces Misc and Dialogs
11:06:36.4 3/18/2006: Creating Surface Volume
11:06:36.4 3/18/2006: Creating Surfaces Arrows
11:06:36.4 3/18/2006: Creating Surfaces GameEXlogo Text
11:06:36.4 3/18/2006: Creating Surfaces Toolbar
11:06:36.5 3/18/2006: Creating Surfaces Backgrounds
11:06:38.8 3/18/2006: Creating Surfaces Toolbar Controls
11:06:38.8 3/18/2006: Creating Surfaces GameEx Logo
11:06:38.9 3/18/2006: Creating Surfaces Home & Exit
11:06:38.9 3/18/2006: Creating Surfaces Snaps
11:06:38.9 3/18/2006: Creating Surfaces Menu and List Bars
11:06:39.2 3/18/2006: Creating Fonts
11:06:39.2 3/18/2006: Creating Menu Font
Hi, that's not the newest version, try the latest one.
Thanks Tom - that worked - I'v been playing around with gameex for about a year and it the best frontend that I've seen. I'll be making a donation soon. Thank you for all of this.
Rayman
I have the same p;roblem Windows 98, etc. but new version:P
01:16:07.1 3/27/2006: GameEx: Version 5.87: Starting Log
01:16:07.1 3/27/2006: Operating System Platform: Win32Windows
01:16:07.1 3/27/2006: Operating System Name: Windows 98
01:16:07.1 3/27/2006: Operating System Version: 4.10.67766446
01:16:07.1 3/27/2006: Checking for versions of .net Framework installed
01:16:07.1 3/27/2006: .net Framework 1.1 Installed
01:16:07.1 3/27/2006: Checking Registration
01:16:07.1 3/27/2006: Running Randomize()
01:16:07.1 3/27/2006: Initialising Video/MNG DLL's
01:16:07.1 3/27/2006: Running Misc startup tasks
01:16:07.1 3/27/2006: Setting Menu types
01:16:07.1 3/27/2006: Opening Configuration File
01:16:07.1 3/27/2006: Getting Configuration Values
01:16:07.1 3/27/2006: Using Theme: Default - Custom V2 Default 800x600
01:16:07.1 3/27/2006: Checking for alternate Image Directory for Theme: Default - Custom V2 Default 800x600
01:16:07.2 3/27/2006: Launching HideOS.exe
01:16:07.3 3/27/2006: Hiding Taskbar
01:16:07.3 3/27/2006: Is Media Center running?
01:16:07.3 3/27/2006: Check Media Center Exit/Start Mode
01:16:07.3 3/27/2006: Media Center Mode 0
01:16:07.3 3/27/2006: Text/Language: English
01:16:07.3 3/27/2006: Applying Language/Text
01:16:07.4 3/27/2006: Creating Scancodes.txt (List of DirectInput scan codes)
01:16:07.4 3/27/2006: Snap Delay set to: 1
01:16:07.4 3/27/2006: Get other settings
01:16:07.5 3/27/2006: Set: Find emulator artwork on best match basis
01:16:07.6 3/27/2006: Start work for Form
01:16:07.6 3/27/2006: Getting Original Screen Size
01:16:07.6 3/27/2006: Loading ICON
01:16:07.6 3/27/2006: Checking for applications to Launch On Startup
01:16:07.6 3/27/2006: Initializing Component
01:16:07.6 3/27/2006: Initialising Bass Audio Library
01:16:07.7 3/27/2006: Loading default loading screen
01:16:07.7 3/27/2006: Version 2 Theme being used. Loading.
01:16:07.7 3/27/2006: Loading Button Data
01:16:07.7 3/27/2006: Loading Font Data
01:16:07.7 3/27/2006: Loading Layout Data
01:16:07.7 3/27/2006: Loading Taskbar Data
01:16:07.7 3/27/2006: Using 2D Animations
01:16:07.7 3/27/2006: Using General Font: Trebuchet MS
01:16:07.7 3/27/2006: Using Title Font: Trebuchet MS
01:16:07.7 3/27/2006: Initialising DirectDraw
01:16:07.8 3/27/2006: Creating DirectDraw Device
01:16:07.8 3/27/2006: Using Device: VIA/S3G UniChrome IGP
01:16:07.9 3/27/2006: Setting Resolution to 800x600 32 bit color
01:16:08.0 3/27/2006: Creating DirectDraw Surfaces
01:16:08.0 3/27/2006: Creating Primary Surface - Full Screen Mode
01:16:08.0 3/27/2006: Creating Back Buffer
01:16:08.0 3/27/2006: Loading graphic surfaces
01:16:08.0 3/27/2006: Creating Surfaces Misc and Dialogs
01:16:08.2 3/27/2006: Creating Surface Volume
01:16:08.2 3/27/2006: Creating Surfaces Arrows
01:16:08.2 3/27/2006: Creating Surfaces GameEXlogo Text
01:16:08.2 3/27/2006: Creating Surfaces Toolbar
01:16:08.2 3/27/2006: Creating Surfaces Backgrounds
01:16:09.2 3/27/2006: Creating Surfaces Toolbar Controls
01:16:09.2 3/27/2006: Creating Surfaces GameEx Logo
01:16:09.3 3/27/2006: Creating Surfaces Home & Exit
01:16:09.3 3/27/2006: Creating Surfaces Snaps
01:16:09.3 3/27/2006: Creating Surfaces Menu and List Bars
01:16:09.4 3/27/2006: Creating Fonts
01:16:09.4 3/27/2006: Creating Menu Font
Theres known issues with Windows 98 when using custom themes (which your using here) and higher resolutions. Unfortunatly its just not up to the job.
