I'm having problems with a few emulators in GameEx.
The first is Nestopia. The games sound plays, but the screen is black. any ideas?
Heres that config:
[Emulator_3]
StartPageName=Nintendo NES Games
TitleText=Nintendo
StartPageLogo=nes
RomFilter=*.nes
RomsInFolders=False
ROMPath=D:\arcade\nes\roms
SnapPath=D:\arcade\nes\snaps
WorkingPath=D:\arcade\nes\
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=False
Debug=False
Command=Nestopia.exe "[ROMPath]\[RomFile]"
I can't seem to get an Atari 5200 emulator working either. I tried Jum52, but no luck.
[Emulator_6]
StartPageName=Atari 5200 Games
TitleText=Atari 5200
StartPageLogo=5200
RomFilter=*.bin
RomsInFolders=False
ROMPath=D:\arcade\a5200\roms
SnapPath=D:\arcade\a5200\snaps
WorkingPath=D:\arcade\a5200\
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=False
Debug=False
MapFile=
OLDatZip=
Command=jum52.exe "[ROMPath]\[RomFile]"
any help is appreciated!
dan
Heres that config:
[Emulator_3]
TitleText=Nintendo
StartPageLogo=nes
RomFilter=*.nes
RomsInFolders=False
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=False
Debug=False
[Emulator_6]
StartPageLogo=5200
RomFilter=*.bin
RomsInFolders=False
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=False
Debug=False
MapFile=
OLDatZip=
dan
Try setting show desktop to true in the config and see if that helps.
Jay Thompson
Jay Thompson
Thanks, that at least brings up the window in each emulator. How can i make it fullscreen with out the window? Can't seem to find the right settings for these...
Dan
P.S. I just got the NES fullscreen, but still am up s*** creek with jum52...
Also N64 with project64 isnt working either...
Nestopia is working fine for me. Here's my settings:
[Emulator_1]
STARTPAGENAME=Nintendo NES
TITLETEXT=Nintendo NES
StartPageLogo=nes
ROMFilter=*.nes
RomsInFolders=False
RomPath=D:\Games\Emulation\NES\Roms
SnapPath=D:\Games\Emulation\NES\Snaps
TitlePath=
BoxPath=
CartPath=
WorkingPath=C:\Emulation\Nestopia
MapKeys=False
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=False
Capitals=False
RemoveBrackets=True
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=Nestopia
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[GENERAL]
DumbyValue=
Nestopia config. I edited out all the input settings to make it shorter.
// Nestopia Configuration File. Version 1.26
-files auto export states : yes
-files auto import states : yes
-files auto ips patching : no
-files compress states : yes
-files fds bios : ""
-files fds led : screen
-files fds save : ips
-files path image : "C:\Emulation\Nestopia\snaps\"
-files path ips : "C:\Emulation\Nestopia\ips\"
-files path save : "C:\Emulation\Nestopia\save\"
-files path screenshot : "C:\Emulation\Nestopia\screenshots\"
-files path script : "C:\Emulation\Nestopia\scripts\"
-files path state : "C:\Emulation\Nestopia\states\"
-files readonly cartridge : no
-files screenshot format : png
-files tape : ""
-files use image tape name : yes
-files use last image path : yes
-files use last script path : yes
-launcher color background : 0x00FFFFFF
-launcher color foreground : 0x00000000
-launcher column 1 : file
-launcher column 2 : system
-launcher column 3 : mapper
-launcher column 4 : prom
-launcher column 5 : crom
-launcher column 6 : wram
-launcher column 7 : battery
-launcher column 8 : trainer
-launcher column 9 : mirroring
-launcher search any file extension : no
-launcher search files archive : yes
-launcher search files fds : yes
-launcher search files ips : yes
-launcher search files nes : yes
-launcher search files nsf : yes
-launcher search files nsp : yes
-launcher search files unf : yes
-launcher search no duplicate files : yes
-launcher show gridlines : yes
-launcher use image database : yes
-machine autoselect controllers : yes
-machine no sprite limit : no
-machine port 1 : pad1
-machine port 2 : pad2
-machine port 3 : unconnected
-machine port 4 : unconnected
-machine port 5 : unconnected
-machine region : auto
-netplay in fullscreen : no
-nsf in background : yes
-preferences allow multiple instances : no
-preferences autocorrect images : yes
-preferences autostart emulation : yes
-preferences confirm exit : no
-preferences confirm machine reset : no
-preferences default desktop menu color : yes
-preferences default fullscreen menu color : yes
-preferences desktop menu color : 0x00EFCA18
-preferences fullscreen menu color : 0x00EFCA18
-preferences power off on exit : no
-preferences priority : normal
-preferences run in background : no
-preferences save cheats : yes
-preferences save launcher files : yes
-preferences save logfile : no
-preferences save netplay list : yes
-preferences save settings : yes
-preferences save window : no
-preferences start in fullscreen : yes
-preferences suppress warnings : yes
-sound adjust pitch : no
-sound apu dpcm : on
-sound apu external : on
-sound apu noise : on
-sound apu square 1 : on
-sound apu square 2 : on
-sound apu triangle : on
-sound buffers : 2
-sound device : "00000000-0000-0000-0000-000000000000"
-sound enabled : yes
-sound output : stereo
-sound sample bits : 16
-sound sample rate : 44100
-sound volume : 100
-timer alternative speed : 180
-timer auto frame skip : no
-timer default rewind speed : yes
-timer default speed : yes
-timer max frame skips : 8
-timer no rewind sound : no
-timer performance counter : yes
-timer rewind speed : 60
-timer rewinder : no
-timer speed : 60
-timer triple buffering : yes
-timer vsync : yes
-video auto display frequency : yes
-video color brightness : 128
-video color hue : 128
-video color saturation : 128
-video device : "D7B71EE2-0230-11CF-8E6D-2B5CA1C2CB35"
-video filter : none
-video filter 2xsai bilinear : no
-video filter 2xsai type : 2xsai
-video filter hqx bilinear : no
-video filter hqx scale : 2
-video filter none bilinear : no
-video filter ntsc bilinear : no
-video filter ntsc scanlines : none
-video filter ntsc widescreen : no
-video filter scalex bilinear : no
-video filter scalex scale : 2
-video filter scanlines bilinear : no
-video filter scanlines type : bright
-video fullscreen bpp : 16
-video fullscreen height : 480
-video fullscreen width : 640
-video ntsc bottom : 231
-video ntsc left : 0
-video ntsc right : 255
-video ntsc top : 8
-video pal bottom : 239
-video pal left : 0
-video pal right : 255
-video pal top : 0
-video palette : internal
-video palette file : ""
-video texture location : auto
-view show fps : no
-view show on top : no
-view show status bar : no
-view show window menu : yes
-view size fullscreen : stretched
-view size window : 1
