I get an error when I first bootup my arcade machine with GameEx in the startup directory. Occassionally it won't mess up on the boot. But almost always it gives me the error below. After I close the error screen I can start GameEx and it works fine, so it only happens when I first try to boot.
15:40:27.1 3/18/2006: GameEx: Version 5.78: Starting Log
15:40:27.1 3/18/2006: Operating System Platform: Win32NT
15:40:27.1 3/18/2006: Operating System Name: Windows XP
15:40:27.1 3/18/2006: Operating System Version: 5.1.2600
15:40:27.1 3/18/2006: Checking for versions of .net Framework installed
15:40:27.1 3/18/2006: .net Framework 1.1 Installed
15:40:27.1 3/18/2006: .net Framework 2.0 Installed
15:40:27.1 3/18/2006: Checking Registration
15:40:27.1 3/18/2006: Running Randomize()
15:40:27.1 3/18/2006: Initialising Video/MNG DLL's
15:40:27.1 3/18/2006: Running Misc startup tasks
15:40:27.1 3/18/2006: Setting Menu types
15:40:27.1 3/18/2006: Opening Configuration File
15:40:27.1 3/18/2006: Getting Configuration Values
15:40:27.1 3/18/2006: Using Theme: Default - MCE Glossy
15:40:27.1 3/18/2006: Checking for alternate Image Directory for Theme: Default - MCE Glossy
15:40:27.1 3/18/2006: Text/Language: English
15:40:27.1 3/18/2006: Applying Language/Text
15:40:27.1 3/18/2006: Custom Keyboard Input enabled: Getting custom codes
15:40:27.1 3/18/2006: Creating Scancodes.txt (List of DirectInput scan codes)
15:40:27.2 3/18/2006: Snap Delay set to: 3
15:40:27.2 3/18/2006: Is Media Center running?
15:40:27.2 3/18/2006: Check Media Center Exit/Start Mode
15:40:27.2 3/18/2006: Media Center Mode 0
15:40:27.2 3/18/2006: Checking for applications to Launch On Startup
15:40:27.2 3/18/2006: Get other settings
15:40:27.2 3/18/2006: Set: Find emulator artwork on best match basis
15:40:27.2 3/18/2006: SlikStik support enabled
15:40:27.2 3/18/2006: Using DirectInput for keyboard input
15:40:27.2 3/18/2006: Launching HideOS.exe
15:40:28.0 3/18/2006: Hiding Taskbar
15:40:28.0 3/18/2006: Start work for Form
15:40:28.0 3/18/2006: Getting Original Screen Size
15:40:28.0 3/18/2006: Loading ICON
15:40:28.0 3/18/2006: Initializing Component
15:40:28.1 3/18/2006: Initialising Bass Audio Library
15:40:28.2 3/18/2006: Loading default loading screen
15:40:28.3 3/18/2006: Using 3D Animations
15:40:28.3 3/18/2006: Using General Font: Trebuchet MS
15:40:28.3 3/18/2006: Using Title Font: Trebuchet MS
15:40:28.3 3/18/2006: Starting GameExtender on: 127.0.0.1:8383
15:40:28.3 3/18/2006: Initialising DirectDraw
15:40:28.3 3/18/2006: Applying GameEx is Loading Image
15:40:28.3 3/18/2006: Creating DirectDraw Device
15:40:28.3 3/18/2006: Using Device: XGI Volari Family
15:40:28.5 3/18/2006: Setting Resolution to 800x600 16 bit color
15:40:28.5 3/18/2006: Creating DirectDraw Surfaces
15:40:28.5 3/18/2006: Creating Primary Surface - Full Screen Mode
15:40:28.6 3/18/2006: Creating Back Buffer
15:40:28.6 3/18/2006: Loading graphic surfaces
15:40:28.6 3/18/2006: Creating Surfaces Misc and Dialogs
15:40:28.7 3/18/2006: Creating Surface Volume
15:40:28.7 3/18/2006: Creating Surfaces Arrows
15:40:28.7 3/18/2006: Creating Surfaces GameEXlogo Text
15:40:28.7 3/18/2006: Creating Surfaces Toolbar
15:40:28.8 3/18/2006: Creating Surfaces Backgrounds
15:40:29.7 3/18/2006: Creating Surfaces Toolbar Controls
15:40:29.7 3/18/2006: Creating Surfaces GameEx Logo
15:40:29.7 3/18/2006: Creating Surfaces Home & Exit
15:40:29.7 3/18/2006: Creating Surfaces Snaps
15:40:29.8 3/18/2006: Creating Surfaces Menu and List Bars
15:40:29.9 3/18/2006: Creating Fonts
15:40:29.9 3/18/2006: Creating Menu Font
15:40:30.4 3/18/2006: Creating Game Font
15:40:30.8 3/18/2006: Creating Game Font Standard Size
15:40:31.7 3/18/2006: Creating Font Black
15:40:31.7 3/18/2006: Creating Font Black Small
15:40:31.8 3/18/2006: Creating Game Font Faded
15:40:32.2 3/18/2006: Creating Title Font
15:40:32.9 3/18/2006: Creating Control Panel Font
15:40:33.8 3/18/2006: Fonts Created Succesfully
15:40:34.1 3/18/2006: Initialising Windows Media Player Component
15:40:34.1 3/18/2006: MAME Path is: D:\MAME
15:40:34.1 3/18/2006: MAME EXE file is: Mame32.exe
15:40:34.2 3/18/2006: ROM Path is: D:\MAME\roms
15:40:34.2 3/18/2006: Catver.ini is located at: D:\MAME\catver.ini
15:40:34.2 3/18/2006: controls.ini is located at: D:\MAME\controls.ini
15:40:34.2 3/18/2006: History.dat is located at: D:\MAME\history.dat
15:40:34.2 3/18/2006: nplayers.ini is located at: D:\MAME\nplayers.ini
15:40:34.2 3/18/2006: MAMEinfo.dat is located at: D:\MAME\mameinfo.dat
15:40:34.2 3/18/2006: Loading Controls.ini map file
15:40:34.2 3/18/2006: Loading Custom Emulators
15:40:34.2 3/18/2006: Loading Emulator 1: Nintendo Enertainment System
15:40:34.2 3/18/2006: Loading Emulator 2: Super Nintendo
15:40:34.2 3/18/2006: Loading Emulator 3: Sega Genesis
15:40:34.3 3/18/2006: Loading Emulator 4: Sega Game Gear
15:40:34.3 3/18/2006: Loading Emulator 5: Atari 2600 Games
15:40:34.6 3/18/2006: Snap Path is: D:\MAME\snap
15:40:34.6 3/18/2006: AVI Snap Path is: D:\MAME\videos
15:40:34.6 3/18/2006: Flyer Path is: D:\MAME\flyers
15:40:34.6 3/18/2006: Cabinet Path is: D:\MAME\cabinets
15:40:34.6 3/18/2006: Title Path is: D:\MAME\titles
15:40:34.6 3/18/2006: Panel Path: Not Found
15:40:34.6 3/18/2006: Icon Path is: D:\MAME\icons
15:40:34.6 3/18/2006: Marquee Path is: D:\MAME\marquees
15:40:34.6 3/18/2006: MAME CMD options: -triplebuffer -nowindow -joy
15:40:34.6 3/18/2006: Attempting to load game list
15:40:34.7 3/18/2006: Loading last used Game List
15:40:34.7 3/18/2006: Loading Start Page
15:40:34.9 3/18/2006: Setting Music Volume
15:40:34.9 3/18/2006: Creating DirectSound Device
15:40:34.9 3/18/2006: Trying: Primary Sound Driver
15:40:34.9 3/18/2006: Loading Sound Files
15:40:34.9 3/18/2006: DirectSound Device Created Successfully
15:40:34.9 3/18/2006: Creating ICONS
15:40:35.0 3/18/2006: Restoring Cached ICONS from File
15:40:35.1 3/18/2006: Gamepad/Joystick disabled
15:40:35.1 3/18/2006: Initialising DirectInput for Keyboard support
15:40:35.1 3/18/2006: Error in the application.
15:40:37.2 3/18/2006: ERRORS DETECTED: EXITING
I get something similar to this every time I upgrade to the next version. Then I just start it again and it works fine.
J.
My problem is it happens every time I boot up my PC/Arcade cabinet not just once, and not only after I upgrade
Any networked drive paths mapped & being used? Check the folders that the config is pointing to for any emulated games as well as mame.
I get this too if I haven't fired up my host PC with the roms on it.
If mame isn't workin try a re-install.
"15:40:34.6 3/18/2006: Panel Path: Not Found" is in your 1st post.
My Tuppence
