Hi - so following another post here on the forum I edited my pinball.ini for Pinball FX2 exactly as recommended, I copied the XML files to the database folder and I can see the tables along with the wheelart and backglass on my cabinet. When I launch any table though it takes me to the black loading screen in PinballX and just hangs there.
For the life of me I can't figure out how to get PinballX to launch a PinballFX2 table.
The tables all launch perfectly from steam outside of PinballX. The Pinball FX2 program also works perfectly if I just run the executable itself outside of PinballX.
Any help at all would be highly appreciated.
Okay - I figured something out -
My PinballX.ini contains the following 2 lines for Pinball FX2
LaunchBeforeWorkingPath=C:\PinballX\Scripts
LaunchBeforeExecutable=PinballFX2.exe
LaunchBeforeParameters=[TABLEFILE]
if I change it to
then in PinballX when I click on a Pinball FX2 table it launces Pinball FX2.
I then can go in and navigate to the table I want to play.
So - next question. How do I go into an individual table directly from PinballX without having to navigate to the table within Pinball FX2?
Also, for some reason, on my cabinet when Pinball FX2 starts its not rotated 270 degrees and in portrait view. Any idea how to get Pinball FX2 rotated and in portrait view on my cabinet using PinballX?
Can't believe im struggling so much with pinball fx2 - Visual Pinball and Future Pinball on PinballX was so easy to set up.
Any help appreciated.
