I'm new to using gameex,can someone help me out with changing the music that plays when the fe starts up.I've set the path for the audio files for the jukebox.I've got an mp3 file of arcade sounds that I would like to play when the fe menu is up instead of the default song "like humans do" that keeps playing.Thanks
That "Like Humans Do" song you're hearing is a sample song that is included with Windows Media Player. You keep hearing that song because it's saved in your Windows Media Player playlist. You need to open up Windows Media Player and remove this song from the library, then add the MP3 of arcade songs to the Windows Media Player library. Just keep in mind that GameEX will only play songs that are listed in the Playlists / Library listings of Windows Media Player.
Hi
Turning off the Jukebox will turn off Windows Media player, and use the Playlist path you set.
When the Jukebox is on, it overrides the playlist setting.
Thanks,
Tom
Thanks for the help guys,that did what I wanted,I don't use the playlist feature much and didn't realize thats where it was picking up the audio from.
