I can't get the Cirqus Voltaire B2S.exe to close after exiting the table. It successfully closes when I'm using Hyperpin or PinSelect. Any idea why it won't close with PInballX?
Is your 'Exit Emulator' key set to be "Escape"? Mine is set to "E" so when I use an older style B2S table I also have to hit "Escape" to exit the backglass right after hitting "E".
I guess I'm gonna have to try editing table scripts for the few B2S.exe tables I'm using. There are a few threads I've read on VPforums about this. As far as I know you can't use ESC as a cab button to close tables and b2s.exe backglasses because this would cause issue with future pinball which uses esc as a non changeable table exit button.
I appreciate your input Mara
