I'm sure Flash's official db will be in the GameEx install. I meant any modifications you made after them.
It's best not to go editing the SQL files. I will have a look today and hopefully upload a complete db.
Currently there appears to be only me working on the databases. We originally started on them in 2008 with a small team and that whittled down to just me over a short period of time. The only entry we had was from tempest of sorts. Lol.
We tried again in September last year and got another small team together, though as of yet I have not had a single submission.
We may consider looking for other long standing members to help with the databases. I will let you know if anything transpires.
Stigzler, can you message me (don't post) the names of the roms that are failing to be recognised?
EDIT: Don't worry, just try the attatched DB
Arcade Sega System 3.zip
stigzler, can you let me know if this works for you?
Ah... think the update killed this :(
looking in gameex folder - a new Sammy Atomiswave.db3 had appeared. Changed name, which resulted in using the eponymous mdb file instead + all is good.
Am I gonna have to do this every time gameex updates!??
I am lost? The update contains the latest DB's, which are the ones I had post and messaged to you.
Please be more specific and I will endeavour to sort it out.
Several of the system names changed in this release that may have caused problems perhaps? Ps. the atomiswave DB is incomplete. Are the Sega System 3 (now Model 3) games ok?
