I can successfully load a FuturePinball table through PinballX but upon launching a ball and hitting the flippers a few times it quits back to PinballX.
Anybody having similar problems?
(log to come)
Wasnt using BAM, tried it out with your arguments and now the table stays open!
However now when I exit a table PinballX remains minimized. Tried to set it as run after but then I get multiple instances of Pinballx
Tell more about Your config:
- cpu (if it is old, like Athlon XP)
- os
- monitors number / config
- gfx card model / drivers
- version of pinballx (if You use old) / FP mods? like Physicist 2.5 / BAM
switch /STAYINRAM is only for BAM/FPLoader.exe
If You use pure FP, it will don't do anything.
Check out the config wizard and see if you've set PinballX to autostart when windows starts? Disabling this feature solved my error that was pretty close to your issue.
  • 4 weeks later...
Sorry for the late response, life got in the way...
pc specs:
Core 2 Duo 3Ghz (e8400)
Win 7 32
Mon 1: 1920x1080
Mon 2: 1280x 1024 (back glass)
GFX card: GTX 555/latest drivers
Pinball x: 1.56
Pinball X is NOT set to auto start
