13th March  2006
- GameEx 5.80
  • A ton of emulator databases
    are included with special thanks to Dave R.
    (AKA Incubus)
  • I've also improved and fixed
    the parsing of the databases to fix where there's
    no date, and provided some built in formatting and
    cleaning of the description and category.
  • See here for more information
    on database support, and how you can help: http://www.gameex.info/forums/index.php?showtopic=1228
  • I have fixed the play random
    videos option, and also improved it so it now does
    a shuffle, instead of just randomly select files,
    meaning videos wont be played again until the list
    has been parsed. Been wanting to do that for a
    while, making this feature pretty good now in my
    opinion.
  • GameEx now attempts to
    download and show box art for Videos when enabled.
  • Something very cool, for
    folks running on good hardware. The 3D Transition
    (selected under display settings), have been
    greatly enhanced to give a very slick alpha blended
    3d effect when going between menus. Not many front ends
    do such things. Only one I know is Windows Media Centre.
    It makes GameEx look even more flash and very cool
    in my opinion, but don't even bother with it if
    you have less than P4 1.8GHZ and a Radeon 8000 (or
    equivalent).
  • Fixes please wait animation
    still showing after GameEx start-up on
    unregistered versions.
  • I've also upped the minimum
    requirements to a P3 700Mhz instead of 500Mhz.
    GameEx may run on less though, but I want people
    to know GameEx is really for newer systems.
  • Improved loading speed of
    some menus including start page a lot.
hey tom after i installed this new version the gameex config program doesnt work any more. here is a picture of what happens
oh and the now i tested gameex and it does the same thing
when i open it i hear the gameex starting sound but the screen stays black when i check task manager its at 99 cpu usage
