HI! first of all Thanks again for developing frontend.. I'm really expecting to finishing seting up ...
I have a question about hard: I got lag in Playfield and BG and videos... I've got a core 2 core cpu windows 7 64bits geforce 9600gt and 6 gb ram
the thing is that using hiperpin.. I 've got plenty of speed BUT... it's too messy.. and i've got 30030400203020 issues
I REALLY LOVE PINBALL X, setup... the new updates and else... but: Why apparently Pinball X uses more resourses? in video matter.. decoding them or whatever?
and I repeat the bug i've discovered..... While seting up Gamepad buttons... if you leave some "blank" it asumes the previous buton asignation...
example..
jump: 1
smile:
laugh: 3
when you press Smile... it jumps too! in stead of doin nothing..
THANKS!!!!
and I really hope I can use it working like a charm in my pc.
Hi,
I will look into the settings issue for the next release but manually editing the ini would do the trick for you in the mean time.
In regards to performance both decoding and rendering take cpu cycles. You can't do much about the rendering but using the corect codecs and settings can make a big difference to the decoding. I can turn this laggy laptop I am working on right now to full FPS just by switcihing from the microsoft codec and ensure i am using FFDSHOW or LAV.
