Function Logger (PinballX Edition) - Version 1.0.1
Here's the usual plugin for development purposes. Basically like it's GameEx cousin, it logs the PinballX variables as they pass through the GameEx events. It's my ground floor entry into the plugin system for PinballX... I had to make a bunch of adjustments to the included template anyways, and I whipped this up in about an hour.
Just extract the attached rar file to your PinballX installation folder and enable it in the plugins menu, you'll be good to go.
Download it here:
http://www.gameex.info/forums/files/file/14-function-logger-pinballx-edition/
Cool thanks Adultery! It's always beneficial to see what's going on under the hood, especially for those inclined to add functionality to the frontend by way of super-cool plugins!
  • 1 month later...
Just a heads up buddy but this is not going to work in the next version unless its added to slightly. Not your fault just adding some new features.
I'm adding a real time key/joy input event. This will allow flipper/solenoid plugins etc.
No problem, if you update the template I'll update the plugin too.
Here is the new event:
Public Function Event_Input(Input_Keys() As Boolean, Input_Buttons() As Boolean, PinballXStatus As Integer) As Boolean
If Input_Keys(System.Windows.Forms.Keys.LShiftKey) Then
' Left Shift Key Down
End If
If Input_Buttons(0) Then
' Gamepad button 1 down
End If
End Function
Roger that! :-)
Updated to 1.0.1:
-Added the new Input event to the plugin system
Thanks for the new toy Tom! :)
