Hello Everyone,
To save alot of time reposing all my images i will link you to my project (if i am aloud to)
The project has been going for awhile and it is a work in progress.
Currently it has an automatic rotating monitor, Namco recoil guns with machine gun mode hacked video drivers and so much more.
Admins if this is not aloud let me know ill remove the link and manually post the project!
Thanks all happy gaming and reading!
http://forums.overclockers.com.au/showthread.php?t=1021786 :ph34r:
Hey everyone So i have finished the major part of the USB rotatable interface.
At the moment all i have to do is build the Automatic KVM feature in.
Then i have to add switches to the Rotate.exe file like below.
Rotate.exe -right
Rotate.exe -left
Rotate.exe -deguass
It also has a a GUI interface that allows you to manually Rotate Left, Rotate Right, Degauss.
It Operates as follows.
Rotate Right Selected by GUI or Rotate.exe -right
Monitor Relay Is turned on (turning off the monitor)
5v is applied HVBridge (High) Rotating the monitor Right
Limit Switch is pressed Turns off rotating, Turns off Monitor Relay(Monitor Comes on), Degaussing Coil fired.
Message is Sent to GUI Letting user known the position.
Rotate Left Selected by GUI or Rotate.exe -left
5v is applied HVBridge (High) Rotating the monitor Left
Degauss Selected by GUI or Rotate.exe -degauss
Deguassing Coil is fired 3 times.
200ms ON
200ms OFF
200ms ON
200ms OFF
200ms ON
200ms OFF
If the monitor is in the left position (meaning the left limit switch is pressed)
And Rotate left is selected by GUI or Rotate.exe -left The Chip will not turn the monitor off nor will it send power to the HV-Bridge.
If the monitor is in the Right position (meaning the Right limit switch is pressed)
And Rotate Right is selected by GUI or Rotate.exe -Right The Chip will not turn the monitor off nor will it send power to the HV-Bridge.
I Have taken a Youtube Video for you all, its not an ideal setup and hard to see but you all get the idea.
I Would love your feedback, i spent alot of time working on this and i hope you all like it as much as i do.
http://youtu.be/oj3v1sMBDOw
