I'm configuring BlueStacks as external application, it starts correctly but remains behind the frontend, as I do not return to the main menu.
any ideas that can help me?
thanks
Please post your GameEx INI for the application in question... sounds like you are missing a setting somewhere.
The INI is manipulated through the Setup Wizard, so it's just a resident file within your GameEx directory. Please refer to this thread for the full details on accessing your GameEx INI, the log and other good stuff. Thanks man!
ok
Enabled_9=True
name_9=ANDROID
path_9=C:\Archivos de programa\BlueStacks
cmd_9=HD-StartLauncher.exe
snap_9=stats
showdesktop_9=True
mapkeys_9=True
WaitBeforeKeys_9=
SendKeys_9=
You might need to use an advanced config to watch for additional processes. I don't know anything about Blue Stacks, but I suspect this because of the name of the app that you are using - 'HD-StartLauncher.exe'
It is a gameex.ini
External aplication
runitgame.bat
c:
CD "c:\archivos de programa\bluestacks"
and log
08:07:35.8 06/06/2013: Opening Configuration File
08:07:35.9 06/06/2013: GameEx: Version 13.13: Starting Log
08:07:35.9 06/06/2013: Operating System Platform: Win32NT
08:07:35.9 06/06/2013: Operating System Name: Windows XP
08:07:35.9 06/06/2013: Operating System Version: 5.1.2600
08:07:35.9 06/06/2013: Getting CPU and RAM info
08:07:35.9 06/06/2013: AMD Athlon II X3 455 Processor, 3583MB
08:07:35.9 06/06/2013: 3,31Ghz - 3 Cores or CPU's
08:07:35.9 06/06/2013: Running Randomize()
08:07:36.0 06/06/2013: Loading PlugIns
08:07:36.2 06/06/2013: Loaded Plugin:"Xpadder Plugin" Version 1.0.8 By Adultery
08:07:36.2 06/06/2013: PlugIn: "Xpadder Plugin" Initialized OK
08:07:36.2 06/06/2013: Using Plugin System Version: 1,4
08:07:36.2 06/06/2013: Checking for applications to Launch On Startup
08:07:36.2 06/06/2013: Setting default net connection limit to 15
08:07:36.2 06/06/2013: Running Misc startup tasks
08:07:36.2 06/06/2013: Setting Menu types
08:07:36.2 06/06/2013: Getting Configuration Values
08:07:36.3 06/06/2013: Using Theme: NexGen
08:07:36.3 06/06/2013: Checking for alternate Image Directory for Theme: NexGen
08:07:36.4 06/06/2013: Launching HideOS.exe
08:07:36.4 06/06/2013: Initialising Video/MNG DLL's
08:07:36.4 06/06/2013: GameEx will check for media insertion (may affect performance)
08:07:36.4 06/06/2013: Hiding Taskbar
08:07:36.5 06/06/2013: Is Media Center running?
08:07:36.5 06/06/2013: Checking/Creating LCD Registry values
08:07:36.5 06/06/2013: Check Media Center Exit/Start Mode
08:07:36.5 06/06/2013: Media Center Mode 2
08:07:36.6 06/06/2013: Video previews on. Warning: Only recommended on modern systems
08:07:36.6 06/06/2013: Custom Keyboard Input enabled: Getting custom codes
08:07:36.6 06/06/2013: Custom Game Device Input enabled: Getting custom codes
08:07:36.6 06/06/2013: Snap Delay set to: 4
08:07:36.6 06/06/2013: Get other settings
08:07:36.6 06/06/2013: Desktop set to Hide ICONS and set Background to Black
08:07:36.6 06/06/2013: Set: Find emulator artwork on best match basis
08:07:36.6 06/06/2013: SlikStik support enabled
08:07:36.6 06/06/2013: Using DirectInput for keyboard input
08:07:36.6 06/06/2013: Start work for Form
08:07:36.6 06/06/2013: Getting Original Screen Size
08:07:36.7 06/06/2013: Opening Database Connection
08:07:37.4 06/06/2013: Initializing Component
08:07:37.5 06/06/2013: MAME Path is: C:\hyperspin1.0\emulators\MAME
08:07:37.6 06/06/2013: Model 2 Path Path is: C:\Emulators\Model2
08:07:37.6 06/06/2013: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
08:07:37.6 06/06/2013: Model 2 EXE file is: emulator_multicpu.exe
08:07:37.6 06/06/2013: Model 2 emulator with command line support detected
08:07:37.6 06/06/2013: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
08:07:37.6 06/06/2013: ZiNc Path is: C:\Emulators\ZiNc
08:07:37.7 06/06/2013: ZiNc EXE file is: zinc.exe
08:07:37.7 06/06/2013: Use ZiNc on. zinc.exe will launch PSX games
08:07:37.7 06/06/2013: MAME EXE file is: mameui.exe
08:07:37.7 06/06/2013: ROM Path is: C:\hyperspin1.0\emulators\MAME\roms
08:07:37.8 06/06/2013: Catver.ini is located at: C:\GameEx\DATA\catver.ini
08:07:37.8 06/06/2013: controls.ini is located at: C:\GameEx\DATA\controls.ini
08:07:37.9 06/06/2013: History.dat is located at: C:\GameEx\DATA\history.dat
08:07:37.9 06/06/2013: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
08:07:37.9 06/06/2013: command.dat is located at: C:\GameEx\DATA\command.dat
08:07:37.9 06/06/2013: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
08:07:37.9 06/06/2013: Loading Controls.ini map file
08:07:37.9 06/06/2013: Snap Path: Not Found
08:07:37.9 06/06/2013: Background Snap Path: Not Found
08:07:37.9 06/06/2013: AVI Snap Path: Not Found
08:07:37.9 06/06/2013: Flyer Path: Not Found
08:07:37.9 06/06/2013: Cabinet Path: Not Found
08:07:37.9 06/06/2013: Cabinet 3D Path: Not Found
08:07:37.9 06/06/2013: Title Path: Not Found
08:07:37.9 06/06/2013: PCB Path: Not Found
08:07:37.9 06/06/2013: Artwork Preview Path: Not Found
08:07:37.9 06/06/2013: Panel Path: Not Found
08:07:37.9 06/06/2013: Manual Path: Not Found
08:07:37.9 06/06/2013: Icon Path: Not Found
08:07:37.9 06/06/2013: Marquee Path: Not Found
08:07:38.0 06/06/2013: Applying Language/Text
08:07:38.0 06/06/2013: Text/Language: Spanish
08:07:38.0 06/06/2013: Loading Language/Text
08:07:38.0 06/06/2013: Loading Custom Emulators
08:07:38.1 06/06/2013: Loading Emulator 1: [Arcade] Arcade (CPS-3)
08:07:38.2 06/06/2013: Loading Emulator 2: [Console] Atari 2600 (Stella)
08:07:38.2 06/06/2013: Loading Emulator 3: [Console] Atari 5200 (MESS)
08:07:38.2 06/06/2013: Loading Emulator 4: [Console] NEC TurboGrafx-16 (MagicEngine)
08:07:38.4 06/06/2013: Loading Emulator 5: [Console] Nintendo N64 (Project64)
08:07:38.5 06/06/2013: Loading Emulator 6: [Console] Nintendo NES (Nestopia)
08:07:38.5 06/06/2013: Loading Emulator 7: [Console] Nintendo SNES (ZSNES)
08:07:38.5 06/06/2013: Loading Emulator 8: [Console] Nintendo Wii (Dolphin)
08:07:38.6 06/06/2013: Loading Emulator 9: [Console] Sega Genesis (Fusion)
08:07:38.7 06/06/2013: Loading Emulator 10: [Console] Sega Master System (Fusion)
08:07:38.8 06/06/2013: Loading Emulator 11: [Console] Sega Saturn (Yabause)
08:07:38.8 06/06/2013: Loading Emulator 12: [Console] SNK Neo-Geo (WinKawaks)
08:07:38.9 06/06/2013: Loading Emulator 13: [Console] Sony Playstation (ePSXe)
08:07:38.9 06/06/2013: Loading Emulator 14: [Console] Sony Playstation 2 (PCSX2)
08:07:39.0 06/06/2013: Loading Emulator 15: [Fruit] Fruit (BFM)
08:07:39.0 06/06/2013: Loading Emulator 16: [Fruit] Fruit (MFME)
08:07:39.2 06/06/2013: Loading Emulator 17: [PC] POPCAP GAMES
08:07:39.2 06/06/2013: Loading Emulator 18: [Pinball] Future Pinball
08:07:39.4 06/06/2013: Loading Emulator 19: [Pinball] Visual PinMAME
08:07:39.5 06/06/2013: Loading Emulator 20: [Arcade] Model 2 (Model2)
08:07:39.5 06/06/2013: Loading Emulator 21: [Console] Sega Dreamcast (nullDC)
08:07:39.6 06/06/2013: Loading Emulator 22: Flash games
08:07:39.7 06/06/2013: Loading Emulator 23: [Arcade] Arcade (WinKawaks)
08:07:39.7 06/06/2013: Loading Emulator 25: [Console] SNK Neo-Geo (Nebula)
08:07:39.8 06/06/2013: Loading Emulator 26: [Console] Sega Saturn (SSF)
08:07:39.9 06/06/2013: Checking if Steam enabled
08:07:39.9 06/06/2013: Cannot find steam path
08:07:39.9 06/06/2013: gamebase support enabled.
08:07:39.9 06/06/2013: Using 3D Alpha Blended Animations.
08:07:39.9 06/06/2013: Retrieving resolution setting
08:07:40.5 06/06/2013: Using General Font: Trebuchet MS
08:07:40.5 06/06/2013: Using Title Font: Trebuchet MS
08:07:40.5 06/06/2013: GameEx will try to reduce CPU usage
08:07:40.5 06/06/2013: Initialising Direct3D
08:07:42.4 06/06/2013: Applying GameEx is Loading Image
08:07:43.5 06/06/2013: Setting Resolution to 1280x1024 32 bit color
08:07:43.5 06/06/2013: Creating Surfaces
08:07:44.1 06/06/2013: Creating Primary Surface - Full Screen Mode
08:07:44.1 06/06/2013: Creating Back Buffer
08:07:44.2 06/06/2013: Version 2 Theme being used. Loading.
08:07:44.2 06/06/2013: Loading Button Data
08:07:44.2 06/06/2013: Loading Font Data
08:07:44.2 06/06/2013: Loading Layout Data
08:07:44.2 06/06/2013: Loading Taskbar Data
08:07:44.2 06/06/2013: Loading graphic Surfaces
08:07:44.2 06/06/2013: Display is running at: 1280x1024 32bit color, 60hz
08:07:44.2 06/06/2013: Adapter: AMD Radeon HD 6670
08:07:44.2 06/06/2013: Max texture size: 8192x8192
08:07:44.2 06/06/2013: Available texture memory: -1947MB
08:07:44.3 06/06/2013: Initialising Bass Audio Library
08:07:44.4 06/06/2013: Creating Surfaces Misc and Dialogs
08:07:45.1 06/06/2013: Creating Surfaces Volume
08:07:45.1 06/06/2013: Creating Surfaces Arrows
08:07:45.2 06/06/2013: Creating Surfaces GameEXlogo Text
08:07:45.2 06/06/2013: Creating Surfaces Toolbar
08:07:45.4 06/06/2013: Creating Surfaces Toolbar Controls
08:07:45.5 06/06/2013: Creating Surfaces Backgrounds
08:07:45.5 06/06/2013: Creating Surfaces GameEx Logo
08:07:45.5 06/06/2013: Creating Surface Unselected
08:07:45.6 06/06/2013: Creating Surfaces Home & Exit
08:07:45.6 06/06/2013: Creating Surfaces Snaps
08:07:45.6 06/06/2013: Creating Surfaces Menu and List Bars
08:07:45.8 06/06/2013: Creating Fonts
08:07:45.8 06/06/2013: Creating Game Font
08:07:46.1 06/06/2013: Creating Game Font Faded
08:07:46.1 06/06/2013: Creating Title Font
08:07:46.1 06/06/2013: Restoring Title Font From Cache
08:07:46.4 06/06/2013: Creating Menu Font
08:07:46.5 06/06/2013: Creating Font Black
08:07:46.6 06/06/2013: Creating Font Black Small
08:07:46.6 06/06/2013: Fonts Created Succesfully
08:07:47.0 06/06/2013: Attempting to load game list
08:07:47.2 06/06/2013: MAME CMD options: -nowindow -joy -skip_gameinfo
08:07:47.7 06/06/2013: Loading music
08:07:52.9 06/06/2013: Initialising DirectInput for Gamepad support
08:07:53.0 06/06/2013: Using Device Psx Gamepad 1
08:07:53.0 06/06/2013: Using Device Psx Gamepad 2
08:07:53.0 06/06/2013: Using Device Psx Gamepad 3
08:07:53.0 06/06/2013: Initialising DirectInput for Keyboard support
08:07:53.1 06/06/2013: Loading Start Page
08:07:53.2 06/06/2013: Initializing MCE Remote
08:07:53.2 06/06/2013: Playing intro sound file
08:07:53.2 06/06/2013: Initialization OK! Starting GameEx!
08:07:53.2 06/06/2013: Testing Main Loop Once: Processing Frame
08:07:53.6 06/06/2013: Testing Main Loop Once: Main Loop ran successfully
08:07:53.8 06/06/2013: Validating: Emulator_1: Snap Path: C:\Assets\Arcade\CPS-3\Snaps
08:07:53.8 06/06/2013: Validating: Emulator_1: Control Panel Path: C:\Assets\Arcade\CPS-3\Controls
08:07:53.8 06/06/2013: Validating: Emulator_1: Title Snap Path: C:\Assets\Arcade\CPS-3\Titles
08:07:53.8 06/06/2013: Validating: Emulator_1: Box Art Path: C:\Assets\Arcade\CPS-3\Boxes
08:07:53.8 06/06/2013: Validating: Emulator_1: Cart Art Path: C:\Assets\Arcade\CPS-3\Cartridges
08:07:53.8 06/06/2013: Validating: Emulator_1: Manual Path: C:\Assets\Arcade\CPS-3\Manuals
08:07:53.9 06/06/2013: Caching Video Snap Path
08:07:53.9 06/06/2013: Caching Snap Path
08:07:53.9 06/06/2013: Caching Title Path
08:07:53.9 06/06/2013: Caching Box Path
08:07:53.9 06/06/2013: Caching Cart Path
08:07:53.9 06/06/2013: Validating: Emulator_2: Snap Path: C:\Assets\Atari 2600\Snaps
08:07:53.9 06/06/2013: Validating: Emulator_2: Control Panel Path: C:\Assets\Atari 2600\Controls
08:07:53.9 06/06/2013: Validating: Emulator_2: Database: [Console] Atari 2600
08:07:54.0 06/06/2013: Validating: Emulator_2: Title Snap Path: C:\Assets\Atari 2600\Titles
08:07:54.0 06/06/2013: Validating: Emulator_2: Box Art Path: C:\Assets\Atari 2600\Boxes
08:07:54.0 06/06/2013: Validating: Emulator_2: Cart Art Path: C:\Assets\Atari 2600\Cartridges
08:07:54.0 06/06/2013: Validating: Emulator_2: Manual Path: C:\Assets\Atari 2600\Manuals
08:07:54.0 06/06/2013: Caching Video Snap Path
08:07:56.2 06/06/2013: Caching Snap Path
08:07:56.2 06/06/2013: Caching Title Path
08:07:56.2 06/06/2013: Caching Box Path
08:07:56.8 06/06/2013: Caching Cart Path
08:07:57.4 06/06/2013: Validating: Emulator_3: Snap Path: C:\Assets\Atari 5200\Snaps
08:07:57.4 06/06/2013: Validating: Emulator_3: Control Panel Path: C:\Assets\Atari 5200\Controls
08:07:57.4 06/06/2013: Validating: Emulator_3: Database: [Console] Atari 5200
08:07:57.4 06/06/2013: Validating: Emulator_3: Title Snap Path: C:\Assets\Atari 5200\Titles
08:07:57.4 06/06/2013: Validating: Emulator_3: Box Art Path: C:\Assets\Atari 5200\Boxes
08:07:57.4 06/06/2013: Validating: Emulator_3: Cart Art Path: C:\Assets\Atari 5200\Cartridges
08:07:57.4 06/06/2013: Validating: Emulator_3: Manual Path: C:\Assets\Atari 5200\Manuals
08:07:57.4 06/06/2013: Caching Video Snap Path
08:07:57.5 06/06/2013: Caching Snap Path
08:07:57.5 06/06/2013: Caching Title Path
08:07:57.5 06/06/2013: Caching Box Path
08:07:57.7 06/06/2013: Caching Cart Path
08:07:57.7 06/06/2013: Validating: Emulator_4: Snap Path: C:\Assets\NEC TurboGrafx-16\Snaps
08:07:57.8 06/06/2013: Validating: Emulator_4: Control Panel Path: C:\Assets\NEC TurboGrafx-16\Controls
08:07:57.8 06/06/2013: Validating: Emulator_4: Database: [Console] NEC TurboGrafx-16
08:07:57.8 06/06/2013: Validating: Emulator_4: Title Snap Path: C:\Assets\NEC TurboGrafx-16\Titles
08:07:57.8 06/06/2013: Validating: Emulator_4: Box Art Path: C:\Assets\NEC TurboGrafx-16\Boxes
08:07:57.8 06/06/2013: Validating: Emulator_4: Cart Art Path: C:\Assets\NEC TurboGrafx-16\Cartridges
08:07:57.8 06/06/2013: Validating: Emulator_4: Manual Path: C:\Assets\NEC TurboGrafx-16\Manuals
08:07:57.8 06/06/2013: Caching Video Snap Path
08:07:57.8 06/06/2013: Caching Snap Path
08:07:57.8 06/06/2013: Caching Title Path
08:07:57.9 06/06/2013: Caching Box Path
08:07:58.0 06/06/2013: Caching Cart Path
08:07:58.1 06/06/2013: Validating: Emulator_5: Snap Path: C:\Assets\Nintendo N64\Snaps
08:07:58.2 06/06/2013: Validating: Emulator_5: Control Panel Path: C:\Assets\Nintendo N64\Controls
08:07:58.2 06/06/2013: Validating: Emulator_5: Database: [Console] Nintendo N64
08:07:58.2 06/06/2013: Validating: Emulator_5: Title Snap Path: C:\Assets\Nintendo N64\Titles
08:07:58.2 06/06/2013: Validating: Emulator_5: Box Art Path: C:\Assets\Nintendo N64\Boxes
08:07:58.2 06/06/2013: Validating: Emulator_5: Cart Art Path: C:\Assets\Nintendo N64\Cartridges
08:07:58.2 06/06/2013: Validating: Emulator_5: Manual Path: C:\Assets\Nintendo N64\Manuals
08:07:58.2 06/06/2013: Caching Video Snap Path
08:07:58.5 06/06/2013: Caching Snap Path
08:07:58.5 06/06/2013: Caching Title Path
08:07:59.5 06/06/2013: Caching Box Path
08:08:00.5 06/06/2013: Caching Cart Path
08:08:00.9 06/06/2013: Validating: Emulator_6: Snap Path: C:\Assets\Nintendo NES\Snaps
08:08:01.0 06/06/2013: Validating: Emulator_6: Control Panel Path: C:\Assets\Nintendo NES\Controls
08:08:01.0 06/06/2013: Validating: Emulator_6: Database: [Console] Nintendo NES
08:08:01.0 06/06/2013: Validating: Emulator_6: Title Snap Path: C:\Assets\Nintendo NES\Titles
08:08:01.0 06/06/2013: Validating: Emulator_6: Box Art Path: C:\Assets\Nintendo NES\Boxes
08:08:01.0 06/06/2013: Validating: Emulator_6: Cart Art Path: C:\Assets\Nintendo NES\Cartridges
08:08:01.0 06/06/2013: Validating: Emulator_6: Manual Path: C:\Assets\Nintendo NES\Manuals
08:08:01.0 06/06/2013: Caching Video Snap Path
08:08:05.3 06/06/2013: Caching Snap Path
08:08:05.3 06/06/2013: Caching Title Path
08:08:08.8 06/06/2013: Caching Box Path
08:08:10.5 06/06/2013: Caching Cart Path
08:08:10.5 06/06/2013: Validating: Emulator_7: Snap Path: C:\Assets\Nintendo SNES\Snaps
08:08:10.6 06/06/2013: Validating: Emulator_7: Video Snap Path: C:\hyperspin1.0\Media\Nintendo Entertainment System\Video
08:08:10.6 06/06/2013: Validating: Emulator_7: Control Panel Path: C:\Assets\Nintendo SNES\Controls
08:08:10.6 06/06/2013: Validating: Emulator_7: Database: [Console] Nintendo SNES
08:08:10.6 06/06/2013: Validating: Emulator_7: Title Snap Path: C:\Assets\Nintendo SNES\Titles
08:08:10.6 06/06/2013: Validating: Emulator_7: Box Art Path: C:\Assets\Nintendo SNES\Boxes
08:08:10.6 06/06/2013: Validating: Emulator_7: Cart Art Path: C:\Assets\Nintendo SNES\Cartridges
08:08:10.6 06/06/2013: Validating: Emulator_7: Manual Path: C:\Assets\Nintendo SNES\Manuals
08:08:10.6 06/06/2013: Caching Video Snap Path
08:08:10.7 06/06/2013: Caching Snap Path
08:08:11.8 06/06/2013: Caching Title Path
08:08:14.7 06/06/2013: Caching Box Path
08:08:16.0 06/06/2013: Caching Cart Path
08:08:17.4 06/06/2013: Validating: Emulator_8: Snap Path: C:\Assets\Nintendo Wii\Snaps
08:08:17.4 06/06/2013: Validating: Emulator_8: Control Panel Path: C:\Assets\Nintendo Wii\Controls
08:08:17.4 06/06/2013: Validating: Emulator_8: Title Snap Path: C:\Assets\Nintendo Wii\Titles
08:08:17.4 06/06/2013: Validating: Emulator_8: Box Art Path: C:\Assets\Nintendo Wii\Boxes
08:08:17.4 06/06/2013: Validating: Emulator_8: Cart Art Path: C:\Assets\Nintendo Wii\Cartridges
08:08:17.4 06/06/2013: Validating: Emulator_8: Manual Path: C:\Assets\Nintendo Wii\Manuals
08:08:17.4 06/06/2013: Caching Video Snap Path
08:08:17.4 06/06/2013: Caching Snap Path
08:08:17.4 06/06/2013: Caching Title Path
08:08:17.4 06/06/2013: Caching Box Path
08:08:17.4 06/06/2013: Caching Cart Path
08:08:17.4 06/06/2013: Validating: Emulator_9: Snap Path: C:\Assets\Sega Genesis\Snaps
08:08:17.5 06/06/2013: Validating: Emulator_9: Control Panel Path: C:\Assets\Sega Genesis\Controls
08:08:17.5 06/06/2013: Validating: Emulator_9: Database: [Console] Sega Genesis
08:08:17.5 06/06/2013: Validating: Emulator_9: Title Snap Path: C:\Assets\Sega Genesis\Titles
08:08:17.5 06/06/2013: Validating: Emulator_9: Box Art Path: C:\Assets\Sega Genesis\Boxes
08:08:17.5 06/06/2013: Validating: Emulator_9: Cart Art Path: C:\Assets\Sega Genesis\Cartridges
08:08:17.5 06/06/2013: Validating: Emulator_9: Manual Path: C:\Assets\Sega Genesis\Manuals
08:08:17.5 06/06/2013: Caching Video Snap Path
08:08:19.2 06/06/2013: Caching Snap Path
08:08:19.2 06/06/2013: Caching Title Path
08:08:20.6 06/06/2013: Caching Box Path
08:08:20.7 06/06/2013: Caching Cart Path
08:08:21.2 06/06/2013: Validating: Emulator_10: Snap Path: C:\Assets\Sega Master System\Snaps
08:08:21.2 06/06/2013: Validating: Emulator_10: Control Panel Path: C:\Assets\Sega Master System\Controls
08:08:21.3 06/06/2013: Validating: Emulator_10: Database: [Console] Sega Master System
08:08:21.3 06/06/2013: Validating: Emulator_10: Title Snap Path: C:\Assets\Sega Master System\Titles
08:08:21.3 06/06/2013: Validating: Emulator_10: Box Art Path: C:\Assets\Sega Master System\Boxes
08:08:21.3 06/06/2013: Validating: Emulator_10: Cart Art Path: C:\Assets\Sega Master System\Cartridges
08:08:21.3 06/06/2013: Validating: Emulator_10: Manual Path: C:\Assets\Sega Master System\Manuals
08:08:21.3 06/06/2013: Caching Video Snap Path
08:08:21.4 06/06/2013: Caching Snap Path
08:08:21.4 06/06/2013: Caching Title Path
08:08:21.5 06/06/2013: Caching Box Path
08:08:21.5 06/06/2013: Caching Cart Path
08:08:21.5 06/06/2013: Validating: Emulator_11: Snap Path: C:\Assets\Sega Saturn\Snaps
08:08:21.5 06/06/2013: Validating: Emulator_11: Control Panel Path: C:\Assets\Sega Saturn\Controls
08:08:21.5 06/06/2013: Validating: Emulator_11: Database: [Console] Sega Saturn
08:08:21.5 06/06/2013: Validating: Emulator_11: Title Snap Path: C:\Assets\Sega Saturn\Titles
08:08:21.5 06/06/2013: Validating: Emulator_11: Box Art Path: C:\Assets\Sega Saturn\Boxes
08:08:21.5 06/06/2013: Validating: Emulator_11: Cart Art Path: C:\Assets\Sega Saturn\Cartridges
08:08:21.5 06/06/2013: Validating: Emulator_11: Manual Path: C:\Assets\Sega Saturn\Manuals
08:08:21.5 06/06/2013: Caching Video Snap Path
08:08:21.5 06/06/2013: Caching Snap Path
08:08:21.5 06/06/2013: Caching Title Path
08:08:21.5 06/06/2013: Validating: Emulator_12: Snap Path: C:\Assets\SNK Neo-Geo\Snaps
08:08:21.5 06/06/2013: Validating: Emulator_12: Control Panel Path: C:\Assets\SNK Neo-Geo\Controls
08:08:21.6 06/06/2013: Validating: Emulator_12: Database: [Console] SNK Neo-Geo
08:08:21.6 06/06/2013: Validating: Emulator_12: Title Snap Path: C:\Assets\SNK Neo-Geo\Titles
08:08:21.6 06/06/2013: Validating: Emulator_12: Box Art Path: C:\Assets\SNK Neo-Geo\Boxes
08:08:21.6 06/06/2013: Validating: Emulator_12: Cart Art Path: C:\Assets\SNK Neo-Geo\Cartridges
08:08:21.6 06/06/2013: Validating: Emulator_12: Manual Path: C:\Assets\SNK Neo-Geo\Manuals
08:08:21.6 06/06/2013: Caching Video Snap Path
08:08:22.2 06/06/2013: Caching Snap Path
08:08:22.2 06/06/2013: Caching Title Path
08:08:22.2 06/06/2013: Caching Box Path
08:08:22.2 06/06/2013: Caching Cart Path
08:08:22.2 06/06/2013: Validating: Emulator_13: Snap Path: C:\Assets\Sony Playstation\Snaps
08:08:22.2 06/06/2013: Validating: Emulator_13: Control Panel Path: C:\Assets\Sony Playstation\Controls
08:08:22.2 06/06/2013: Validating: Emulator_13: Database: [Console] Sony Playstation
08:08:22.3 06/06/2013: Validating: Emulator_13: Title Snap Path: C:\Assets\Sony Playstation\Titles
08:08:22.3 06/06/2013: Validating: Emulator_13: Box Art Path: C:\Assets\Sony Playstation\Boxes
08:08:22.3 06/06/2013: Validating: Emulator_13: Cart Art Path: C:\Assets\Sony Playstation\Cartridges
08:08:22.3 06/06/2013: Validating: Emulator_13: Manual Path: C:\Assets\Sony Playstation\Manuals
08:08:22.3 06/06/2013: Warning: Emulator_13: MAPFile Does Not Exist
08:08:22.3 06/06/2013: Caching Video Snap Path
08:08:22.3 06/06/2013: Caching Snap Path
08:08:22.3 06/06/2013: Caching Title Path
08:08:22.3 06/06/2013: Caching Box Path
08:08:22.3 06/06/2013: Caching Cart Path
08:08:22.3 06/06/2013: Validating: Emulator_14: Snap Path: C:\Assets\Sony Playstation 2\Snaps
08:08:22.3 06/06/2013: Validating: Emulator_14: Control Panel Path: C:\Assets\Sony Playstation 2\Controls
08:08:22.3 06/06/2013: Validating: Emulator_14: Database: [Console] Sony PlayStation 2
08:08:22.3 06/06/2013: Validating: Emulator_14: Title Snap Path: C:\Assets\Sony Playstation 2\Titles
08:08:22.3 06/06/2013: Validating: Emulator_14: Box Art Path: C:\Assets\Sony Playstation 2\Boxes
08:08:22.3 06/06/2013: Validating: Emulator_14: Cart Art Path: C:\Assets\Sony Playstation 2\Cartridges
08:08:22.3 06/06/2013: Validating: Emulator_14: Manual Path: C:\Assets\Sony Playstation 2\Manuals
08:08:22.3 06/06/2013: Validating: Emulator_15: Snap Path: C:\Assets\Fruit Machine\BFM\Snaps
08:08:22.3 06/06/2013: Validating: Emulator_15: Control Panel Path: C:\Assets\Fruit Machine\BFM\Controls
08:08:22.3 06/06/2013: Validating: Emulator_15: Title Snap Path: C:\Assets\Fruit Machine\BFM\Titles
08:08:22.3 06/06/2013: Validating: Emulator_15: Box Art Path: C:\Assets\Fruit Machine\BFM\Boxes
08:08:22.3 06/06/2013: Validating: Emulator_15: Cart Art Path: C:\Assets\Fruit Machine\BFM\Cartridges
08:08:22.3 06/06/2013: Validating: Emulator_15: Manual Path: C:\Assets\Fruit Machine\BFM\Manuals
08:08:22.3 06/06/2013: Validating: Emulator_16: Snap Path: C:\Assets\Fruit Machine\MFME\Snaps
08:08:22.4 06/06/2013: Validating: Emulator_16: Control Panel Path: C:\Assets\Fruit Machine\MFME\Controls
08:08:22.4 06/06/2013: Validating: Emulator_16: Title Snap Path: C:\Assets\Fruit Machine\MFME\Titles
08:08:22.4 06/06/2013: Validating: Emulator_16: Box Art Path: C:\Assets\Fruit Machine\MFME\Boxes
08:08:22.4 06/06/2013: Validating: Emulator_16: Cart Art Path: C:\Assets\Fruit Machine\MFME\Cartridges
08:08:22.4 06/06/2013: Validating: Emulator_16: Manual Path: C:\Assets\Fruit Machine\MFME\Manuals
08:08:22.4 06/06/2013: Caching Video Snap Path
08:08:22.4 06/06/2013: Caching Snap Path
08:08:22.4 06/06/2013: Caching Title Path
08:08:22.4 06/06/2013: Caching Box Path
08:08:22.4 06/06/2013: Caching Cart Path
08:08:22.4 06/06/2013: Validating: Emulator_18: Snap Path: C:\Assets\Future Pinball\Snaps
08:08:22.4 06/06/2013: Validating: Emulator_18: Control Panel Path: C:\Assets\Future Pinball\Controls
08:08:22.4 06/06/2013: Validating: Emulator_18: Database: [Pinball] Future Pinball
08:08:22.5 06/06/2013: Validating: Emulator_18: Title Snap Path: C:\Assets\Future Pinball\Titles
08:08:22.5 06/06/2013: Validating: Emulator_18: Box Art Path: C:\Assets\Future Pinball\Boxes
08:08:22.5 06/06/2013: Validating: Emulator_18: Cart Art Path: C:\Assets\Future Pinball\Cartridges
08:08:22.5 06/06/2013: Validating: Emulator_18: Manual Path: C:\Assets\Future Pinball\Manuals
08:08:22.5 06/06/2013: Caching Video Snap Path
08:08:22.5 06/06/2013: Caching Snap Path
08:08:22.5 06/06/2013: Caching Title Path
08:08:22.5 06/06/2013: Caching Box Path
08:08:22.5 06/06/2013: Caching Cart Path
08:08:22.5 06/06/2013: Validating: Emulator_19: Snap Path: C:\Assets\Visual Pinball\Snaps
08:08:22.5 06/06/2013: Validating: Emulator_19: Control Panel Path: C:\Assets\Visual Pinball\Controls
08:08:22.5 06/06/2013: Validating: Emulator_19: Database: [Pinball] Visual Pinball
08:08:22.5 06/06/2013: Validating: Emulator_19: Title Snap Path: C:\Assets\Visual Pinball\Titles
08:08:22.5 06/06/2013: Validating: Emulator_19: Box Art Path: C:\Assets\Visual Pinball\Boxes
08:08:22.5 06/06/2013: Validating: Emulator_19: Cart Art Path: C:\Assets\Visual Pinball\Cartridges
08:08:22.5 06/06/2013: Validating: Emulator_19: Manual Path: C:\Assets\Visual Pinball\Manuals
08:08:22.5 06/06/2013: Validating: Emulator_20: Snap Path: C:\Assets\Arcade\Model2\Snaps
08:08:22.5 06/06/2013: Validating: Emulator_20: Control Panel Path: C:\Assets\Arcade\Model2\Controls
08:08:22.5 06/06/2013: Validating: Emulator_20: Title Snap Path: C:\Assets\Arcade\Model2\Titles
08:08:22.5 06/06/2013: Validating: Emulator_20: Box Art Path: C:\Assets\Arcade\Model2\Boxes
08:08:22.5 06/06/2013: Validating: Emulator_20: Cart Art Path: C:\Assets\Arcade\Model2\Cartridges
08:08:22.5 06/06/2013: Validating: Emulator_20: Manual Path: C:\Assets\Arcade\Model2\Manuals
08:08:22.5 06/06/2013: Validating: Emulator_21: Snap Path: C:\Assets\Sega Dreamcast\Snaps
08:08:22.5 06/06/2013: Validating: Emulator_21: Control Panel Path: C:\Assets\Sega Dreamcast\Controls
08:08:22.5 06/06/2013: Validating: Emulator_21: Database: [Console] Sega Dreamcast
08:08:22.5 06/06/2013: Validating: Emulator_21: Title Snap Path: C:\Assets\Sega Dreamcast\Titles
08:08:22.5 06/06/2013: Validating: Emulator_21: Box Art Path: C:\Assets\Sega Dreamcast\Boxes
08:08:22.5 06/06/2013: Validating: Emulator_21: Cart Art Path: C:\Assets\Sega Dreamcast\Cartridges
08:08:22.5 06/06/2013: Validating: Emulator_21: Manual Path: C:\Assets\Sega Dreamcast\Manuals
08:08:22.5 06/06/2013: Validating: Emulator_23: Snap Path: C:\Assets\Arcade\WinKawaks\Snaps
08:08:22.6 06/06/2013: Validating: Emulator_23: Control Panel Path: C:\Assets\Arcade\WinKawaks\Controls
08:08:22.6 06/06/2013: Validating: Emulator_23: Title Snap Path: C:\Assets\Arcade\WinKawaks\Titles
08:08:22.6 06/06/2013: Validating: Emulator_23: Box Art Path: C:\Assets\Arcade\WinKawaks\Boxes
08:08:22.6 06/06/2013: Validating: Emulator_23: Cart Art Path: C:\Assets\Arcade\WinKawaks\Cartridges
08:08:22.6 06/06/2013: Validating: Emulator_23: Manual Path: C:\Assets\Arcade\WinKawaks\Manuals
08:08:22.6 06/06/2013: Caching Video Snap Path
08:08:22.6 06/06/2013: Caching Snap Path
08:08:22.6 06/06/2013: Caching Title Path
08:08:22.6 06/06/2013: Caching Box Path
08:08:22.6 06/06/2013: Caching Cart Path
08:08:22.6 06/06/2013: Validating: Emulator_25: Snap Path: C:\Assets\SNK Neo-Geo\Snaps
08:08:22.6 06/06/2013: Validating: Emulator_25: Control Panel Path: C:\Assets\SNK Neo-Geo\Controls
08:08:22.6 06/06/2013: Validating: Emulator_25: Database: [Console] SNK Neo-Geo
08:08:22.6 06/06/2013: Validating: Emulator_25: Title Snap Path: C:\Assets\SNK Neo-Geo\Titles
08:08:22.6 06/06/2013: Validating: Emulator_25: Box Art Path: C:\Assets\SNK Neo-Geo\Boxes
08:08:22.6 06/06/2013: Validating: Emulator_25: Cart Art Path: C:\Assets\SNK Neo-Geo\Cartridges
08:08:22.6 06/06/2013: Validating: Emulator_25: Manual Path: C:\Assets\SNK Neo-Geo\Manuals
08:08:22.6 06/06/2013: Validating: Emulator_26: Snap Path: C:\Assets\Sega Saturn\Snaps
08:08:22.6 06/06/2013: Validating: Emulator_26: Control Panel Path: C:\Assets\Sega Saturn\Controls
08:08:22.6 06/06/2013: Validating: Emulator_26: Database: [Console] Sega Saturn
08:08:22.6 06/06/2013: Validating: Emulator_26: Title Snap Path: C:\Assets\Sega Saturn\Titles
08:08:22.6 06/06/2013: Validating: Emulator_26: Box Art Path: C:\Assets\Sega Saturn\Boxes
08:08:22.6 06/06/2013: Validating: Emulator_26: Cart Art Path: C:\Assets\Sega Saturn\Cartridges
08:08:22.6 06/06/2013: Validating: Emulator_26: Manual Path: C:\Assets\Sega Saturn\Manuals
08:08:23.5 06/06/2013: Restoring Emulator from Cache: 2
08:08:23.7 06/06/2013: Restoring Emulator Database From Cache: 2
08:08:23.8 06/06/2013: Restoring Emulator from Cache: 3
08:08:23.9 06/06/2013: Restoring Emulator Database From Cache: 3
08:08:24.1 06/06/2013: Restoring Emulator from Cache: 4
08:08:24.2 06/06/2013: Restoring Emulator Database From Cache: 4
08:08:24.5 06/06/2013: Restoring Emulator Database From Cache: 5
08:08:24.7 06/06/2013: Restoring Emulator from Cache: 6
08:08:24.9 06/06/2013: Restoring Emulator Database From Cache: 6
08:08:25.1 06/06/2013: Restoring Emulator from Cache: 7
08:08:25.2 06/06/2013: Restoring Emulator Database From Cache: 7
08:08:25.5 06/06/2013: Restoring Emulator from Cache: 8
08:08:25.7 06/06/2013: Restoring Emulator Database From Cache: 9
08:08:26.0 06/06/2013: [XPADDER PLUGIN] Xpadder Plugin (1.0.8) Initialized successfully!
08:08:26.0 06/06/2013: Restoring Emulator from Cache: 11
08:08:26.0 06/06/2013: Restoring Emulator Database From Cache: 11
08:08:26.2 06/06/2013: Restoring Emulator Database From Cache: 12
08:08:26.3 06/06/2013: Restoring Emulator from Cache: 14
08:08:26.3 06/06/2013: No Database Data: 14
08:08:26.6 06/06/2013: Restoring Emulator from Cache: 17
08:08:26.7 06/06/2013: Restoring Emulator from Cache: 18
08:08:26.7 06/06/2013: No Database Data: 18
08:08:26.7 06/06/2013: Restoring Emulator from Cache: 19
08:08:26.7 06/06/2013: No Database Data: 19
08:08:26.8 06/06/2013: Restoring Emulator from Cache: 21
08:08:26.8 06/06/2013: Restoring Emulator Database From Cache: 21
08:08:26.9 06/06/2013: Restoring Emulator from Cache: 22
08:08:27.1 06/06/2013: DBCache Diff: 10/07/2012 02:30:11 p.m. - 10/07/2012 02:30:11 p.m.
08:08:27.2 06/06/2013: Not Restoring Emulator Database From Cache: 25
08:08:27.5 06/06/2013: Restoring Emulator from Cache: 26
08:08:27.5 06/06/2013: Restoring Emulator Database From Cache: 26
08:11:13.8 06/06/2013: Running: cmd.exe /c c: HD-StartLauncher.exe
08:11:14.0 06/06/2013: Shutting down display
08:12:19.4 06/06/2013: Exiting GameEx!
08:12:19.4 06/06/2013: Disposing all videos
08:12:19.4 06/06/2013: Deleting temporary Karaoke videos
08:12:19.4 06/06/2013: Disposing Image List
08:12:19.4 06/06/2013: Disposing Fonts
08:12:19.4 06/06/2013: Disposing Surfaces
08:12:19.4 06/06/2013: Saving Settings
08:12:19.4 06/06/2013: Shutting down Bass
08:12:19.4 06/06/2013: Closing HideOS.exe
08:12:19.6 06/06/2013: Disposing Plugins
08:12:19.9 06/06/2013: Closing database connection
08:12:19.9 06/06/2013: Checking for applications to Launch On Exit
08:12:19.9 06/06/2013: Bye
First a a quick bit of background and then to the point. Unless specifically configured otherwise GameEx watches the application launched via runitgame.bat (the primary command, not Launch Before, Launch After, etc.) to determine when to give focus back to GameEx. So typically a 'Launcher' sort of throws a monkey wrench in this model, since a Launcher is typically a smaller program designed to run only long enough to start another program. So GameEx starts the Launcher, the Launcher does it's thing and closes, and GameEx thinks you're done with your application and takes back focus.
So that's what Tempest and Han are getting at. You may need to use an Advanced Config as it will let you configure additional Watched Processes. In this way GameEx will know not to take back focus until all watched processes have closed.
... But here's the catch. You cannot use an Advanced Config when you configure an External Application. So you may need to configure this as an Emulator rather than an External Application so you can apply an Advanced Config. I know it sounds odd, but the Emulator config will allow you greater control over the program.
If you would be so kind, please post your emulator config containing your current settings. Like the others I don't know much about BlueStacks, and after researching it a bit, I don't think it's something I'm going to install on my own rig. Having a look at your current progress will help us to make better suggestions about getting you up and running. Please refer to the How to Ask For Help thread for instructions on exporting a single emulator config.
Thanks man!
this is my ini file
[Emulator]
STARTPAGENAME=Android
TITLETEXT=Android
StartPageLogo=
WorkingPath=C:\Archivos de programa\BlueStacks
RomPath=C:\Archivos de programa\BlueStacks
ROMFilter=
Command=HD-StartLauncher.exe
SnapPath=
TitlePath=
BoxPath=
CartPath=
ManualPath=
DATABASE=
ReplaceDash=True
ShowDesktop=True
MAPFile=
configFile=
PCGame=True
ControlPanelPath=
thanks
nullPointer is right on. With a launcher, it usually only launches the program then closes, then GameEx see's that it's closed and then comes back up. Something you MIGHT be able to do is create a BATCH file. Have GameEx launch that. Then when the BATCH file closes, GameEx will resume. I don't quite remember how to set it up, somebody else could be more helpful there. But I do remember you can configure a BATCH file to watch for a process to close before going to the next line in the BATCH.
Also, is it necessary to run the launcher? Outside of GameEx, run your Task Manager and see what program the launcher actually loads up. Then try to run that directly without the launcher. If it works, tell GameEx to run that program instead...
if I did well, but got it the program opens Bluestack behind the frontend and it returns to the menu. Top put the ini file you use.
sorry but I'm a little confused do not know what is the process to be modified to GameEx not return to the menu and run the front
OK, this is good progress. I'm going to incorporate some of Han's advice, but I'm going to take it a slightly different direction. Here's what I'd like you to try:
  • First do like Han says. Launch your game, open up Windows Task Manager, and find the name of the application that your launcher starts up (i.e. the application that's running your game or whatever)
  • Open up notepad and paste the following contents into it.
    # This is an advanced emulator configuration file. It does things such as allow keyboard only emulators to be operated by a gamepad, wait for additional processes to exit and map keys. If this file is used it overrides the MAPKeys setting for the emulator.
    [GENERAL]
    # Enabled. Use this.
    #Make MCE Back button and X-ARCADE Escape and SlikStik Escape to close emulator process
    MapBack=False
    #Make Escape key close emulator process
    MapEscape=False
    #When exiting an emulator via the above mappings, you can specify keys in the send keys format to send instead of having GameEx close the process to cleanly exit the emulator. Such as the Q Key or ALT F4 which is %{F4}
    KeysToSendOnExit=
    #Wait for keys to be processed by the emulator
    EmuWaitForKeys=True
    #Additional processes to wait to exit or close on exit. Dont include the .exe. Leave blank not to use.
    Process1=
    Process2=
    Process3=
    Process4=
    [JOYMAPPING]
    # For mapping a GamePad to keys
    # Specify a virtual key code to send when the specific joystick control is pressed. Look at vkcodes.htm for codes.
    JoymappingEnabled=False
    Left=
    up=
    Right=
    Down=
    Button1=
    Button2=
    Button3=
    Button4=
    Button5=
    Button6=
    Button7=
    Button8=
    Button9=
    Button10=
    Button11=
    Button12=
    Button13=
    Button14=
    Button15=
    Button16=
    [GAMEPADEXIT]
    #MAP Gamepad controls to exit and make controls exit process
    MapGamePadExit=False
    #Flag the controls that exit a game by placing True next to each control. To not use the control as part of the combination use a 0
    Left=True
    Down=
    Right=
    Up=True
    Button1=
    Button2=
    Button3=
    Button4=True
    Button5=True
    Button6=True
    Button7=
    Button8=
    Button9=
    Button10=
    Button11=
    Button12=
    Button13=
    Button14=
    Button15=
    Button16=
    [MOUSEMAPPING]
    # For registered users, the ability to control the mouse with a gamepad and/or directional keys.
    # For example for PC strategy games.
    # Apparantly this functionality is similar to the software Pinnacle profiler. Remember you can setup an emulator
    # as one PC game. Specify enabled, and mousespeed 0-20. 20 Being fastest. This setting overrides the directional
    # mapping for the above and buttons 1 and 2 Button 1/CTRL becomes left mouse. Button 2/ALT Right mouse
    MouseMappingEnabled=False
    MouseSpeed=0
    [bLOCKKEYS]
    # Use this section to disable and block key presses and mouse clicks.
    # To disable the mouse clicks use code 1 for left mouse button,
    # 2 for right button and 4 for middle button
    Enabled=False
    BlockKey_1=1
    BlockKey_2=2
    BlockKey_3=4
    BlockKey_4=
    BlockKey_5=
    [KEYBOARDREMAP]
    # Remap Keys for the emulator. Specify from the from key, which is the key you wish to replace the to key
    # This should be good enough for real time gaming. Registered version feature. Look at VKCodes.htm for codes.
    Enabled=False
    Remap_1_From_VK=
    Remap_1_To_VK=
    Remap_2_From_VK=
    Remap_2_To_VK=
    Remap_3_From_VK=
    Remap_3_To_VK=
    Remap_4_From_VK=
    Remap_4_To_VK=
    Remap_5_From_VK=
    Remap_5_To_VK=
    Remap_6_From_VK=
    Remap_6_To_VK=
    Remap_7_From_VK=
    Remap_7_To_VK=
    Remap_8_From_VK=
    Remap_8_To_VK=
    Remap_9_From_VK=
    Remap_9_To_VK=
    Remap_10_From_VK=
    Remap_10_To_VK=
    Remap_11_From_VK=
    Remap_11_To_VK=
    Remap_12_From_VK=
    Remap_12_To_VK=
    Remap_13_From_VK=
    Remap_13_To_VK=
    Remap_14_From_VK=
    Remap_14_To_VK=
    Remap_15_From_VK=
    Remap_15_To_VK=
    Remap_16_From_VK=
    Remap_16_To_VK=
    Remap_17_From_VK=
    Remap_17_To_VK=
    Remap_18_From_VK=
    Remap_18_To_VK=
    Remap_19_From_VK=
    Remap_19_To_VK=
    Remap_20_From_VK=
    Remap_20_To_VK=
    Remap_21_From_VK=
    Remap_21_To_VK=
    Remap_22_From_VK=
    Remap_22_To_VK=
    Remap_23_From_VK=
    Remap_23_To_VK=
    Remap_24_From_VK=
    Remap_24_To_VK=
    Remap_25_From_VK=
    Remap_25_To_VK=
    Remap_26_From_VK=
    Remap_26_To_VK=
    Remap_27_From_VK=
    Remap_27_To_VK=
    Remap_28_From_VK=
    Remap_28_To_VK=
    Remap_29_From_VK=
    Remap_29_To_VK=
    Remap_30_From_VK=
    Remap_30_To_VK=
    Remap_31_From_VK=
    Remap_31_To_VK=
    Remap_32_From_VK=
    Remap_32_To_VK=
  • Save the file as BlueStacks.ini (or whatever you like) in the following directory:
    ...\GameEx\CONFIG\EMULATORS
  • Locate the following section of your file and modify it like so (Remember to follow the instructions - this is only the name of the executable. Do not include the extension.):
    Process1=[Enter the name of your application right here]
    Process2=
    Process3=
    Process4=
This is what's known as an Advanced Emulator Config around these parts. You can edit your Advanced Emulator config through the Setup Wizard. At this point you will need to configure GameEx to actually use your new Advanced Emulator config for BlueStacks. Do the following:
  • Open the Setup Wizard and navigate to the Advanced Emulator Setup screen for your BlueStacks setup. On that screen you'll see a field called Advanced Config. Your new advanced emulator config (BlueStacks or whatever you called it) should appear in that dropdown list. Select your new config and exit the Setup Wizard.
  • (Optional) After selecting your Advanced Emulator Config, you can also edit the contents by clicking the '...' button. This will open up a GUI editor for the config which is quite a bit more user-friendly than editing the config with notepad.
Good luck Paul, and let us know how you're getting along with this.
Hmm ... if you followed those instructions you should see that Advanced Emulator Config in the appropriate dropdown on the Advanced Emulator Setup screen. If you copied the above text into a file called BlueStacks.ini (or whatever you would prefer) in the ...\GameEx\CONFIG\EMULATORS (where '...' is wherever you have GameEx installed), you should see it as an available choice in the following field on the Advanced Emulator Setup screen:
The easiest way to see what's happening will be to take a look at your current settings. When you have a moment please post your current progress in the form of your Emulator Config for BlueStacks as well as the BlueStacks.ini file you created above (if that's what you called the file).
Thanks man!
You will only be able to configure individual games as ROMs if BlueStacks is actually capable of running individual games directly from the command line. Otherwise it's a lost cause (unless someone has written a loader or wrapper to automate loading individual games).
looking I found that can be done by selecting hd-frontend.exe to open the game directly but for some reason unknown to me I get the following error HD-Frontend <Vm name> Can you help me?
thanks
You need to figure out how to run a game from the command line or a bat file, and then use the command in GameEx. Sometimes it takes a bit of trial and error to figure things out, so you will have to decide if it is worth the time to get it going.
My guess would be HD-Frontend.exe "RomName" or HD-Frontend.exe "RomName\RomPath"
