I cannot get Gameex to launch no matter which version of mame I use. The latest Mame build that I have tried was 0104b and this is what I got. Can someone point me to a setup guide or thread.Thanks in advance
.0 3/9/2006: GameEx: Version 5.74: Starting Log
18:45:23.0 3/9/2006: Operating System Platform: Win32NT
18:45:23.0 3/9/2006: Operating System Name: Windows XP
18:45:23.0 3/9/2006: Operating System Version: 5.1.2600
18:45:23.0 3/9/2006: Checking for versions of .net Framework installed
18:45:23.0 3/9/2006: .net Framework 1.1 Installed
18:45:23.0 3/9/2006: .net Framework 2.0 Installed
18:45:23.0 3/9/2006: Checking Registration
18:45:23.0 3/9/2006: Running Randomize()
18:45:23.0 3/9/2006: Initialising Video/MNG DLL's
18:45:23.0 3/9/2006: Running Misc startup tasks
18:45:23.0 3/9/2006: Setting Menu types
18:45:23.0 3/9/2006: Opening Configuration File
18:45:23.0 3/9/2006: Getting Configuration Values
18:45:23.0 3/9/2006: Using Theme: Default - Default
18:45:23.0 3/9/2006: Checking for alternate Image Directory for Theme: Default - Default
18:45:23.0 3/9/2006: Text/Language: English
18:45:23.0 3/9/2006: Applying Language/Text
18:45:23.1 3/9/2006: Creating Scancodes.txt (List of DirectInput scan codes)
18:45:23.1 3/9/2006: Snap Delay set to: 1
18:45:23.1 3/9/2006: Is Media Center running?
18:45:23.1 3/9/2006: Check Media Center Exit/Start Mode
18:45:23.1 3/9/2006: Media Center Mode 2
18:45:23.1 3/9/2006: Checking for applications to Launch On Startup
18:45:23.1 3/9/2006: Get other settings
18:45:23.1 3/9/2006: Using 2D Animations
18:45:23.1 3/9/2006: Set: Find emulator artwork on best match basis
18:45:23.1 3/9/2006: Start work for Form
18:45:23.1 3/9/2006: Getting Original Screen Size
18:45:23.1 3/9/2006: Loading ICON
18:45:23.1 3/9/2006: Initializing Component
18:45:23.1 3/9/2006: Initialising Bass Audio Library
18:45:23.3 3/9/2006: Loading default loading screen
18:45:23.3 3/9/2006: Using General Font: Trebuchet MS
18:45:23.3 3/9/2006: Using Title Font: Trebuchet MS
18:45:23.3 3/9/2006: Initialising DirectDraw
18:45:23.3 3/9/2006: Creating DirectDraw Device
18:45:23.3 3/9/2006: Creating DirectDraw Surfaces
18:45:23.3 3/9/2006: Creating Primary Surface - Windowed Mode
18:45:23.4 3/9/2006: Creating Back Buffer
18:45:23.4 3/9/2006: Loading graphic surfaces
18:45:23.4 3/9/2006: Creating Surfaces Misc and Dialogs
18:45:23.5 3/9/2006: Creating Surface Volume
18:45:23.5 3/9/2006: Creating Surfaces Arrows
18:45:23.5 3/9/2006: Creating Surfaces GameEXlogo Text
18:45:23.5 3/9/2006: Creating Surfaces Toolbar
18:45:23.6 3/9/2006: Creating Surfaces Backgrounds
18:45:24.0 3/9/2006: Creating Surfaces Toolbar Controls
18:45:24.0 3/9/2006: Creating Surfaces GameEx Logo
18:45:24.1 3/9/2006: Creating Surfaces Home & Exit
18:45:24.1 3/9/2006: Creating Surfaces Snaps
18:45:24.1 3/9/2006: Creating Surfaces Menu and List Bars
18:45:24.2 3/9/2006: Creating Fonts
18:45:24.2 3/9/2006: Creating Menu Font
18:45:24.3 3/9/2006: Creating Game Font
18:45:24.3 3/9/2006: Creating Game Font Standard Size
18:45:24.6 3/9/2006: Creating Font Black
18:45:24.7 3/9/2006: Creating Font Black Small
18:45:24.7 3/9/2006: Creating Game Font Faded
18:45:24.7 3/9/2006: Creating Title Font
18:45:24.9 3/9/2006: Creating Control Panel Font
18:45:25.1 3/9/2006: Fonts Created Succesfully
18:45:47.2 3/9/2006: Initialising Windows Media Player Component
18:45:47.2 3/9/2006: MAME Path is: F:\Mame
18:45:47.2 3/9/2006: MAME EXE file is: f:\mame
18:45:47.2 3/9/2006: Invalid MAME Executable
18:45:47.2 3/9/2006: ERRORS DETECTED: EXITING
1)Are you using the latest build of gameex,v5.78? because I believe gameex should start even without mame installed.
2) it looks like what ever version of gameex you have can't find the mame.exe,check your path to the mame.exe in the config app
3)is it an official build of mame or custom build?
Hi bigyouth!!
Chek your config in gameex. Your mame exe are not corret, the correct exe is
mame32.exe, in your log you have "f:\mame", that its the folder, not the exe. That its your problem and the log say it "Invalid MAME Executable".
Change this in your gameex config and it will run. Try it!!
Excuse my bad english.
-=Evil=-
