A feature I use alot in graphics is converting a color to alpha. The only software I know that can do this in a simple way is Gimp. It's the only reason I install Gimp.
Anyway I got sick of running Gimp just to use this feature and decided to write an app to do it. It uses the same algorithm as the Gimp plugin. It supports batch processing, has a colour picker and is very simple to use.
Download Color2Alpha
  • 2 months later...
Color2Alpha 1.2 Released
- Now you can specify a color threshold using a slider. The threshold determines the distance from the color and whether or not it should be converted to alpha.
