Tom Speirs Posted June 3, 2013 Posted June 3, 2013 I took the time, scoured and downloaded all the wheel images I could find. I then wrote an app to rename the files according to the latest Dats.These are now on the FTP. 2
Tom Speirs Posted June 3, 2013 Author Posted June 3, 2013 A couple I am missing and would like to add if anyone can help:The AtariansBalyhoo
pocketpal Posted June 3, 2013 Posted June 3, 2013 Thanks a lot for doing this! I'm finding so many that I didn't have!
KRC Posted June 3, 2013 Posted June 3, 2013 Is this of any use?I cut it from a flyer and gave it a general clean over. 1
Tom Speirs Posted June 4, 2013 Author Posted June 4, 2013 Thanks guys.Just one more missing: Tim-Buc-Tu.
KRC Posted June 5, 2013 Posted June 5, 2013 If you need anymore I dont have a problem sourcing/creating/cutting etc..
promise2die4 Posted December 4, 2013 Posted December 4, 2013 i also have a lot of wheel logo's,but where can i find the FTP server so i can check the ones we have double??please send ftp adress in messages.Tnx for your work guys.
nullPointer Posted December 4, 2013 Posted December 4, 2013 You can find information on the FTP server right here. Thanks and good luck!
