R-DUB Posted May 31, 2013 Share Posted May 31, 2013 There seems to be an issue with mouse cursors on your system. Try setting the mouse cursors to default under control panel but try 1.25 again is should work round it.Went to control panel and went to change mouse pointer and I get an error that says.The C:\PinballX\BlackDot.cur file,which contains the 'Link'cursor,is either missing or corrupt.I will try 1.25 again and report back Link to comment Share on other sites More sharing options...
Darkmeteor Posted May 31, 2013 Share Posted May 31, 2013 It seems LAV is causing a lot of trouble Link to comment Share on other sites More sharing options...
R-DUB Posted May 31, 2013 Share Posted May 31, 2013 Tried 1.25 again and same. Link to comment Share on other sites More sharing options...
R-DUB Posted May 31, 2013 Share Posted May 31, 2013 Not sure if it matters but my OS is XP Pro with SP3 Link to comment Share on other sites More sharing options...
Tom Speirs Posted May 31, 2013 Share Posted May 31, 2013 Please try 1.25 again. I put an exception block around the whole function so it won't crash there again. Link to comment Share on other sites More sharing options...
R-DUB Posted May 31, 2013 Share Posted May 31, 2013 Launches but after title screen just a black screen again. Link to comment Share on other sites More sharing options...
Tom Speirs Posted May 31, 2013 Share Posted May 31, 2013 Can I have the log? Maybe the download is cached on your system? Link to comment Share on other sites More sharing options...
R-DUB Posted May 31, 2013 Share Posted May 31, 2013 Can I have the log? Maybe the download is cached on your system? Link to comment Share on other sites More sharing options...
Tom Speirs Posted May 31, 2013 Share Posted May 31, 2013 Can you post the ini. Does it work in windowed mode? Link to comment Share on other sites More sharing options...
R-DUB Posted May 31, 2013 Share Posted May 31, 2013 No it is not working in windowed mode. Link to comment Share on other sites More sharing options...
Tom Speirs Posted May 31, 2013 Share Posted May 31, 2013 Please backup C:\pinballx delete it and try a fresh install. I just need to see if its your setup or something Ive broken. Link to comment Share on other sites More sharing options...
R-DUB Posted May 31, 2013 Share Posted May 31, 2013 Ok It is working now.Never changed anything in setup between installs, ood no?Thanks Link to comment Share on other sites More sharing options...
horseyhorsey Posted May 31, 2013 Share Posted May 31, 2013 I have tried that and it works this end properly.I just threw my config and database over to C:PinballX and the tables launched fine, even TFTC , which has been a pain. None of the media is in C:PinballX, if that makes a difference. Link to comment Share on other sites More sharing options...
