New Desktop mode.
Desktop mode sets up PinballX for non cabinet usage. When set the Desktop image and video folders will be used and PinballX will run Landscape and videos and images in the desktop folder will not be rotated.
Compatible with emumovies videos and snaps.
http://youtu.be/zeaC3R24WSI
Wow! I'm gone for a few days, and I miss out on all the amazing progress with PinballX! Truly impressive work. Thanks for that! I'm excited to test out this latest update on the widescreen.
Thanks Tom this is a great frontend
The only problem i'm having is trying to remap my left and right keys to right and left shift keys.if they do work its pretty sporadic at best. when i set the key it says LShift or RShift as it should but if i go back into settings to check it it reads RShiftKey or LShiftKey .Is there a way to fix this as im building a cab and need to navigate with the flipper buttons.
Using Win7 64bit , Shark007 Codecs with 64 bit addon pack
Any help is apppreciated
Nels
EXACTLY WHAT I'VE BEEN LOOKING FOR!!!! I had just about given up on using GE for cab. Can't wait to try! Thanks
May cab (mid build) will be pincab/mame any game ex integration or the like?
  On 5/28/2013 at 2:10 PM, Tom Speirs said:
New Desktop mode.
Great idea!
Nels
I can't duplicate any keyboard issues although I get the changed text. The shift keys work fine for me. Could it be a controller issue. Is it a wireless keyboard?
I have tried it using a Logitech wireless keyboard and works fine for me, and on the cab im using an I-pac and again works fine. So cant really help as I don't get any issues. Maybe you could try using a keymapping program to address the issue.
i have a wacom tablet for drawing but i don't use that for pinball (i have a wired keyboard) when i get home from work i'll try working around that and report back...thanks for the quick response
Nelson
  On 5/29/2013 at 12:46 PM, Tom Speirs said:
Just a thought maybe its the windows Sticky Keys thing. Try running in windows mode and you will see If that is the issue.
i got it figured out Tom it was my language bar issue listed 3 different keyboard settings
Thanx again\ Nelson
