slydog43 Posted May 27, 2013 Share Posted May 27, 2013 When I press my previous page up button, it works right once or twice, but then does nothing. Skipping "down" to next letter works fine. Link to comment Share on other sites More sharing options...
pocketpal Posted May 27, 2013 Share Posted May 27, 2013 I have experienced the same behavior. Link to comment Share on other sites More sharing options...
Tom Speirs Posted May 28, 2013 Share Posted May 28, 2013 Hey fellas,Can you confirm this is fixed in the latest release?Thanks. Link to comment Share on other sites More sharing options...
pocketpal Posted May 28, 2013 Share Posted May 28, 2013 It does seem to be fixed, but now I have noticed some other odd behavior: when skipping by letter backwards, it will go from a "G" table to the last of my "F" tables, as expected, which is "Funhouse." Skip back a letter from there, though, and it goes to "Far Out" instead of the last of my "E" tables. Also, from my last "B" table, "Bronco", it goes to "Band Wagon" instead of the last "A" table. I counted the range between tables, and in both cases, it is 18. Dunno if that means something to you...? I can verify that it does nothing of the sort when skipping letters forward.EDIT: I should mention that in both cases, it is NOT skipping from the last table of a particular letter to the first table of that letter. There are more tables of each letter in the list before those.EDIT #2: I just noticed that the same thing happens in the "S" tables as well, and it ALSO is a range of 18, so I think that's key. Link to comment Share on other sites More sharing options...
horseyhorsey Posted May 28, 2013 Share Posted May 28, 2013 The page/up down always got stuck before, ok now, thanks. Link to comment Share on other sites More sharing options...
