Skinooe Posted May 22, 2013 Share Posted May 22, 2013 Programm i fast, beautiful and also for beginners GratulationSome tables of FP won't load. For Example AFM with Ledwiz support or slamtilts Avatar Ultra. Database is o.k.,Directory is o.k. with Hyperpin tables are working12:40:07.5 22.05.2013: PinballX - Version 1.0012:40:07.5 22.05.2013: Loading Settings12:40:07.5 22.05.2013: Hiding Cursor12:40:07.5 22.05.2013: Hiding Taskbar12:40:07.5 22.05.2013: Initialize Component12:40:07.5 22.05.2013: Load Game List12:40:09.0 22.05.2013: Initialize Display12:40:09.6 22.05.2013: Initialize Audio12:40:09.6 22.05.2013: Set Keyboard Controls12:40:09.7 22.05.2013: Initialize Joystick12:40:09.7 22.05.2013: 1 Joystick Attached12:40:09.7 22.05.2013: Started12:40:22.3 22.05.2013: Exiting12:40:22.7 22.05.2013: Showing Taskbar12:40:22.7 22.05.2013: Unhiding Mouse Cursor12:40:22.7 22.05.2013: Saving Settingsvideo start, but not FP (other Tables in FP work great):12:45:18.1 22.05.2013: PinballX - Version 1.0012:45:18.1 22.05.2013: Loading Settings12:45:18.1 22.05.2013: Hiding Cursor12:45:18.1 22.05.2013: Hiding Taskbar12:45:18.1 22.05.2013: Initialize Component12:45:18.2 22.05.2013: Load Game List12:45:19.6 22.05.2013: Initialize Display12:45:20.3 22.05.2013: Initialize Audio12:45:20.3 22.05.2013: Set Keyboard Controls12:45:20.3 22.05.2013: Initialize Joystick12:45:20.3 22.05.2013: 1 Joystick Attached12:45:20.3 22.05.2013: Started12:45:26.4 22.05.2013: D:\Games\Future Pinball\BAM\\Future Pinball.exe /open "D:\Games\Future Pinball\Tables\\ArcadeMayhem.fpt" /play /exit/12:46:22.0 22.05.2013: Exiting12:46:22.4 22.05.2013: Showing Taskbar12:46:22.4 22.05.2013: Unhiding Mouse Cursor12:46:22.5 22.05.2013: Saving SettingsAll tables are in the same Dir, for some Table in FP loadingscree is very short and then the eorro massage (Attache file), this message disapears after loading the table: I think the loading screen is too short, maybethe programm needs more pause input (there are some tables which are loading over 1 minute like Tron, Stern)My System: windows 7 64bit, amd quardcore,4 GB ramIt seems FP (with or without bam don't start with some tables..Greetings an much thanksKarl DirnstorferFuture Pinball.xml Link to comment Share on other sites More sharing options...
Skinooe Posted May 22, 2013 Author Share Posted May 22, 2013 MP3 Music for Ambience wonderful! So all tables are loading -very, very fast with older PC. Difference between HP und the new one: between 10 sec till 1 minute. And no more Memory leaksIt seem I have birthday.In my first post I said, some tables will not load, mistake (early I used bad Data manager, now all is right). I would recommend anyone this program. I've been thrown to the trash HP. 1 Link to comment Share on other sites More sharing options...
