Goron Posted May 11, 2013 Author Share Posted May 11, 2013 I remove game key but the problem persist... There is a mame error and the game freeze... I press esc and come back to gameex with a windows error of mame multiple arcade machine... There is another error sometimes: "there is an error in interprocess MAME rawinput hook. The application is closed" Link to comment Share on other sites More sharing options...
Goron Posted May 11, 2013 Author Share Posted May 11, 2013 The joypad of xbox 360 it' s a possibility of error? Link to comment Share on other sites More sharing options...
Goron Posted May 11, 2013 Author Share Posted May 11, 2013 Tomorrow post the new log file! Link to comment Share on other sites More sharing options...
Goron Posted May 11, 2013 Author Share Posted May 11, 2013 09:41:01.0 11/05/2013: Opening Configuration File09:41:01.5 11/05/2013: GameEx: Version 13.11: Starting Log09:41:01.6 11/05/2013: Operating System Platform: Win32NT09:41:01.6 11/05/2013: Operating System Name: Windows XP09:41:01.6 11/05/2013: Operating System Version: 5.1.260009:41:01.6 11/05/2013: Getting CPU and RAM info09:41:01.6 11/05/2013: Intel® Pentium® 4 CPU 3.00GHz, 1279MB09:41:01.7 11/05/2013: 3Ghz - 2 Cores or CPU's09:41:01.7 11/05/2013: Running Randomize()09:41:01.9 11/05/2013: Loading PlugIns09:41:02.0 11/05/2013: Checking for applications to Launch On Startup09:41:02.0 11/05/2013: Setting default net connection limit to 1509:41:02.2 11/05/2013: Running Misc startup tasks09:41:02.3 11/05/2013: Setting Menu types09:41:02.3 11/05/2013: Getting Configuration Values09:41:02.4 11/05/2013: Using Theme: Default - Media Center V109:41:02.4 11/05/2013: Checking for alternate Image Directory for Theme: Default - Media Center V109:41:02.5 11/05/2013: Launching HideOS.exe09:41:02.5 11/05/2013: Initialising Video/MNG DLL's09:41:02.5 11/05/2013: GameEx will check for media insertion (may affect performance)09:41:02.5 11/05/2013: Hiding Taskbar09:41:02.5 11/05/2013: Is Media Center running?09:41:02.5 11/05/2013: Checking/Creating LCD Registry values09:41:02.7 11/05/2013: Check Media Center Exit/Start Mode09:41:02.7 11/05/2013: Media Center Mode 209:41:03.1 11/05/2013: Video previews on. Warning: Only recommended on modern systems09:41:03.1 11/05/2013: Custom Game Device Input enabled: Getting custom codes09:41:03.1 11/05/2013: Snap Delay set to: 209:41:03.1 11/05/2013: Get other settings09:41:03.1 11/05/2013: Desktop set to Hide ICONS and set Background to Black09:41:03.1 11/05/2013: Set: Find emulator artwork on best match basis09:41:03.1 11/05/2013: Start work for Form09:41:03.1 11/05/2013: Getting Original Screen Size09:41:03.1 11/05/2013: Opening Database Connection09:41:04.7 11/05/2013: Initializing Component09:41:05.1 11/05/2013: MAME Path is: C:\Emulators GameEx\MAME09:41:05.1 11/05/2013: MAME EXE file is: mame.exe09:41:05.2 11/05/2013: ROM Path is: C:\Roms\MAME09:41:05.2 11/05/2013: Catver.ini is located at: C:\Emulators GameEx\MAME\Catver.ini09:41:05.2 11/05/2013: controls.ini is located at: C:\Emulators GameEx\MAME\controls.ini09:41:05.5 11/05/2013: History.dat is located at: C:\Emulators GameEx\MAME\history.dat09:41:05.5 11/05/2013: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini09:41:05.5 11/05/2013: command.dat is located at: C:\GameEx\DATA\command.dat09:41:05.5 11/05/2013: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat09:41:05.5 11/05/2013: Loading Controls.ini map file09:41:05.6 11/05/2013: Snap Path is: C:\Assets\MAME\Snaps09:41:05.6 11/05/2013: Background Snap Path: Not Found09:41:05.6 11/05/2013: AVI Snap Path: Not Found09:41:05.6 11/05/2013: Flyer Path: Not Found09:41:05.6 11/05/2013: Cabinet Path is: C:\Emulators GameEx\MAME\Cabinets09:41:05.6 11/05/2013: Cabinet 3D Path: Not Found09:41:05.6 11/05/2013: Title Path is: C:\Assets\MAME\Titles09:41:05.6 11/05/2013: PCB Path: Not Found09:41:05.6 11/05/2013: Artwork Preview Path: Not Found09:41:05.6 11/05/2013: Panel Path is: C:\Assets\MAME\Controls09:41:05.6 11/05/2013: Manual Path: Not Found09:41:05.6 11/05/2013: Icon Path: Not Found09:41:05.6 11/05/2013: Marquee Path is: C:\Emulators GameEx\MAME\marquees09:41:05.7 11/05/2013: Applying Language/Text09:41:05.7 11/05/2013: Text/Language: English09:41:05.7 11/05/2013: Loading Language/Text09:41:05.8 11/05/2013: Loading Custom Emulators09:41:05.9 11/05/2013: Loading Emulator 1: A) Famicom09:41:05.9 11/05/2013: Loading Emulator 2: Super Famicom09:41:06.0 11/05/2013: Loading Emulator 3: C) Nintendo 6409:41:06.0 11/05/2013: Loading Emulator 4: D) Sega Master System09:41:06.1 11/05/2013: Loading Emulator 5: E) Sega Genesis09:41:06.1 11/05/2013: Loading Emulator 6: F) Nintendo Game Boy09:41:06.1 11/05/2013: Loading Emulator 7: G) Nintendo Game Boy Color09:41:06.1 11/05/2013: Loading Emulator 8: H) Nintendo Game Boy Advance09:41:06.1 11/05/2013: Loading Emulator 9: I) Sony Playstation09:41:06.1 11/05/2013: Using 2D Animations09:41:06.1 11/05/2013: Retrieving resolution setting09:41:06.4 11/05/2013: Using General Font: Trebuchet MS09:41:06.4 11/05/2013: Using Title Font: Trebuchet MS09:41:06.4 11/05/2013: GameEx will try to reduce CPU usage09:41:06.5 11/05/2013: Initialising Direct3D09:41:07.4 11/05/2013: Setting Resolution to 1280x800 32 bit color09:41:07.5 11/05/2013: Creating Surfaces09:41:08.4 11/05/2013: Creating Primary Surface - Full Screen Mode09:41:08.4 11/05/2013: Creating Back Buffer09:41:08.4 11/05/2013: Loading graphic Surfaces09:41:08.5 11/05/2013: Display is running at: 1280x800 32bit color, 60hz09:41:08.5 11/05/2013: Adapter: NVIDIA GeForce FX 550009:41:08.5 11/05/2013: Max texture size: 4096x409609:41:08.5 11/05/2013: Available texture memory: 618MB09:41:08.7 11/05/2013: Initialising Bass Audio Library09:41:08.8 11/05/2013: Creating Surfaces Misc and Dialogs09:41:09.4 11/05/2013: Creating Surfaces Volume09:41:09.4 11/05/2013: Creating Surfaces Arrows09:41:09.5 11/05/2013: Creating Surfaces GameEXlogo Text09:41:09.5 11/05/2013: Creating Surfaces Toolbar09:41:09.7 11/05/2013: Creating Surfaces Toolbar Controls09:41:09.9 11/05/2013: Creating Surfaces Backgrounds09:41:09.9 11/05/2013: Creating Surfaces GameEx Logo09:41:09.9 11/05/2013: Creating Surface Unselected09:41:10.0 11/05/2013: Creating Surfaces Home & Exit09:41:10.1 11/05/2013: Creating Surfaces Snaps09:41:10.1 11/05/2013: Creating Surfaces Menu and List Bars09:41:11.0 11/05/2013: Creating Fonts09:41:11.0 11/05/2013: Creating Game Font09:41:11.6 11/05/2013: Creating Game Font Faded09:41:11.7 11/05/2013: Creating Title Font09:41:12.7 11/05/2013: Creating Menu Font09:41:13.0 11/05/2013: Creating Font Black09:41:13.1 11/05/2013: Creating Font Black Small09:41:13.2 11/05/2013: Fonts Created Succesfully09:41:13.6 11/05/2013: 4MB Video Memory Used09:41:35.7 11/05/2013: Attempting to load game list09:41:36.4 11/05/2013: MAME CMD options: -nowindow -joy -skip_gameinfo09:41:36.4 11/05/2013: Initialising DirectInput for Gamepad support09:41:36.5 11/05/2013: Using Device Controller (XBOX 360 For Windows)09:41:36.5 11/05/2013: Using Device Controller (XBOX 360 For Windows)09:41:36.6 11/05/2013: Loading Start Page09:41:36.7 11/05/2013: Initializing MCE Remote09:41:36.7 11/05/2013: Playing intro sound file09:41:36.7 11/05/2013: Initialization OK! Starting GameEx!09:41:36.7 11/05/2013: Testing Main Loop Once: Processing Frame09:41:37.7 11/05/2013: Testing Main Loop Once: Main Loop ran successfully09:41:53.7 11/05/2013: Validating: Emulator_1: Snap Path: C:\Assets\Nintendo NES\Snaps09:41:53.7 11/05/2013: Validating: Emulator_1: Control Panel Path: C:\Assets\Nintendo NES\Nintendo NES\Controls09:41:53.7 11/05/2013: Warning: Emulator_1: Control Panel Path Does not exist09:41:53.7 11/05/2013: Validating: Emulator_1: Database: [Console] Nintendo NES09:41:53.8 11/05/2013: Validating: Emulator_1: Title Snap Path: C:\Assets\Nintendo NES\Titles09:41:53.8 11/05/2013: Validating: Emulator_1: Box Art Path: C:\Assets\Nintendo NES\Nintendo NES\Boxes09:41:53.8 11/05/2013: Warning: Emulator_1: Box Art Path Does not exist09:41:53.8 11/05/2013: Validating: Emulator_1: Cart Art Path: C:\Assets\Nintendo NES\Nintendo NES\Cartridges09:41:53.8 11/05/2013: Warning: Emulator_1: Cart Art Path Does not exist09:41:53.8 11/05/2013: Validating: Emulator_1: Manual Path: C:\Assets\Nintendo NES\Nintendo NES\Manuals09:41:53.8 11/05/2013: Warning: Emulator_1: Manual Path Does not exist09:41:53.8 11/05/2013: Caching Video Snap Path09:41:56.4 11/05/2013: Caching Snap Path09:41:56.4 11/05/2013: Caching Title Path09:42:00.5 11/05/2013: Validating: Emulator_2: Snap Path: C:\Assets\Nintendo SNES\Snaps09:42:00.5 11/05/2013: Validating: Emulator_2: Control Panel Path: C:\Assets\Nintendo SNES\Controls09:42:00.5 11/05/2013: Validating: Emulator_2: Database: [Console] Nintendo SNES09:42:00.5 11/05/2013: Validating: Emulator_2: Title Snap Path: C:\Assets\Nintendo SNES\Titles09:42:00.5 11/05/2013: Validating: Emulator_2: Box Art Path: C:\Assets\Nintendo SNES\Boxes09:42:00.5 11/05/2013: Validating: Emulator_2: Cart Art Path: C:\Assets\Nintendo SNES\Cartridges09:42:00.5 11/05/2013: Validating: Emulator_2: Manual Path: C:\Assets\Nintendo SNES\Manuals09:42:00.5 11/05/2013: Caching Video Snap Path09:42:01.4 11/05/2013: Caching Snap Path09:42:01.4 11/05/2013: Caching Title Path09:42:05.2 11/05/2013: Caching Box Path09:42:05.2 11/05/2013: Caching Cart Path09:42:05.2 11/05/2013: Validating: Emulator_3: Snap Path: C:\Assets\Nintendo N64\Snaps09:42:05.2 11/05/2013: Validating: Emulator_3: Control Panel Path: C:\Assets\Nintendo N64\Controls09:42:05.2 11/05/2013: Validating: Emulator_3: Database: [Console] Nintendo N6409:42:05.2 11/05/2013: Validating: Emulator_3: Title Snap Path: C:\Assets\Nintendo N64\Titles09:42:05.2 11/05/2013: Validating: Emulator_3: Box Art Path: C:\Assets\Nintendo N64\Boxes09:42:05.2 11/05/2013: Validating: Emulator_3: Cart Art Path: C:\Assets\Nintendo N64\Cartridges09:42:05.2 11/05/2013: Validating: Emulator_3: Manual Path: C:\Assets\Nintendo N64\Manuals09:42:05.2 11/05/2013: Caching Video Snap Path09:42:05.2 11/05/2013: Caching Snap Path09:42:05.2 11/05/2013: Caching Title Path09:42:05.2 11/05/2013: Caching Box Path09:42:05.2 11/05/2013: Caching Cart Path09:42:05.2 11/05/2013: Validating: Emulator_4: Snap Path: C:\Assets\Sega Master System\Snaps09:42:05.2 11/05/2013: Validating: Emulator_4: Control Panel Path: C:\Assets\Sega Master System\Controls09:42:05.2 11/05/2013: Validating: Emulator_4: Database: [Console] Sega Master System09:42:05.2 11/05/2013: Validating: Emulator_4: Title Snap Path: C:\Assets\Sega Master System\Titles09:42:05.2 11/05/2013: Validating: Emulator_4: Box Art Path: C:\Assets\Sega Master System\Boxes09:42:05.2 11/05/2013: Validating: Emulator_4: Cart Art Path: C:\Assets\Sega Master System\Cartridges09:42:05.2 11/05/2013: Validating: Emulator_4: Manual Path: C:\Assets\Sega Master System\Manuals09:42:05.2 11/05/2013: Caching Video Snap Path09:42:06.0 11/05/2013: Caching Snap Path09:42:06.0 11/05/2013: Caching Title Path09:42:06.0 11/05/2013: Caching Box Path09:42:06.0 11/05/2013: Caching Cart Path09:42:06.0 11/05/2013: Validating: Emulator_5: Snap Path: C:\Assets\Sega Genesis\Snaps09:42:06.1 11/05/2013: Validating: Emulator_5: Control Panel Path: C:\Assets\Sega Genesis\Controls09:42:06.1 11/05/2013: Validating: Emulator_5: Database: [Console] Sega Genesis09:42:06.1 11/05/2013: Validating: Emulator_5: Title Snap Path: C:\Assets\Sega Genesis\Titles09:42:06.1 11/05/2013: Validating: Emulator_5: Box Art Path: C:\Assets\Sega Genesis\Boxes09:42:06.1 11/05/2013: Validating: Emulator_5: Cart Art Path: C:\Assets\Sega Genesis\Cartridges09:42:06.1 11/05/2013: Validating: Emulator_5: Manual Path: C:\Assets\Sega Genesis\Manuals09:42:06.1 11/05/2013: Caching Video Snap Path09:42:08.0 11/05/2013: Caching Snap Path09:42:08.0 11/05/2013: Caching Title Path09:42:11.5 11/05/2013: Caching Box Path09:42:11.5 11/05/2013: Caching Cart Path09:42:11.5 11/05/2013: Validating: Emulator_6: Snap Path: C:\Assets\Nintendo Game Boy\Snaps09:42:11.7 11/05/2013: Validating: Emulator_6: Control Panel Path: C:\Assets\Nintendo Game Boy\Controls09:42:11.7 11/05/2013: Validating: Emulator_6: Database: [Handheld] Nintendo Game Boy09:42:11.7 11/05/2013: Validating: Emulator_6: Title Snap Path: C:\Assets\Nintendo Game Boy\Titles09:42:11.7 11/05/2013: Validating: Emulator_6: Box Art Path: C:\Assets\Nintendo Game Boy\Boxes09:42:11.7 11/05/2013: Validating: Emulator_6: Cart Art Path: C:\Assets\Nintendo Game Boy\Cartridges09:42:11.7 11/05/2013: Validating: Emulator_6: Manual Path: C:\Assets\Nintendo Game Boy\Manuals09:42:11.7 11/05/2013: Caching Video Snap Path09:42:12.2 11/05/2013: Caching Snap Path09:42:12.2 11/05/2013: Caching Title Path09:42:12.2 11/05/2013: Caching Box Path09:42:12.2 11/05/2013: Caching Cart Path09:42:12.2 11/05/2013: Validating: Emulator_7: Snap Path: C:\Assets\Nintendo Game Boy Color\Snaps09:42:12.2 11/05/2013: Validating: Emulator_7: Control Panel Path: C:\Assets\Nintendo Game Boy Color\Controls09:42:12.2 11/05/2013: Validating: Emulator_7: Database: [Handheld] Nintendo Game Boy Color09:42:12.2 11/05/2013: Validating: Emulator_7: Title Snap Path: C:\Assets\Nintendo Game Boy Color\Titles09:42:12.2 11/05/2013: Validating: Emulator_7: Box Art Path: C:\Assets\Nintendo Game Boy Color\Boxes09:42:12.2 11/05/2013: Validating: Emulator_7: Cart Art Path: C:\Assets\Nintendo Game Boy Color\Cartridges09:42:12.2 11/05/2013: Validating: Emulator_7: Manual Path: C:\Assets\Nintendo Game Boy Color\Manuals09:42:12.2 11/05/2013: Caching Video Snap Path09:42:12.7 11/05/2013: Caching Snap Path09:42:12.7 11/05/2013: Caching Title Path09:42:12.7 11/05/2013: Caching Box Path09:42:12.7 11/05/2013: Caching Cart Path09:42:12.7 11/05/2013: Validating: Emulator_8: Snap Path: C:\Assets\Nintendo Game Boy Advance\Snaps09:42:12.8 11/05/2013: Validating: Emulator_8: Control Panel Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Controls09:42:12.8 11/05/2013: Warning: Emulator_8: Control Panel Path Does not exist09:42:12.8 11/05/2013: Validating: Emulator_8: Database: [Handheld] Nintendo Game Boy Advance09:42:12.8 11/05/2013: Validating: Emulator_8: Title Snap Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Titles09:42:12.8 11/05/2013: Warning: Emulator_8: Title Snap Path Does not exist09:42:12.8 11/05/2013: Validating: Emulator_8: Box Art Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Boxes09:42:12.8 11/05/2013: Warning: Emulator_8: Box Art Path Does not exist09:42:12.8 11/05/2013: Validating: Emulator_8: Cart Art Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Cartridges09:42:12.8 11/05/2013: Warning: Emulator_8: Cart Art Path Does not exist09:42:12.8 11/05/2013: Validating: Emulator_8: Manual Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Manuals09:42:12.8 11/05/2013: Warning: Emulator_8: Manual Path Does not exist09:42:12.8 11/05/2013: Caching Video Snap Path09:42:12.8 11/05/2013: Caching Snap Path09:42:12.8 11/05/2013: Validating: Emulator_9: Snap Path: C:\Assets\Sony Playstation\Snaps09:42:12.8 11/05/2013: Validating: Emulator_9: Control Panel Path: C:\Assets\Sony Playstation\Controls09:42:12.8 11/05/2013: Validating: Emulator_9: Database: [Console] Sony Playstation09:42:12.8 11/05/2013: Validating: Emulator_9: Title Snap Path: C:\Assets\Sony Playstation\Titles09:42:12.8 11/05/2013: Validating: Emulator_9: Box Art Path: C:\Assets\Sony Playstation\Boxes09:42:12.8 11/05/2013: Validating: Emulator_9: Cart Art Path: C:\Assets\Sony Playstation\Cartridges09:42:12.8 11/05/2013: Validating: Emulator_9: Manual Path: C:\Assets\Sony Playstation\Manuals09:42:12.8 11/05/2013: Warning: Emulator_9: MAPFile Does Not Exist09:42:12.8 11/05/2013: Caching Video Snap Path09:42:12.8 11/05/2013: Caching Snap Path09:42:12.8 11/05/2013: Caching Title Path09:42:12.8 11/05/2013: Caching Box Path09:42:12.9 11/05/2013: Caching Cart Path09:42:13.0 11/05/2013: Restoring Emulator from Cache: 109:42:13.4 11/05/2013: Restoring Emulator Database From Cache: 109:42:13.8 11/05/2013: Restoring Emulator from Cache: 209:42:14.2 11/05/2013: Restoring Emulator Database From Cache: 209:42:14.6 11/05/2013: Restoring Emulator from Cache: 309:42:14.8 11/05/2013: Restoring Emulator Database From Cache: 309:42:15.1 11/05/2013: Restoring Emulator from Cache: 409:42:15.3 11/05/2013: Restoring Emulator Database From Cache: 409:42:15.5 11/05/2013: Restoring Emulator from Cache: 509:42:15.9 11/05/2013: Restoring Emulator Database From Cache: 509:42:16.2 11/05/2013: Restoring Emulator from Cache: 609:42:16.4 11/05/2013: Restoring Emulator Database From Cache: 609:42:16.5 11/05/2013: Restoring Emulator from Cache: 709:42:16.7 11/05/2013: Restoring Emulator Database From Cache: 709:42:16.9 11/05/2013: Restoring Emulator from Cache: 809:42:16.9 11/05/2013: Restoring Emulator Database From Cache: 809:42:17.1 11/05/2013: Restoring Emulator from Cache: 909:42:17.1 11/05/2013: No Database Data: 909:42:44.9 11/05/2013: Setting Up RawInput Hook09:42:45.0 11/05/2013: Launching RawInputHook.exe09:42:46.2 11/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe 005 -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo -bezel -artpath artworkgameex09:42:46.5 11/05/2013: Shutting down display09:44:49.3 11/05/2013: Exiting game09:44:49.7 11/05/2013: Shutting down RawInput Hook09:44:49.7 11/05/2013: Writing MAME stats09:44:49.7 11/05/2013: Restoring Bezel09:44:49.7 11/05/2013: Plugin: Game Exit09:44:49.7 11/05/2013: Plugin: Process Commands09:44:49.8 11/05/2013: Restoring Window09:44:49.8 11/05/2013: Reinitializing Graphics System09:44:51.7 11/05/2013: Returning to GameEx09:46:31.8 11/05/2013: Setting Up RawInput Hook09:46:31.8 11/05/2013: Launching RawInputHook.exe09:46:32.9 11/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe 3countb -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo09:46:33.0 11/05/2013: Shutting down display09:47:18.8 11/05/2013: Gamepad removed. Attached devices: 109:47:23.1 11/05/2013: Gamepad inserted. Attached devices: 209:47:53.5 11/05/2013: Exiting game09:47:53.5 11/05/2013: Closing MAME window09:47:53.5 11/05/2013: Waiting for MAME to exit09:47:53.7 11/05/2013: MAME has exited09:47:54.1 11/05/2013: Shutting down RawInput Hook09:47:54.1 11/05/2013: Writing MAME stats09:47:54.1 11/05/2013: Plugin: Game Exit09:47:54.1 11/05/2013: Plugin: Process Commands09:47:54.1 11/05/2013: Restoring Window09:47:54.1 11/05/2013: Reinitializing Graphics System09:47:56.0 11/05/2013: Returning to GameEx09:48:00.6 11/05/2013: Gamepad removed. Attached devices: 109:48:26.6 11/05/2013: Setting Up RawInput Hook09:48:26.6 11/05/2013: Launching RawInputHook.exe09:48:27.8 11/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe sonicwi2 -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo09:48:27.8 11/05/2013: Shutting down display09:48:48.7 11/05/2013: Gamepad inserted. Attached devices: 209:49:05.8 11/05/2013: Exiting game09:49:05.8 11/05/2013: Closing MAME window09:49:05.8 11/05/2013: Waiting for MAME to exit09:49:05.9 11/05/2013: MAME has exited09:49:06.2 11/05/2013: Shutting down RawInput Hook09:49:06.2 11/05/2013: Writing MAME stats09:49:06.3 11/05/2013: Plugin: Game Exit09:49:06.3 11/05/2013: Plugin: Process Commands09:49:06.3 11/05/2013: Restoring Window09:49:06.3 11/05/2013: Reinitializing Graphics System09:49:08.2 11/05/2013: Returning to GameEx09:49:17.2 11/05/2013: Setting Up RawInput Hook09:49:17.2 11/05/2013: Launching RawInputHook.exe09:49:18.4 11/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe sonicwi2 -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo09:49:18.4 11/05/2013: Shutting down display09:56:48.8 11/05/2013: Exiting game09:56:48.8 11/05/2013: Closing MAME window09:56:48.8 11/05/2013: Waiting for MAME to exit09:56:48.9 11/05/2013: MAME has exited09:56:49.3 11/05/2013: Shutting down RawInput Hook09:56:49.3 11/05/2013: Writing MAME stats09:56:49.3 11/05/2013: Plugin: Game Exit09:56:49.3 11/05/2013: Plugin: Process Commands09:56:49.4 11/05/2013: Restoring Window09:56:49.4 11/05/2013: Reinitializing Graphics System09:56:51.2 11/05/2013: Returning to GameEx09:57:19.6 11/05/2013: Setting Up RawInput Hook09:57:19.6 11/05/2013: Launching RawInputHook.exe09:57:20.7 11/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe mshu -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo09:57:20.7 11/05/2013: Shutting down display09:59:04.4 11/05/2013: Gamepad removed. Attached devices: 109:59:18.2 11/05/2013: Gamepad inserted. Attached devices: 210:04:05.9 11/05/2013: Exiting game10:04:05.9 11/05/2013: Closing MAME window10:04:05.9 11/05/2013: Waiting for MAME to exit10:04:06.1 11/05/2013: MAME has exited10:04:06.4 11/05/2013: Shutting down RawInput Hook10:04:06.5 11/05/2013: Writing MAME stats10:04:06.5 11/05/2013: Plugin: Game Exit10:04:06.5 11/05/2013: Plugin: Process Commands10:04:06.5 11/05/2013: Restoring Window10:04:06.5 11/05/2013: Reinitializing Graphics System10:04:08.3 11/05/2013: Returning to GameEx10:04:26.5 11/05/2013: Setting Up RawInput Hook10:04:26.5 11/05/2013: Launching RawInputHook.exe10:04:27.7 11/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe mvscu -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo10:04:27.7 11/05/2013: Shutting down display10:05:04.7 11/05/2013: Exiting game10:05:04.7 11/05/2013: Closing MAME window10:05:04.7 11/05/2013: Waiting for MAME to exit10:05:04.9 11/05/2013: MAME has exited10:05:05.3 11/05/2013: Shutting down RawInput Hook10:05:05.3 11/05/2013: Writing MAME stats10:05:05.3 11/05/2013: Plugin: Game Exit10:05:05.3 11/05/2013: Plugin: Process Commands10:05:05.3 11/05/2013: Restoring Window10:05:05.3 11/05/2013: Reinitializing Graphics System10:05:07.2 11/05/2013: Returning to GameEx10:05:34.5 11/05/2013: Setting Up RawInput Hook10:05:34.5 11/05/2013: Launching RawInputHook.exe10:05:35.6 11/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe mvscu -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo10:05:35.7 11/05/2013: Shutting down display10:06:53.7 11/05/2013: Exiting game10:06:53.7 11/05/2013: Closing MAME window10:06:53.7 11/05/2013: Waiting for MAME to exit10:06:53.9 11/05/2013: MAME has exited10:06:54.3 11/05/2013: Shutting down RawInput Hook10:06:54.3 11/05/2013: Writing MAME stats10:06:54.3 11/05/2013: Plugin: Game Exit10:06:54.3 11/05/2013: Plugin: Process Commands10:06:54.3 11/05/2013: Restoring Window10:06:54.3 11/05/2013: Reinitializing Graphics System10:06:56.2 11/05/2013: Returning to GameEx10:07:03.0 11/05/2013: Setting Up RawInput Hook10:07:03.0 11/05/2013: Launching RawInputHook.exe10:07:04.2 11/05/2013: Running: cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe mmancp2u -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo10:07:04.2 11/05/2013: Shutting down display10:07:21.8 11/05/2013: Exiting game10:07:21.8 11/05/2013: Closing MAME window10:07:21.8 11/05/2013: Waiting for MAME to exit10:07:25.8 11/05/2013: MAME has exited10:07:26.2 11/05/2013: Shutting down RawInput Hook10:07:26.2 11/05/2013: Writing MAME stats10:07:26.3 11/05/2013: Plugin: Game Exit10:07:26.3 11/05/2013: Plugin: Process Commands10:07:26.3 11/05/2013: Restoring Window10:07:26.3 11/05/2013: Reinitializing Graphics System10:07:26.3 11/05/2013: Warning: Display is running in full screen compatibility mode.10:07:26.6 11/05/2013: 21 Consecutive Exceptions Occured10:07:26.6 11/05/2013: Object reference not set to an instance of an object.10:07:26.6 11/05/2013: at Direct2D.Direct2d.Device.BeginScene(Boolean Clear, Color ClearColour)10:07:26.6 11/05/2013: at Direct2D.Direct2d.Device.BeginScene(Boolean Clear)10:07:26.6 11/05/2013: at GameEx.GameEx.mainform.c(Boolean A_0)10:07:26.6 11/05/2013: at GameEx.GameEx.mainform.d3()10:07:26.6 11/05/2013: Trying reinitialising the display after sleeping for 4 seconds10:07:26.6 11/05/2013: Exception count will be dropped to 1510:07:30.7 11/05/2013: Exception initializing display10:07:30.7 11/05/2013: Error in the application.10:07:30.7 11/05/2013: at Microsoft.DirectX.Direct3D.Device..ctor(Int32 adapter, DeviceType deviceType, Control renderWindow, CreateFlags behaviorFlags, PresentParameters[] presentationParameters)10:07:30.7 11/05/2013: at Direct2D.Direct2d.Device.a(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6, Int32 A_7)10:07:30.7 11/05/2013: at Direct2D.Direct2d.Device..ctor(Form FormHandle, Int32 Width, Int32 Height, Boolean Windowed, Boolean VSync, Boolean Display16Bit, Boolean SecondaryDisplay)10:07:30.7 11/05/2013: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7, Boolean A_8)10:07:30.7 11/05/2013: at GameEx.GameEx.mainform.d3()10:07:30.7 11/05/2013: --**--10:07:30.7 11/05/2013: 21 Consecutive Exceptions Occured: Exiting10:07:30.7 11/05/2013: Closing database connection10:07:30.7 11/05/2013: First Exception:10:07:30.7 11/05/2013: Error in the application.10:07:30.7 11/05/2013: at GameEx.GameEx.mainform.c1()10:07:30.7 11/05/2013: at GameEx.GameEx.mainform.u(String A_0)10:07:30.7 11/05/2013: at GameEx.GameEx.mainform.r(Boolean A_0)10:07:30.7 11/05/2013: at GameEx.GameEx.mainform.d3()10:07:30.7 11/05/2013: Last Exception:10:07:30.7 11/05/2013: Object reference not set to an instance of an object.10:07:30.7 11/05/2013: at Direct2D.Direct2d.Device.BeginScene(Boolean Clear, Color ClearColour)10:07:30.7 11/05/2013: at Direct2D.Direct2d.Device.BeginScene(Boolean Clear)10:07:30.7 11/05/2013: at GameEx.GameEx.mainform.c(Boolean A_0)10:07:30.7 11/05/2013: at GameEx.GameEx.mainform.d3() Link to comment Share on other sites More sharing options...
Goron Posted May 11, 2013 Author Share Posted May 11, 2013 Tom this is the new log... Please help me! Link to comment Share on other sites More sharing options...
Goron Posted May 11, 2013 Author Share Posted May 11, 2013 no one knows how to help me for this problem? after 10 minutes of use mame system crashes and windows gives me an error message in multiple arcade machine emulator ... it is really frustrating Link to comment Share on other sites More sharing options...
hansolo77 Posted May 11, 2013 Share Posted May 11, 2013 Is it crashing while you're in a game? Try running the command outside of GameEx and see if it still crashes. This will eliminate GameEx from the equation. If that runs ok, then the problem is somewhere in your GameEx configuration.Try running this directly:cmd.exe /c C: C:\Emulators GameEx\MAME\mame.exe mmancp2u -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfo Link to comment Share on other sites More sharing options...
Goron Posted May 11, 2013 Author Share Posted May 11, 2013 Where i running this command? Link to comment Share on other sites More sharing options...
nullPointer Posted May 11, 2013 Share Posted May 11, 2013 You're running Windows 7 right?Click the Start menu and type cmd into the search box. You'll see cmd.exe in the search results. Open that up. For running the command directly from the command line, I'd make a small alteration to Han's suggestion. Try this:C:C:\Emulators GameEx\MAME\mame.exe mmancp2u -rompath C:\Roms\MAME -nowindow -joy -skip_gameinfoThis will help to determine if this problem is specifically related to GameEx, or something else on your system. Link to comment Share on other sites More sharing options...
Goron Posted May 11, 2013 Author Share Posted May 11, 2013 seems to work out GameEx Link to comment Share on other sites More sharing options...
Goron Posted May 11, 2013 Author Share Posted May 11, 2013 I correct my post ... the problem is even so ... there is a problem in MAME... How do i resolve this? Link to comment Share on other sites More sharing options...
hansolo77 Posted May 11, 2013 Share Posted May 11, 2013 I hate to say it, but if the problem is outside of GameEx, and in MAME itself, we don't really support it. There is a MAME website for support there... somebody might be kind enough to help you but I wouldn't expect much. Something I can suggest.. are you having this crash on one specific game, or is it ALL games? Try playing something simple like Pac-Man or Galaga, an old game that won't use a lot of system resources. You might just have an incapable videocard. Link to comment Share on other sites More sharing options...
celly Posted May 11, 2013 Share Posted May 11, 2013 Since it looks like a MAME issue, why not update your current version from here. Link to comment Share on other sites More sharing options...
Goron Posted May 12, 2013 Author Share Posted May 12, 2013 I resolve the crash problem... But i have another problem... Gameex doesn' t update the mame list... I start to update but after 5 minutes he crashes and return to window... There is not a log file for this problem... When i open gameex i find neo geo games halved... Link to comment Share on other sites More sharing options...
Tom Speirs Posted May 12, 2013 Share Posted May 12, 2013 Log please. Link to comment Share on other sites More sharing options...
Goron Posted May 12, 2013 Author Share Posted May 12, 2013 Gameex doesn't give me a log file for this problem... Link to comment Share on other sites More sharing options...
Tom Speirs Posted May 12, 2013 Share Posted May 12, 2013 There is still a log.Start > Programs > GameEx > Utilities > Log Link to comment Share on other sites More sharing options...
Goron Posted May 12, 2013 Author Share Posted May 12, 2013 16:14:45.8 12/05/2013: Opening Configuration File16:14:46.3 12/05/2013: GameEx: Version 13.11: Starting Log16:14:46.4 12/05/2013: Operating System Platform: Win32NT16:14:46.4 12/05/2013: Operating System Name: Windows XP16:14:46.4 12/05/2013: Operating System Version: 5.1.260016:14:46.4 12/05/2013: Getting CPU and RAM info16:14:46.4 12/05/2013: Intel® Pentium® 4 CPU 3.00GHz, 1279MB16:14:46.4 12/05/2013: 3Ghz - 2 Cores or CPU's16:14:46.4 12/05/2013: Running Randomize()16:14:46.6 12/05/2013: Loading PlugIns16:14:46.7 12/05/2013: Checking for applications to Launch On Startup16:14:46.7 12/05/2013: Setting default net connection limit to 1516:14:46.9 12/05/2013: Running Misc startup tasks16:14:47.1 12/05/2013: Setting Menu types16:14:47.1 12/05/2013: Getting Configuration Values16:14:47.2 12/05/2013: Using Theme: Default - Media Center V116:14:47.2 12/05/2013: Checking for alternate Image Directory for Theme: Default - Media Center V116:14:47.2 12/05/2013: Launching HideOS.exe16:14:47.2 12/05/2013: Initialising Video/MNG DLL's16:14:47.2 12/05/2013: GameEx will check for media insertion (may affect performance)16:14:47.2 12/05/2013: Hiding Taskbar16:14:47.4 12/05/2013: Is Media Center running?16:14:47.4 12/05/2013: Checking/Creating LCD Registry values16:14:47.5 12/05/2013: Check Media Center Exit/Start Mode16:14:47.5 12/05/2013: Media Center Mode 216:14:47.7 12/05/2013: Video previews on. Warning: Only recommended on modern systems16:14:47.7 12/05/2013: Custom Game Device Input enabled: Getting custom codes16:14:47.7 12/05/2013: Snap Delay set to: 216:14:47.7 12/05/2013: Get other settings16:14:47.7 12/05/2013: Desktop set to Hide ICONS and set Background to Black16:14:47.7 12/05/2013: Set: Find emulator artwork on best match basis16:14:47.7 12/05/2013: Start work for Form16:14:47.7 12/05/2013: Getting Original Screen Size16:14:47.8 12/05/2013: Opening Database Connection16:14:49.5 12/05/2013: Initializing Component16:14:49.7 12/05/2013: MAME Path is: C:\Emulators GameEx\MAME16:14:49.7 12/05/2013: MAME EXE file is: mame.exe16:14:49.7 12/05/2013: ROM Path is: C:\Roms\MAME16:14:49.7 12/05/2013: Catver.ini is located at: C:\Emulators GameEx\MAME\Catver.ini16:14:49.7 12/05/2013: controls.ini is located at: C:\Emulators GameEx\MAME\controls.ini16:14:50.0 12/05/2013: History.dat is located at: C:\Emulators GameEx\MAME\history.dat16:14:50.0 12/05/2013: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini16:14:50.0 12/05/2013: command.dat is located at: C:\GameEx\DATA\command.dat16:14:50.0 12/05/2013: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat16:14:50.0 12/05/2013: Loading Controls.ini map file16:14:50.1 12/05/2013: Snap Path is: C:\Assets\MAME\Snaps16:14:50.1 12/05/2013: Background Snap Path: Not Found16:14:50.1 12/05/2013: AVI Snap Path: Not Found16:14:50.1 12/05/2013: Flyer Path: Not Found16:14:50.1 12/05/2013: Cabinet Path is: C:\Emulators GameEx\MAME\Cabinets16:14:50.1 12/05/2013: Cabinet 3D Path: Not Found16:14:50.2 12/05/2013: Title Path is: C:\Assets\MAME\Titles16:14:50.2 12/05/2013: PCB Path: Not Found16:14:50.2 12/05/2013: Artwork Preview Path: Not Found16:14:50.2 12/05/2013: Panel Path is: C:\Assets\MAME\Controls16:14:50.2 12/05/2013: Manual Path: Not Found16:14:50.2 12/05/2013: Icon Path: Not Found16:14:50.2 12/05/2013: Marquee Path is: C:\Emulators GameEx\MAME\marquees16:14:50.2 12/05/2013: Applying Language/Text16:14:50.2 12/05/2013: Text/Language: English16:14:50.3 12/05/2013: Loading Language/Text16:14:50.3 12/05/2013: Loading Custom Emulators16:14:50.4 12/05/2013: Loading Emulator 1: A) Famicom16:14:50.4 12/05/2013: Loading Emulator 2: Super Famicom16:14:50.4 12/05/2013: Loading Emulator 3: C) Nintendo 6416:14:50.5 12/05/2013: Loading Emulator 4: D) Sega Master System16:14:50.5 12/05/2013: Loading Emulator 5: E) Sega Genesis16:14:50.5 12/05/2013: Loading Emulator 6: F) Nintendo Game Boy16:14:50.5 12/05/2013: Loading Emulator 7: G) Nintendo Game Boy Color16:14:50.5 12/05/2013: Loading Emulator 8: H) Nintendo Game Boy Advance16:14:50.5 12/05/2013: Loading Emulator 9: I) Sony Playstation16:14:50.6 12/05/2013: Using 2D Animations16:14:50.6 12/05/2013: Retrieving resolution setting16:14:50.8 12/05/2013: Using General Font: Trebuchet MS16:14:50.8 12/05/2013: Using Title Font: Trebuchet MS16:14:50.8 12/05/2013: GameEx will try to reduce CPU usage16:14:50.9 12/05/2013: Initialising Direct3D16:14:51.7 12/05/2013: Setting Resolution to 1280x800 32 bit color16:14:51.7 12/05/2013: Creating Surfaces16:14:52.6 12/05/2013: Creating Primary Surface - Full Screen Mode16:14:52.7 12/05/2013: Creating Back Buffer16:14:52.7 12/05/2013: Loading graphic Surfaces16:14:52.7 12/05/2013: Display is running at: 1280x800 32bit color, 60hz16:14:52.7 12/05/2013: Adapter: NVIDIA GeForce FX 550016:14:52.7 12/05/2013: Max texture size: 4096x409616:14:52.7 12/05/2013: Available texture memory: 618MB16:14:53.0 12/05/2013: Initialising Bass Audio Library16:14:53.0 12/05/2013: Creating Surfaces Misc and Dialogs16:14:53.7 12/05/2013: Creating Surfaces Volume16:14:53.7 12/05/2013: Creating Surfaces Arrows16:14:53.7 12/05/2013: Creating Surfaces GameEXlogo Text16:14:53.7 12/05/2013: Creating Surfaces Toolbar16:14:54.1 12/05/2013: Creating Surfaces Toolbar Controls16:14:54.3 12/05/2013: Creating Surfaces Backgrounds16:14:54.3 12/05/2013: Creating Surfaces GameEx Logo16:14:54.3 12/05/2013: Creating Surface Unselected16:14:54.4 12/05/2013: Creating Surfaces Home & Exit16:14:54.5 12/05/2013: Creating Surfaces Snaps16:14:54.5 12/05/2013: Creating Surfaces Menu and List Bars16:14:55.2 12/05/2013: Creating Fonts16:14:55.2 12/05/2013: Creating Game Font16:14:55.7 12/05/2013: Creating Game Font Faded16:14:55.9 12/05/2013: Creating Title Font16:14:55.9 12/05/2013: Restoring Title Font From Cache16:14:56.5 12/05/2013: Creating Menu Font16:14:56.7 12/05/2013: Creating Font Black16:14:56.8 12/05/2013: Creating Font Black Small16:14:57.0 12/05/2013: Fonts Created Succesfully16:14:57.4 12/05/2013: 4MB Video Memory Used16:15:19.5 12/05/2013: Attempting to load game list16:15:19.8 12/05/2013: MAME CMD options: -nowindow -joy -skip_gameinfo16:15:19.8 12/05/2013: Initialising DirectInput for Gamepad support16:15:19.9 12/05/2013: Unable to create a joystick device16:15:19.9 12/05/2013: Loading Start Page16:15:20.0 12/05/2013: Initializing MCE Remote16:15:20.0 12/05/2013: Playing intro sound file16:15:20.0 12/05/2013: Initialization OK! Starting GameEx!16:15:20.0 12/05/2013: Testing Main Loop Once: Processing Frame16:15:21.0 12/05/2013: Testing Main Loop Once: Main Loop ran successfully16:15:27.6 12/05/2013: Validating: Emulator_1: Snap Path: C:\Assets\Nintendo NES\Snaps16:15:27.7 12/05/2013: Validating: Emulator_1: Control Panel Path: C:\Assets\Nintendo NES\Nintendo NES\Controls16:15:27.7 12/05/2013: Warning: Emulator_1: Control Panel Path Does not exist16:15:27.7 12/05/2013: Validating: Emulator_1: Database: [Console] Nintendo NES16:15:27.7 12/05/2013: Validating: Emulator_1: Title Snap Path: C:\Assets\Nintendo NES\Titles16:15:27.7 12/05/2013: Validating: Emulator_1: Box Art Path: C:\Assets\Nintendo NES\Nintendo NES\Boxes16:15:27.7 12/05/2013: Warning: Emulator_1: Box Art Path Does not exist16:15:27.7 12/05/2013: Validating: Emulator_1: Cart Art Path: C:\Assets\Nintendo NES\Nintendo NES\Cartridges16:15:27.7 12/05/2013: Warning: Emulator_1: Cart Art Path Does not exist16:15:27.7 12/05/2013: Validating: Emulator_1: Manual Path: C:\Assets\Nintendo NES\Nintendo NES\Manuals16:15:27.7 12/05/2013: Warning: Emulator_1: Manual Path Does not exist16:15:27.7 12/05/2013: Caching Video Snap Path16:15:28.2 12/05/2013: Caching Snap Path16:15:28.2 12/05/2013: Caching Title Path16:15:28.7 12/05/2013: Validating: Emulator_2: Snap Path: C:\Assets\Nintendo SNES\Snaps16:15:28.7 12/05/2013: Validating: Emulator_2: Control Panel Path: C:\Assets\Nintendo SNES\Controls16:15:28.7 12/05/2013: Validating: Emulator_2: Database: [Console] Nintendo SNES16:15:28.7 12/05/2013: Validating: Emulator_2: Title Snap Path: C:\Assets\Nintendo SNES\Titles16:15:28.7 12/05/2013: Validating: Emulator_2: Box Art Path: C:\Assets\Nintendo SNES\Boxes16:15:28.7 12/05/2013: Validating: Emulator_2: Cart Art Path: C:\Assets\Nintendo SNES\Cartridges16:15:28.7 12/05/2013: Validating: Emulator_2: Manual Path: C:\Assets\Nintendo SNES\Manuals16:15:28.7 12/05/2013: Caching Video Snap Path16:15:29.0 12/05/2013: Caching Snap Path16:15:29.0 12/05/2013: Caching Title Path16:15:30.0 12/05/2013: Caching Box Path16:15:30.0 12/05/2013: Caching Cart Path16:15:30.0 12/05/2013: Validating: Emulator_3: Snap Path: C:\Assets\Nintendo N64\Snaps16:15:30.0 12/05/2013: Validating: Emulator_3: Control Panel Path: C:\Assets\Nintendo N64\Controls16:15:30.0 12/05/2013: Validating: Emulator_3: Database: [Console] Nintendo N6416:15:30.0 12/05/2013: Validating: Emulator_3: Title Snap Path: C:\Assets\Nintendo N64\Titles16:15:30.0 12/05/2013: Validating: Emulator_3: Box Art Path: C:\Assets\Nintendo N64\Boxes16:15:30.0 12/05/2013: Validating: Emulator_3: Cart Art Path: C:\Assets\Nintendo N64\Cartridges16:15:30.0 12/05/2013: Validating: Emulator_3: Manual Path: C:\Assets\Nintendo N64\Manuals16:15:30.0 12/05/2013: Caching Video Snap Path16:15:30.0 12/05/2013: Caching Snap Path16:15:30.0 12/05/2013: Caching Title Path16:15:30.0 12/05/2013: Caching Box Path16:15:30.1 12/05/2013: Caching Cart Path16:15:30.1 12/05/2013: Validating: Emulator_4: Snap Path: C:\Assets\Sega Master System\Snaps16:15:30.1 12/05/2013: Validating: Emulator_4: Control Panel Path: C:\Assets\Sega Master System\Controls16:15:30.1 12/05/2013: Validating: Emulator_4: Database: [Console] Sega Master System16:15:30.1 12/05/2013: Validating: Emulator_4: Title Snap Path: C:\Assets\Sega Master System\Titles16:15:30.1 12/05/2013: Validating: Emulator_4: Box Art Path: C:\Assets\Sega Master System\Boxes16:15:30.1 12/05/2013: Validating: Emulator_4: Cart Art Path: C:\Assets\Sega Master System\Cartridges16:15:30.1 12/05/2013: Validating: Emulator_4: Manual Path: C:\Assets\Sega Master System\Manuals16:15:30.1 12/05/2013: Caching Video Snap Path16:15:30.2 12/05/2013: Caching Snap Path16:15:30.2 12/05/2013: Caching Title Path16:15:30.2 12/05/2013: Caching Box Path16:15:30.2 12/05/2013: Caching Cart Path16:15:30.2 12/05/2013: Validating: Emulator_5: Snap Path: C:\Assets\Sega Genesis\Snaps16:15:30.3 12/05/2013: Validating: Emulator_5: Control Panel Path: C:\Assets\Sega Genesis\Controls16:15:30.3 12/05/2013: Validating: Emulator_5: Database: [Console] Sega Genesis16:15:30.3 12/05/2013: Validating: Emulator_5: Title Snap Path: C:\Assets\Sega Genesis\Titles16:15:30.3 12/05/2013: Validating: Emulator_5: Box Art Path: C:\Assets\Sega Genesis\Boxes16:15:30.3 12/05/2013: Validating: Emulator_5: Cart Art Path: C:\Assets\Sega Genesis\Cartridges16:15:30.3 12/05/2013: Validating: Emulator_5: Manual Path: C:\Assets\Sega Genesis\Manuals16:15:30.3 12/05/2013: Caching Video Snap Path16:15:30.4 12/05/2013: Caching Snap Path16:15:30.4 12/05/2013: Caching Title Path16:15:31.0 12/05/2013: Caching Box Path16:15:31.0 12/05/2013: Caching Cart Path16:15:31.0 12/05/2013: Validating: Emulator_6: Snap Path: C:\Assets\Nintendo Game Boy\Snaps16:15:31.0 12/05/2013: Validating: Emulator_6: Control Panel Path: C:\Assets\Nintendo Game Boy\Controls16:15:31.0 12/05/2013: Validating: Emulator_6: Database: [Handheld] Nintendo Game Boy16:15:31.0 12/05/2013: Validating: Emulator_6: Title Snap Path: C:\Assets\Nintendo Game Boy\Titles16:15:31.0 12/05/2013: Validating: Emulator_6: Box Art Path: C:\Assets\Nintendo Game Boy\Boxes16:15:31.0 12/05/2013: Validating: Emulator_6: Cart Art Path: C:\Assets\Nintendo Game Boy\Cartridges16:15:31.0 12/05/2013: Validating: Emulator_6: Manual Path: C:\Assets\Nintendo Game Boy\Manuals16:15:31.0 12/05/2013: Caching Video Snap Path16:15:31.1 12/05/2013: Caching Snap Path16:15:31.1 12/05/2013: Caching Title Path16:15:31.1 12/05/2013: Caching Box Path16:15:31.1 12/05/2013: Caching Cart Path16:15:31.1 12/05/2013: Validating: Emulator_7: Snap Path: C:\Assets\Nintendo Game Boy Color\Snaps16:15:31.1 12/05/2013: Validating: Emulator_7: Control Panel Path: C:\Assets\Nintendo Game Boy Color\Controls16:15:31.1 12/05/2013: Validating: Emulator_7: Database: [Handheld] Nintendo Game Boy Color16:15:31.1 12/05/2013: Validating: Emulator_7: Title Snap Path: C:\Assets\Nintendo Game Boy Color\Titles16:15:31.1 12/05/2013: Validating: Emulator_7: Box Art Path: C:\Assets\Nintendo Game Boy Color\Boxes16:15:31.1 12/05/2013: Validating: Emulator_7: Cart Art Path: C:\Assets\Nintendo Game Boy Color\Cartridges16:15:31.1 12/05/2013: Validating: Emulator_7: Manual Path: C:\Assets\Nintendo Game Boy Color\Manuals16:15:31.1 12/05/2013: Caching Video Snap Path16:15:31.4 12/05/2013: Caching Snap Path16:15:31.4 12/05/2013: Caching Title Path16:15:31.4 12/05/2013: Caching Box Path16:15:31.4 12/05/2013: Caching Cart Path16:15:31.4 12/05/2013: Validating: Emulator_8: Snap Path: C:\Assets\Nintendo Game Boy Advance\Snaps16:15:31.4 12/05/2013: Validating: Emulator_8: Control Panel Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Controls16:15:31.4 12/05/2013: Warning: Emulator_8: Control Panel Path Does not exist16:15:31.4 12/05/2013: Validating: Emulator_8: Database: [Handheld] Nintendo Game Boy Advance16:15:31.5 12/05/2013: Validating: Emulator_8: Title Snap Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Titles16:15:31.5 12/05/2013: Warning: Emulator_8: Title Snap Path Does not exist16:15:31.5 12/05/2013: Validating: Emulator_8: Box Art Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Boxes16:15:31.5 12/05/2013: Warning: Emulator_8: Box Art Path Does not exist16:15:31.5 12/05/2013: Validating: Emulator_8: Cart Art Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Cartridges16:15:31.5 12/05/2013: Warning: Emulator_8: Cart Art Path Does not exist16:15:31.5 12/05/2013: Validating: Emulator_8: Manual Path: C:\Assets\Nintendo Game Boy Advance\Nintendo Game Boy Advance\Manuals16:15:31.5 12/05/2013: Warning: Emulator_8: Manual Path Does not exist16:15:31.5 12/05/2013: Caching Video Snap Path16:15:31.5 12/05/2013: Caching Snap Path16:15:31.5 12/05/2013: Validating: Emulator_9: Snap Path: C:\Assets\Sony Playstation\Snaps16:15:31.5 12/05/2013: Validating: Emulator_9: Control Panel Path: C:\Assets\Sony Playstation\Controls16:15:31.5 12/05/2013: Validating: Emulator_9: Database: [Console] Sony Playstation16:15:31.5 12/05/2013: Validating: Emulator_9: Title Snap Path: C:\Assets\Sony Playstation\Titles16:15:31.5 12/05/2013: Validating: Emulator_9: Box Art Path: C:\Assets\Sony Playstation\Boxes16:15:31.5 12/05/2013: Validating: Emulator_9: Cart Art Path: C:\Assets\Sony Playstation\Cartridges16:15:31.5 12/05/2013: Validating: Emulator_9: Manual Path: C:\Assets\Sony Playstation\Manuals16:15:31.5 12/05/2013: Warning: Emulator_9: MAPFile Does Not Exist16:15:31.5 12/05/2013: Caching Video Snap Path16:15:31.5 12/05/2013: Caching Snap Path16:15:31.5 12/05/2013: Caching Title Path16:15:31.5 12/05/2013: Caching Box Path16:15:31.5 12/05/2013: Caching Cart Path16:15:31.6 12/05/2013: Restoring Emulator from Cache: 116:15:31.9 12/05/2013: Restoring Emulator Database From Cache: 116:15:32.2 12/05/2013: Restoring Emulator from Cache: 216:15:32.3 12/05/2013: Restoring Emulator Database From Cache: 216:15:32.6 12/05/2013: Restoring Emulator from Cache: 316:15:32.7 12/05/2013: Restoring Emulator Database From Cache: 316:15:32.9 12/05/2013: Restoring Emulator from Cache: 416:15:33.0 12/05/2013: Restoring Emulator Database From Cache: 416:15:33.2 12/05/2013: Restoring Emulator from Cache: 516:15:33.4 12/05/2013: Restoring Emulator Database From Cache: 516:15:33.5 12/05/2013: Restoring Emulator from Cache: 616:15:33.6 12/05/2013: Restoring Emulator Database From Cache: 616:15:33.7 12/05/2013: Restoring Emulator from Cache: 716:15:33.8 12/05/2013: Restoring Emulator Database From Cache: 716:15:33.9 12/05/2013: Restoring Emulator from Cache: 816:15:33.9 12/05/2013: Restoring Emulator Database From Cache: 816:15:34.0 12/05/2013: Restoring Emulator from Cache: 916:15:34.0 12/05/2013: No Database Data: 916:15:40.3 12/05/2013: Writing Game List to disk16:15:40.3 12/05/2013: Updating MAME Game List16:15:40.4 12/05/2013: Running: C: C:\Emulators GameEx\MAME\mame.exe -listxml > C:\Emulators GameEx\MAME\listinfo.dat16:16:27.5 12/05/2013: Opening Listinfo.dat16:16:29.0 12/05/2013: Reading ListInfo.dat16:16:50.7 12/05/2013: Reading ListInfo.dat - DONE16:16:50.7 12/05/2013: Running: C: C:\Emulators GameEx\MAME\mame.exe -verifysets -rompath "C:\Roms\MAME" > C:\Emulators GameEx\MAME\verify.dat16:26:18.9 12/05/2013: Opening Verify.dat16:26:19.9 12/05/2013: Processing Verify.dat16:26:20.0 12/05/2013: Total verifyable roms: 1819416:26:20.0 12/05/2013: Processing ListInfo.dat16:26:37.9 12/05/2013: Listinfo.dat Processing Complete16:26:37.9 12/05/2013: Sorting MAME Game List16:26:38.2 12/05/2013: Adding Catver.ini info to gamelist16:26:44.8 12/05/2013: Importing MAME32 Favorites16:26:44.8 12/05/2013: Updating Custom Folders16:26:44.8 12/05/2013: Writing MAME Game List To File Link to comment Share on other sites More sharing options...
Goron Posted May 12, 2013 Author Share Posted May 12, 2013 After writing MAME game list to file the system crashes and return windows... Link to comment Share on other sites More sharing options...
Goron Posted May 12, 2013 Author Share Posted May 12, 2013 there are games to the letter m Link to comment Share on other sites More sharing options...
Tom Speirs Posted May 12, 2013 Share Posted May 12, 2013 What version of MAME are you using? Where did you get it from? Link to comment Share on other sites More sharing options...
Goron Posted May 12, 2013 Author Share Posted May 12, 2013 I resolve it... After 10 times gameex complete list update... It's very stranger! Link to comment Share on other sites More sharing options...
