Hi,
Do you need to have the paid version of Gameex to be able to save settings in the setup wizard. If not for some reason mine says that it has changed the settings to what I put them too , but in the gameex ini file it appears nothing has changed.
If anyone has any infomation as to how this problem could be solved it would be much appreciated
thanks in advance
Chris
If its not saving its probably a windows user access issue. Did you install GameEx in the default path? If not please do so or run GamEx as administrator.
Do i have to completely start again ( as in unistalling ) if I didn't Run as Admin or can I just do it now and it'll work ?
ps , thanks for quick response
