Hi,
thank you for this amazing frontend.
the xbmc launcher doesn't work because there is an error in the launch.bat file in the userdata folder:
"%programfiles%\SingFront\slingfront.exe" (there is a missing "l" in the folder name SlingFront)
the path has to be corrected in:
"%programfiles%\SlingFront\slingfront.exe"
If someone needs to know where the file is located (for a manual fix):
C:\Users\"your_username"\AppData\Roaming\XBMC\addons\plugin.program.slingfront
  • 3 months later...
Noize:
Can you break it down for us non XBMC experts? I don't know how to add this slingfront to XMBC. I need step by step details. It's not zipped so I don't understand how to enable the slingfront addon inside XBMC program.
I am using win7 64bit OS.
thanks,
  On 8/20/2013 at 11:46 PM, sp22 said:
Noize:
thanks,
The original issue was fixed in an update. If XBMC is installed upon installing SlingFront it should automatically create an addon in XBMC. There should not be anything else to it.
