Hi to all!
I've a version of mame that supports highscore;
mame keeps memory of my highscore;
I've enabled highscore in the wizardsetup (mame advance settings) of gameex.
And then? What do i have to do after all that?
Hi kannadav,
when you have a compiled version of mame (hi.diff included) it should work in GameEx.
When you choose a Mame-game a hi-score menu option should be visible. See screenshot below:
post-10451-0-15214600-1367180087_thumb.j
HiToText support stopped at Mame version 0.139 per this post. In short its likely that ROMs that have been updated since this version of MAME supported by HiToText, may or may not currently work with HiToText since the affected ROMs and/or ROM sets may have been may have been updated in the meantime.
However: I use a compiled version of Mame 0.147 and a lot of ROMs are still working with HiToText and show the highscore in GameEx like the screenshot above.
I hope this will help you.
>>> when you're interested in playing Mame-games and setting hi-scores:
We have started a Mame Hi-Score Competition :)
# You can find all the threads in our Social Club > link
# Here's a link to the rules you should follow when submitting a Hi-Score > link
# If you have any questions or remarks, please add a reply in the general "Hi Score Competition" thread > link
I hope you will join our Hi-Score Competition: the more the merrier :D
GC
Hi, thanks for the answer. I've donwloaded this mame version:
and as i told mame keeps my highscore so i think that it's all set ok.
Then i've enabled hitotext in GameEx and i've played Donkey Kong's rom via GameEx, done an highscore, but at the return in GameEx no any voice like "High Score" in my menù. It seems to me that GameEx doesn't know where find the folder or how launch HiToText; bho...
Ciao!
The normal advice applies here. Please post your GameEx.ini and we'll see if we can spot something. Bear in mind that HiToText doesn't support all games which support saving high scores, but I believe Donkey Kong should still be compatible.
18:04:25.6 28/04/2013: Opening Configuration File
18:04:25.7 28/04/2013: GameEx: Version 13.10: Starting Log
18:04:25.7 28/04/2013: Operating System Platform: Win32NT
18:04:25.7 28/04/2013: Operating System Name: Windows 7
18:04:25.7 28/04/2013: Operating System Version: 6.1.7601
18:04:25.7 28/04/2013: Aero running
18:04:25.7 28/04/2013: Initializing Vista/Windows 7 volume control
18:04:25.7 28/04/2013: Getting CPU and RAM info
18:04:25.7 28/04/2013: Intel® Core i7 CPU 860 @ 2.80GHz, 4087MB
18:04:25.7 28/04/2013: 2,81Ghz - 8 Cores or CPU's
18:04:25.7 28/04/2013: Running Randomize()
18:04:25.7 28/04/2013: Loading PlugIns
18:04:25.7 28/04/2013: Checking for applications to Launch On Startup
18:04:25.7 28/04/2013: Setting default net connection limit to 15
18:04:25.7 28/04/2013: Running Misc startup tasks
18:04:25.7 28/04/2013: Setting Menu types
18:04:25.7 28/04/2013: Getting Configuration Values
18:04:25.7 28/04/2013: Using Theme: Default - Default
18:04:25.7 28/04/2013: Checking for alternate Image Directory for Theme: Default - Default
18:04:25.7 28/04/2013: Launching HideOS.exe
18:04:25.7 28/04/2013: Initialising Video/MNG DLL's
18:04:25.7 28/04/2013: CPWizard enabled
18:04:25.7 28/04/2013: CPWizard path invalid. Not using CPWizard
18:04:25.7 28/04/2013: Hiding Taskbar
18:04:25.7 28/04/2013: Using Cabinet Friendly Control System
18:04:25.7 28/04/2013: Is Media Center running?
18:04:25.7 28/04/2013: Checking/Creating LCD Registry values
18:04:25.7 28/04/2013: Check Media Center Exit/Start Mode
18:04:25.7 28/04/2013: Media Center Mode 2
18:04:25.8 28/04/2013: Video previews on. Warning: Only recommended on modern systems
18:04:25.8 28/04/2013: Custom Keyboard Input enabled: Getting custom codes
18:04:25.8 28/04/2013: Snap Delay set to: 4
18:04:25.8 28/04/2013: Get other settings
18:04:25.8 28/04/2013: Desktop set to Hide ICONS and set Background to Black
18:04:25.8 28/04/2013: Set: Find emulator artwork on best match basis
18:04:25.8 28/04/2013: SlikStik support enabled
18:04:25.8 28/04/2013: Using DirectInput for keyboard input
18:04:25.8 28/04/2013: Start work for Form
18:04:25.8 28/04/2013: Getting Original Screen Size
18:04:25.8 28/04/2013: Opening Database Connection
18:04:25.8 28/04/2013: Initializing Component
18:04:25.9 28/04/2013: MAME Path is: D:\Arcade Cab\Mame 0.148
18:04:25.9 28/04/2013: MAME EXE file is: mameui.exe
18:04:25.9 28/04/2013: ROM Path is: D:\Arcade Cab\Mame 0.148\roms Set Completo alla 0.148 (No CHD)
18:04:25.9 28/04/2013: Catver.ini Not Found
18:04:25.9 28/04/2013: History.dat Not Found
18:04:25.9 28/04/2013: nplayers.ini Not Found
18:04:25.9 28/04/2013: command.dat is located at: D:\GameExreinstallato\DATA\command.dat
18:04:26.0 28/04/2013: MAMEinfo.dat Not Found
18:04:26.0 28/04/2013: Loading Controls.ini map file
18:04:26.0 28/04/2013: Snap Path is: D:\Arcade Cab\Mame 0.148\snap\InGame AntoPisa 0.148
18:04:26.0 28/04/2013: Background Snap Path: Not Found
18:04:26.0 28/04/2013: AVI Snap Path is: D:\Arcade Cab\Mame 0.148\video
18:04:26.0 28/04/2013: Flyer Path is: D:\Arcade Cab\Mame 0.148\snap\Flyers AntoPisa 0.148_4
18:04:26.0 28/04/2013: Cabinet Path is: D:\Arcade Cab\Mame 0.148\snap\Cabinet AntoPisa 0.148_2
18:04:26.0 28/04/2013: Cabinet 3D Path is: D:\GameExreinstallato\3D Cabinet
18:04:26.0 28/04/2013: Title Path is: D:\Arcade Cab\Mame 0.148\snap\Titles AntoPisa 0.148
18:04:26.0 28/04/2013: PCB Path: Not Found
18:04:26.0 28/04/2013: Artwork Preview Path is: D:\Arcade Cab\Mame 0.148\snap\Artwork Preview AntoPisa 0.148
18:04:26.0 28/04/2013: Panel Path is: D:\Arcade Cab\Mame 0.148\snap\Control Panel AntoPisa 0.148
18:04:26.0 28/04/2013: Manual Path: Not Found
18:04:26.0 28/04/2013: Icon Path: Not Found
18:04:26.0 28/04/2013: Marquee Path is: D:\Arcade Cab\Mame 0.148\snap\Marquee AntoPisa 0.148
18:04:26.0 28/04/2013: Applying Language/Text
18:04:26.0 28/04/2013: Text/Language: Custom
18:04:26.0 28/04/2013: Loading Language/Text
18:04:26.0 28/04/2013: Loading Custom Emulators
18:04:26.0 28/04/2013: Loading Emulator 1: Capcom Play System 3
18:04:26.0 28/04/2013: Loading Emulator 2: Sega NAOMI
18:04:26.0 28/04/2013: Loading Emulator 3: Sammy Atomiswave
18:04:26.0 28/04/2013: Loading Emulator 5: NullDC
18:04:26.0 28/04/2013: Loading Emulator 6: Makaron
18:04:26.0 28/04/2013: Loading Emulator 7: Sega Model 2
18:04:26.0 28/04/2013: Checking if Steam enabled
18:04:26.0 28/04/2013: Steam is installed correctly
18:04:26.0 28/04/2013: Invalid or filtered path: c:\\program files (x86)\\skyrim\\steamapps\\ottolola\\winui
18:04:26.0 28/04/2013: Directory does not exist: c:\\program files (x86)\\skyrim\\steamapps\\ottolola\\valvetestapp207510
18:04:26.0 28/04/2013: Did not find any Steam games
18:04:26.0 28/04/2013: Loading Emulator Group 1: Sega NAOMI
18:04:26.0 28/04/2013: Using 3D Alpha Blended Animations.
18:04:26.0 28/04/2013: Retrieving resolution setting
18:04:26.0 28/04/2013: Using General Font: Trebuchet MS
18:04:26.0 28/04/2013: Using Title Font: Trebuchet MS
18:04:26.0 28/04/2013: GameEx will try to reduce CPU usage
18:04:26.1 28/04/2013: Initialising Direct3D
18:04:26.2 28/04/2013: Mouse Input is disabled
18:04:26.2 28/04/2013: Setting Resolution to 800x600 32 bit color
18:04:26.2 28/04/2013: Creating Surfaces
18:04:27.0 28/04/2013: Creating Primary Surface - Full Screen Mode
18:04:27.0 28/04/2013: Creating Back Buffer
18:04:27.1 28/04/2013: Loading graphic Surfaces
18:04:27.1 28/04/2013: Display is running at: 800x600 32bit color, 75hz
18:04:27.1 28/04/2013: Adapter: ATI Radeon HD 5800 Series
18:04:27.1 28/04/2013: Max texture size: 16384x16384
18:04:27.1 28/04/2013: Available texture memory: -1300MB
18:04:27.1 28/04/2013: Initialising Bass Audio Library
18:04:27.2 28/04/2013: Creating Surfaces Misc and Dialogs
18:04:27.3 28/04/2013: Creating Surfaces Volume
18:04:27.3 28/04/2013: Creating Surfaces Arrows
18:04:27.3 28/04/2013: Creating Surfaces GameEXlogo Text
18:04:27.3 28/04/2013: Creating Surfaces Toolbar
18:04:27.3 28/04/2013: Creating Surfaces Toolbar Controls
18:04:27.3 28/04/2013: Creating Surfaces Backgrounds
18:04:27.3 28/04/2013: Creating Surfaces GameEx Logo
18:04:27.3 28/04/2013: Creating Surface Unselected
18:04:27.3 28/04/2013: Creating Surfaces Snaps
18:04:27.3 28/04/2013: Creating Surfaces Menu and List Bars
18:04:27.4 28/04/2013: Creating Fonts
18:04:27.4 28/04/2013: Creating Game Font
18:04:27.5 28/04/2013: Creating Game Font Faded
18:04:27.5 28/04/2013: Creating Title Font
18:04:27.5 28/04/2013: Restoring Title Font From Cache
18:04:27.6 28/04/2013: Creating Font Black
18:04:27.6 28/04/2013: Creating Font Black Small
18:04:27.7 28/04/2013: Fonts Created Succesfully
18:04:27.8 28/04/2013: Attempting to load game list
18:04:27.9 28/04/2013: MAME CMD options: -nowindow -joy -skip_gameinfo
18:04:28.3 28/04/2013: Gamepad/Joystick disabled
18:04:28.3 28/04/2013: Initialising DirectInput for Keyboard support
18:04:28.4 28/04/2013: Loading Start Page
18:04:28.4 28/04/2013: Initializing MCE Remote
18:04:28.4 28/04/2013: Playing intro sound file
18:04:28.4 28/04/2013: Initialization OK! Starting GameEx!
18:04:28.4 28/04/2013: Testing Main Loop Once: Processing Frame
18:04:28.6 28/04/2013: Testing Main Loop Once: Main Loop ran successfully
18:04:28.9 28/04/2013: Validating: Emulator_1: Snap Path: D:\Arcade Cab\CPS3\Media\Snap
18:04:28.9 28/04/2013: Warning: Emulator_1: Snap Path Does not exist
18:04:28.9 28/04/2013: Validating: Emulator_1: Video Snap Path: D:\Arcade Cab\CPS3\Media\Video
18:04:28.9 28/04/2013: Validating: Emulator_1: Custom Art Path 1: D:\Arcade Cab\Mame 0.148\snap\Flyers AntoPisa 0.148_4
18:04:28.9 28/04/2013: Validating: Emulator_1: Custom Art Path 2: D:\Arcade Cab\Mame 0.148\snap\Cabinet AntoPisa 0.148_2
18:04:28.9 28/04/2013: Validating: Emulator_1: Custom Art Path 3: D:\Arcade Cab\Mame 0.148\snap\Marquee AntoPisa 0.148
18:04:28.9 28/04/2013: Validating: Emulator_1: Custom Art Path 4: D:\Arcade Cab\Mame 0.148\snap\Control Panel AntoPisa 0.148
18:04:28.9 28/04/2013: Validating: Emulator_1: Custom Art Path 5: Artwork Preview AntoPisa 0.148
18:04:28.9 28/04/2013: Warning: Emulator_1: Custom Art Path 5 Does not exist
18:04:28.9 28/04/2013: Validating: Emulator_1: Database: [Arcade] Romset completo 0.148
18:04:28.9 28/04/2013: Validating: Emulator_1: Title Snap Path: D:\Arcade Cab\Mame 0.148\snap\Titles AntoPisa 0.148
18:04:28.9 28/04/2013: Caching Video Snap Path
18:04:28.9 28/04/2013: Caching Snap Path
18:04:28.9 28/04/2013: Caching Title Path
18:04:28.9 28/04/2013: Validating: Emulator_2: Snap Path: D:\Arcade Cab\Demul\Media\Naomi\In Game
18:04:28.9 28/04/2013: Validating: Emulator_2: Video Snap Path: D:\Arcade Cab\Demul\Media\Naomi\Video
18:04:28.9 28/04/2013: Validating: Emulator_2: Custom Art Path 1: D:\Arcade Cab\Mame 0.148\snap\Flyers AntoPisa 0.148_4
18:04:28.9 28/04/2013: Validating: Emulator_2: Custom Art Path 2: D:\Arcade Cab\Mame 0.148\snap\Cabinet AntoPisa 0.148_2
18:04:28.9 28/04/2013: Validating: Emulator_2: Custom Art Path 3: D:\Arcade Cab\Mame 0.148\snap\Marquee AntoPisa 0.148
18:04:28.9 28/04/2013: Validating: Emulator_2: Custom Art Path 4: D:\Arcade Cab\Mame 0.148\snap\Control Panel AntoPisa 0.148
18:04:28.9 28/04/2013: Validating: Emulator_2: Custom Art Path 5: Artwork Preview AntoPisa 0.148
18:04:28.9 28/04/2013: Warning: Emulator_2: Custom Art Path 5 Does not exist
18:04:28.9 28/04/2013: Validating: Emulator_2: Database: [Arcade] Romset completo 0.148
18:04:28.9 28/04/2013: Validating: Emulator_2: Title Snap Path: D:\Arcade Cab\Mame 0.148\snap\Titles AntoPisa 0.148
18:04:28.9 28/04/2013: Validating: Emulator_3: Snap Path: D:\Arcade Cab\Demul\Media\Atomiswave\In Game
18:04:28.9 28/04/2013: Validating: Emulator_3: Video Snap Path: D:\Arcade Cab\Demul\Media\Atomiswave\Video
18:04:28.9 28/04/2013: Validating: Emulator_3: Custom Art Path 1: D:\Arcade Cab\Mame 0.148\snap\Flyers AntoPisa 0.148_4
18:04:28.9 28/04/2013: Validating: Emulator_3: Custom Art Path 2: D:\Arcade Cab\Mame 0.148\snap\Cabinet AntoPisa 0.148_2
18:04:28.9 28/04/2013: Validating: Emulator_3: Custom Art Path 3: D:\Arcade Cab\Mame 0.148\snap\Marquee AntoPisa 0.148
18:04:28.9 28/04/2013: Validating: Emulator_3: Custom Art Path 4: D:\Arcade Cab\Mame 0.148\snap\Control Panel AntoPisa 0.148
18:04:28.9 28/04/2013: Validating: Emulator_3: Custom Art Path 5: Artwork Preview AntoPisa 0.148
18:04:28.9 28/04/2013: Warning: Emulator_3: Custom Art Path 5 Does not exist
18:04:28.9 28/04/2013: Validating: Emulator_3: Database: [Arcade] Romset completo 0.148
18:04:28.9 28/04/2013: Validating: Emulator_3: Title Snap Path: D:\Arcade Cab\Mame 0.148\snap\Titles AntoPisa 0.148
18:04:28.9 28/04/2013: Validating: Emulator_5: Snap Path: D:\Arcade Cab\NullDC\EmuCR-nullDC-Naomi-r150\Roms\Media\Snap
18:04:28.9 28/04/2013: Validating: Emulator_5: Video Snap Path: D:\Arcade Cab\NullDC\EmuCR-nullDC-Naomi-r150\Roms\Media\Video
18:04:28.9 28/04/2013: Validating: Emulator_5: Custom Art Path 1: D:\Arcade Cab\Mame 0.148\snap\Flyers AntoPisa 0.148_4
18:04:28.9 28/04/2013: Validating: Emulator_5: Custom Art Path 2: D:\Arcade Cab\Mame 0.148\snap\Cabinet AntoPisa 0.148_2
18:04:28.9 28/04/2013: Validating: Emulator_5: Custom Art Path 3: D:\Arcade Cab\Mame 0.148\snap\Marquee AntoPisa 0.148
18:04:28.9 28/04/2013: Validating: Emulator_5: Custom Art Path 4: D:\Arcade Cab\Mame 0.148\snap\Control Panel AntoPisa 0.148
18:04:28.9 28/04/2013: Validating: Emulator_5: Database: [Arcade] Romset completo 0.148
18:04:28.9 28/04/2013: Validating: Emulator_5: Title Snap Path: D:\Arcade Cab\Mame 0.148\snap\Titles AntoPisa 0.148
18:04:28.9 28/04/2013: Warning: Emulator_5: MAPFile Does Not Exist
18:04:28.9 28/04/2013: Validating: Emulator_6: Snap Path: D:\Arcade Cab\NullDC\EmuCR-nullDC-Naomi-r150\Roms\Roms Makaron\Media\Snap
18:04:28.9 28/04/2013: Validating: Emulator_6: Video Snap Path: D:\Arcade Cab\NullDC\EmuCR-nullDC-Naomi-r150\Roms\Roms Makaron\Media\Video
18:04:28.9 28/04/2013: Validating: Emulator_6: Custom Art Path 1: D:\Arcade Cab\Mame 0.148\snap\Flyers AntoPisa 0.148_4
18:04:28.9 28/04/2013: Validating: Emulator_6: Custom Art Path 2: D:\Arcade Cab\Mame 0.148\snap\Cabinet AntoPisa 0.148_2
18:04:28.9 28/04/2013: Validating: Emulator_6: Custom Art Path 3: D:\Arcade Cab\Mame 0.148\snap\Marquee AntoPisa 0.148
18:04:28.9 28/04/2013: Validating: Emulator_6: Custom Art Path 4: D:\Arcade Cab\Mame 0.148\snap\Control Panel AntoPisa 0.148
18:04:28.9 28/04/2013: Validating: Emulator_6: Database: [Arcade] Romset completo 0.148
18:04:28.9 28/04/2013: Validating: Emulator_6: Title Snap Path: D:\Arcade Cab\Mame 0.148\snap\Titles AntoPisa 0.148
18:04:28.9 28/04/2013: Warning: Emulator_6: MAPFile Does Not Exist
18:04:28.9 28/04/2013: Validating: Emulator_7: Snap Path: D:\Arcade Cab\Sega Model\model 2\Media\Snap
18:04:28.9 28/04/2013: Validating: Emulator_7: Video Snap Path: D:\Arcade Cab\Sega Model\model 2\Media\Video
18:04:28.9 28/04/2013: Validating: Emulator_7: Custom Art Path 1: D:\Arcade Cab\Mame 0.148\snap\Flyers AntoPisa 0.148_4
18:04:28.9 28/04/2013: Validating: Emulator_7: Custom Art Path 2: D:\Arcade Cab\Mame 0.148\snap\Cabinet AntoPisa 0.148_2
18:04:28.9 28/04/2013: Validating: Emulator_7: Custom Art Path 3: D:\Arcade Cab\Mame 0.148\snap\Marquee AntoPisa 0.148
18:04:28.9 28/04/2013: Validating: Emulator_7: Custom Art Path 4: D:\Arcade Cab\Mame 0.148\snap\Control Panel AntoPisa 0.148
18:04:28.9 28/04/2013: Validating: Emulator_7: Database: [Arcade] Romset completo 0.148
18:04:28.9 28/04/2013: Validating: Emulator_7: Title Snap Path: D:\Arcade Cab\Mame 0.148\snap\Titles AntoPisa 0.148
18:04:28.9 28/04/2013: Restoring Emulator Database From Cache: 1
18:04:28.9 28/04/2013: Restoring Emulator Database From Cache: 2
18:04:29.0 28/04/2013: Restoring Emulator Database From Cache: 3
18:04:29.0 28/04/2013: Restoring Emulator from Cache: 5
18:04:29.0 28/04/2013: Restoring Emulator Database From Cache: 5
18:04:29.0 28/04/2013: Restoring Emulator from Cache: 6
18:04:29.0 28/04/2013: Restoring Emulator Database From Cache: 6
18:04:29.0 28/04/2013: Restoring Emulator Database From Cache: 7
18:05:15.8 28/04/2013: Setting Up RawInput Hook
18:05:15.8 28/04/2013: Launching RawInputHook.exe
18:05:17.1 28/04/2013: Running: cmd.exe /c D: D:\Arcade Cab\Mame 0.148\mameui.exe dkong -rompath D:\Arcade Cab\Mame 0.148\roms Set Completo alla 0.148 (No CHD) -nowindow -joy -skip_gameinfo -bezel -artpath artworkgameex
18:05:17.2 28/04/2013: Shutting down display
18:12:07.1 28/04/2013: Exiting game
18:12:07.2 28/04/2013: Closing MAME window
18:12:07.2 28/04/2013: Waiting for MAME to exit
18:12:07.9 28/04/2013: MAME has exited
18:12:09.1 28/04/2013: Shutting down RawInput Hook
18:12:09.2 28/04/2013: Writing MAME stats
18:12:09.2 28/04/2013: Restoring Bezel
18:12:09.2 28/04/2013: Plugin: Game Exit
18:12:09.2 28/04/2013: Plugin: Process Commands
18:12:09.3 28/04/2013: Restoring Window
18:12:09.3 28/04/2013: Reinitializing Graphics System
18:12:09.3 28/04/2013: Mouse Input is disabled
18:12:10.7 28/04/2013: Returning to GameEx
18:12:49.7 28/04/2013: Exiting GameEx!
18:12:49.7 28/04/2013: Disposing all videos
18:12:49.7 28/04/2013: Deleting temporary Karaoke videos
18:12:49.7 28/04/2013: Disposing Image List
18:12:49.7 28/04/2013: Disposing Fonts
18:12:49.7 28/04/2013: Disposing Surfaces
18:12:49.7 28/04/2013: Saving Settings
18:12:49.7 28/04/2013: Shutting down Bass
18:12:49.8 28/04/2013: Closing HideOS.exe
18:12:50.1 28/04/2013: Disposing Plugins
18:12:50.1 28/04/2013: Closing database connection
18:12:50.1 28/04/2013: Checking for applications to Launch On Exit
18:12:50.1 28/04/2013: Media Center was not open when starting GameEx, so not launching
18:12:50.2 28/04/2013: Bye
GameEx.txt
GameEx.txt
Bye!
@kannadav:
could you check the following:
> do you have a 'hi-folder' in your mame root directory?
> is the hiscore.dat present in your mame root directory?
GC
@ Kannadav:
> I noticed you have a seperate diff-folder. My "hi_....diff" file is present in my mame root directory. Maybe you should try this...?
> Maybe you could try downloading the latest hiscore.dat file from here: link
Good luck!
GC
Did you have any luck Kannadav?
Is the 'Hi-Score' menu option visible in Game-Ex (for most games) ?
Cya,
GC
