Two things I've noticed in GameEx that do not match the setup wizard:
1) Under theme selection in the wizard I have "Default - Media Center" selected but if you look in the log files "Default - Media Center V1" is selected. (There is also a Default - Media Center V1" in the theme selection dropdown) Why doesn't this match?
2) Under tweaks/performance in the wizard you can select your system config (very high, high, medium, low). No matter what option I select it always goes back to medium.
Z
GameEx.ini
Hi zeenon,
I can't speak to your first question, but the second question is related specifically to the Setup Wizard in that it doesn't correctly reflect the current value of your performance setting. When you change the value in the Setup Wizard, the selection will still be saved to your GameEx settings.
  On 3/23/2013 at 12:56 AM, Tom Speirs said:
Although the dropdown box always states medium it will apply the settings if you change it.
