I know you can bring up the menu and navigate to edit the settings for the slingbox you are viewing but this is quite longwinded if you just want to switch to another resolution quickly.
So could we have the possibility to either bring up the resolution menu directly via a key or be able to assign some keys to specific resolutions?
It would be nice to assign keys to 640x480, 1280x720 and 1920x544/1920x1080 resolutions. It think it would be enough. Other resolutions could be accessible trough menu.
Yep, something like that would be great.
So you could easily flick down to a lower resolution if your Internet connection goes bad.
I know the Auto setting is meant to do all this but I find it's a bit too conservative - I never get the highest resolution even though 80-90% of the time my connection can handle it.
