I've been trying out Slingfront on a fairly low spec HTPC (Zotac ZBOX nano XS 11 plus to be precise) and while the video and audio stream satisfactorily, I find things get in a bit of a pickle when the menu UI is overlayed onto the stream. The stream freezes and glitches and the UI components can take a long time to draw making it painful to use.
So would it be possible to have another setting whereby when you return to the menu you could have it disconnect from the stream rather than darken the screen and overlay the UI?
Alternatively, you could just add an additional straightforward 'Disconnect' action which you could map to a key and do it that way.
  On 3/25/2013 at 9:50 PM, Tom Speirs said:
There is a control assigned to "Stop" which should do what you want.
Ah yes, thanks, I had assumed that one would just issue a remote Stop command but I can now see that it disconnects the stream.
Probably covered by my feature request for more mappings but could we have separate stop and disconnect commands?
