Ok, so I just did some work on my control panel. I put in a couple of mag stik plus joysticks. I had to do some drilling to install these, as my previous joysticks had different hole locations. I decided to remove all the push buttons and trackball as well. That way I could put on some polycarbonate, which looks fantastic. When I put it all back together, everything works great. EXCEPT THIS ONE STUBBORN PUSHBUTTON!!!!!! Basically it only seems to register when the button is released. I'm using the iPac4 to wire the control panel. I have the stubborn push button wired to the NO and ground (ground looped through whole panel) on the switch. This is the same wiring setup I used for every pushbutton. I tried a new switch, which did not fix the issue. I then tried to rewire that specific push button, which did not fix the issue. It's the player 2 button 2 push button. I reset the default settings for the ipac 4 and then reprogrammed the controls I switched, that did not fix the issue. It's starting to drive me nuts!!! Has anyone else had this issue?? Thanks!
Well, I restarted the computer. Then I went back and restored default settings a second time. I then restarted a third time and it was back to normal. It appears more of a software (OPERATOR) issue than a hardware thing. Ah well, I'm thankful Andy over at Ultimarc is so accomodating with questions.
