  1. Music in Main Menu should be turned off by default.
I don't see option to manually set resolution and available bandwidth. Are you going to add those?
After pressing "N" - NextSlingbox video stops, "Connecting…" is displayed and nothing happens. I need to press Alt+F4 to exit the app. The Slingbox I'm using is the last Slingbox on the list (3 Slingboxes in total).
How to display at any time, this small window with stream details that is shown after connecting?
