Change ESC in GameEx when not using MAME emu?
Hi
I'm launching my C64 games with WinVice throught GameEx. However, the ESC key is critical to C64 games but pressing it takes me back to the GameEx frontend. With MAME, I can press TAB and bring up the menu that allows me to assign keys for the UI but this menu isn't available elsewhere. How can I change the function of the ESC key to be something else, like ALT+F4?
Slink
There are a few methods, one is to use an Autohotkey script to launch before the emulator that maps the keys the way you want. (Do a search on this forum for "Autohotkey" for more info).
The second method is to use Resource Hacker on the WinVice executable. Do a search for the VK_ESCAPE mapping and swap it with another virtual key mapping.
The third method uses the ConfigFile=<name> option under [Emulator_X] in the GameEx.ini file. You place the file <name> in the CONFIG\EMULATORS directory and use the following options...
MapEscape=False
KeysToSendOnExit=%{F4}
The above will disable the escape key for exit, and send ALT-F4 to exit.
Thanks for the reply. I went for option 3 as it seemed the easiest but it doesn't appear to be working. I just pasted in what you put to a WinVice.ini file I created in the config\Emulators folder and pointed to it in the GameEx.ini but no joy. The log doesn't appear to show entries for any advanced config files. Is there anyway to check that it's being used. Has the syntax changed in this latest version perhaps?
Actually, I think it is using the ini file because ALT+F4 now exits me from WinVice and back to GameEx, the trouble is, ESC does aswell! MapEscape=FALSE isn't working.
Hi slinkofff. This does work. I use this method myself. Have you set MapKeys=False in the main config aswell as MapEscape=False
in the advanced config.
J.
I believe you, so what am I doing wrong here?
Contents of Emu section in GameEx.ini
[Emulator_1]
StartPageName=Commodore 64 Games - Highlights
TitleText=C64
StartPageLogo=C64
RomFilter=
RomsInFolders=True
ROMPath=S:\My Documents\My Games\ROMS\C64
SnapPath=
WorkingPath=C:\Program Files\Vice C64 Emu
MapKeys=False
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=False
Debug=False
MapFile=C:\Program Files\GameEx\CONFIG\C64 Map File.map
OLDatZip=
Command=x64.exe -fullscreen -autostart "[ROMPath]\[RomFile]"
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=C:\Program Files\GameEx\CONFIG\EMULATORS\WinVice.ini
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
Contents of winvice.ini:
MapEscape=False
I think this is it.
Change KeysToSendOnExit=%{F4}
To KeysToSendOnExit=%x.
If it is winvice you are using . Then it exits using ALT and x not ALT and F4.
J.
its weird, it seem to work for the first press, but then the next time ESC will take me back to GameEx. Does this happen to you?
